RTEMS 6.1
| #define | IS_PWR_SUPPLY(PWR_SOURCE) |
| #define | IS_PWR_STOP_MODE_REGULATOR_VOLTAGE(VOLTAGE) |
| #define | IS_PWR_DOMAIN(DOMAIN) |
| #define | IS_D3_STATE(STATE) |
| #define | IS_PWR_WAKEUP_PIN(PIN) |
| #define | IS_PWR_WAKEUP_PIN_POLARITY(POLARITY) |
| #define | IS_PWR_WAKEUP_PIN_PULL(PULL) |
| #define | IS_PWR_WAKEUP_FLAG(FLAG) |
| #define | IS_PWR_AVD_LEVEL(LEVEL) |
| #define | IS_PWR_AVD_MODE(MODE) |
| #define | IS_PWR_BATTERY_RESISTOR_SELECT(RESISTOR) |
| #define | IS_PWR_D1_CPU(CPU) ((CPU) == CM7_CPUID) |
| #define IS_D3_STATE | ( | STATE | ) |
| #define IS_PWR_AVD_LEVEL | ( | LEVEL | ) |
| #define IS_PWR_AVD_MODE | ( | MODE | ) |
| #define IS_PWR_BATTERY_RESISTOR_SELECT | ( | RESISTOR | ) |
| #define IS_PWR_DOMAIN | ( | DOMAIN | ) |
| #define IS_PWR_STOP_MODE_REGULATOR_VOLTAGE | ( | VOLTAGE | ) |
| #define IS_PWR_SUPPLY | ( | PWR_SOURCE | ) |
| #define IS_PWR_WAKEUP_FLAG | ( | FLAG | ) |
| #define IS_PWR_WAKEUP_PIN | ( | PIN | ) |
| #define IS_PWR_WAKEUP_PIN_POLARITY | ( | POLARITY | ) |
| #define IS_PWR_WAKEUP_PIN_PULL | ( | PULL | ) |
