RTEMS 6.1
Modules | Files | Functions
TLL6527M Board Support Package. More...
 CPLB Configuration
 CPLB Configuration.
 TM27 Test Support
 Interrupt Mechanisms for TM27.
file  bsp.h
 Global BSP definitions.
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler.
void Init_RTC (void)
void bfin_null_isr (void)
PLL Configuration
#define PLL_CSEL   0x0000
 CCLK = VCO *‍/.
#define PLL_SSEL   0x0003
 SCLK = CCLK/3 *‍/.
#define PLL_MSEL   0x3A00
 VCO = 29xCLKIN *‍/.
#define PLL_DF   0x0001
 CLKIN = XTL/2 *‍/.
Clock setup values
#define CLKIN   (25000000)
 Input clock to the PLL *‍/.
#define CCLK   (600000000)
 CORE CLOCK *‍/.
#define SCLK   (100000000)
 SYSTEM CLOCK *‍/.
UART setup values
#define BAUDRATE   57600
 Console Baudrate *‍/.
#define WORD_5BITS   0x00
 5 bits word *‍/
#define WORD_6BITS   0x01
 6 bits word *‍/
#define WORD_7BITS   0x02
 7 bits word *‍/
#define WORD_8BITS   0x03
 8 bits word *‍/
#define EVEN_PARITY   0x18
 Enable EVEN parity *‍/.
#define ODD_PARITY   0x08
 Enable ODD parity *‍/.
#define TWO_STP_BIT   0x04
 2 stop bits *‍/
◆ set_vector()
rtems_isr_entry set_vector ( rtems_isr_entry  handler,
int  type
This method installs an interrupt handle.
Parameters
[in]handleris the isr routine
[in]vectoris the vector number
[in]typeindicates whether RTEMS or RAW intr
Returns
returns old vector
Parameters
Returns
returns old vector
