RTEMS 6.1
Typedefs | Enumerations | Functions
typedef enum ALT_RESET_EVENT_e ALT_RESET_EVENT_t
enum  ALT_RESET_EVENT_e {
  ALT_RESET_EVENT_PORVOLTRST = 0x00000001 , ALT_RESET_EVENT_NPORPINRST = 0x00000002 , ALT_RESET_EVENT_FPGACOLDRST = 0x00000004 , ALT_RESET_EVENT_CONFIGIOCOLDRST = 0x00000008 ,
  ALT_RESET_EVENT_SWCOLDRST = 0x00000010 , ALT_RESET_EVENT_NRSTPINRST = 0x00000100 , ALT_RESET_EVENT_FPGAWARMRST = 0x00000200 , ALT_RESET_EVENT_SWWARMRST = 0x00000400 ,
  ALT_RESET_EVENT_MPUWD0RST = 0x00001000 , ALT_RESET_EVENT_MPUWD1RST = 0x00002000 , ALT_RESET_EVENT_L4WD0RST = 0x00004000 , ALT_RESET_EVENT_L4WD1RST = 0x00008000 ,
  ALT_RESET_EVENT_FPGADBGRST = 0x00040000 , ALT_RESET_EVENT_CDBGREQRST = 0x00080000 , ALT_RESET_EVENT_SDRSELFREFTIMEOUT = 0x01000000 , ALT_RESET_EVENT_FPGAMGRHSTIMEOUT = 0x02000000 ,
  ALT_RESET_EVENT_SCANHSTIMEOUT = 0x04000000 , ALT_RESET_EVENT_FPGAHSTIMEOUT = 0x08000000 , ALT_RESET_EVENT_ETRSTALLTIMEOUT = 0x10000000
uint32_t alt_reset_event_get (void)
ALT_STATUS_CODE alt_reset_event_clear (uint32_t event_mask)
This functional group provides information on various aspects of SoC reset status and timeout events.
Typedef Documentation
◆ ALT_RESET_EVENT_t
This type definition enumerates the set of reset causes and timeout events as register mask values.
◆ ALT_RESET_EVENT_e
Power-On Voltage Detector Cold Reset
nPOR Pin Cold Reset
FPGA Core Cold Reset
CONFIG_IO Cold Reset
Software Cold Reset
nRST Pin Warm Reset
FPGA Core Warm Reset
Software Warm Reset
MPU Watchdog 0 Warm Reset
MPU Watchdog 1 Warm Reset
L4 Watchdog 0 Warm Reset
L4 Watchdog 1 Warm Reset
FPGA Core Debug Reset
DAP Debug Reset
SDRAM Self-Refresh Timeout
FPGA manager handshake Timeout
SCAN manager handshake Timeout
FPGA handshake Timeout
ETR Stall Timeout
◆ alt_reset_event_clear()
ALT_STATUS_CODE alt_reset_event_clear ( uint32_t  event_mask)
Clears the reset and timeout events that caused the last reset.
Parameters
event_maskA mask of the selected reset and timeout events to clear in the Reset Manager stat register. The mask selection can be formed using the ALT_RESET_EVENT_t enumeration values.
Return values
ALT_E_SUCCESSThe operation was succesful.
ALT_E_ERRORThe operation failed.
◆ alt_reset_event_get()
uint32_t alt_reset_event_get ( void  )
Gets the reset and timeout events that caused the last reset.
The ALT_RESET_EVENT_t enumeration values should be used to selectively examine the returned reset cause(s).
Returns
A mask of the reset and/or timeout events that caused the last reset.
