RTEMS 6.1
Motorola 68340 Board Support Package. More...
Files | |
| file | bsp.h |
| Global BSP definitions. | |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| Install an interrupt handler. | |
| int | dbug_in_char (int minor) |
| void | dbug_out_char (int minor, int ch) |
| int | dbug_char_present (int minor) |
| void | _dbug_dumpanic (void) |
| void | _Init68340 (void) |
| rtems_isr_entry | M68Kvec [] |
| rtems_isr_entry set_vector | ( | rtems_isr_entry | handler, |
| rtems_vector_number | vector, | ||
| int | type | ||
This method installs an interrupt handle.
| [in] | handler | is the isr routine |
| [in] | vector | is the vector number |
| [in] | type | indicates whether RTEMS or RAW intr |
