RTEMS 6.1
#define __HAL_RCC_MCO1_CONFIG(__MCOCLKSOURCE__, __MCODIV__)    MODIFY_REG(RCC->CFGR, (RCC_CFGR_MCO1 | RCC_CFGR_MCO1PRE), ((__MCOCLKSOURCE__) | (__MCODIV__)))
 Macro to configure the MCO1 clock.
#define __HAL_RCC_MCO2_CONFIG(__MCOCLKSOURCE__, __MCODIV__)    MODIFY_REG(RCC->CFGR, (RCC_CFGR_MCO2 | RCC_CFGR_MCO2PRE), ((__MCOCLKSOURCE__) | ((__MCODIV__) << 7)));
 Macro to configure the MCO2 clock.
◆ __HAL_RCC_MCO1_CONFIG
#define __HAL_RCC_MCO1_CONFIG (   __MCOCLKSOURCE__,
  __MCODIV__
Parameters
__MCOCLKSOURCE__specifies the MCO clock source. This parameter can be one of the following values:
  • RCC_MCO1SOURCE_HSI: HSI clock selected as MCO1 source
  • RCC_MCO1SOURCE_LSE: LSE clock selected as MCO1 source
  • RCC_MCO1SOURCE_HSE: HSE clock selected as MCO1 source
  • RCC_MCO1SOURCE_PLL1QCLK: PLL1Q clock selected as MCO1 source
  • RCC_MCO1SOURCE_HSI48: HSI48 (48MHZ) selected as MCO1 source
__MCODIV__specifies the MCO clock prescaler. This parameter can be one of the following values:
  • RCC_MCODIV_1 up to RCC_MCODIV_15 : divider applied to MCO1 clock
◆ __HAL_RCC_MCO2_CONFIG
#define __HAL_RCC_MCO2_CONFIG (   __MCOCLKSOURCE__,
  __MCODIV__
Parameters
  • RCC_MCO2SOURCE_SYSCLK: System clock (SYSCLK) selected as MCO2 source
  • RCC_MCO2SOURCE_PLL2PCLK: PLL2P clock selected as MCO2 source
  • RCC_MCO2SOURCE_HSE: HSE clock selected as MCO2 source
  • RCC_MCO2SOURCE_PLLCLK: PLL1P clock selected as MCO2 source
  • RCC_MCO2SOURCE_CSICLK: CSI clock selected as MCO2 source
  • RCC_MCO2SOURCE_LSICLK: LSI clock selected as MCO2 source
  • RCC_MCODIV_1 up to RCC_MCODIV_15 : divider applied to MCO2 clock
