RTEMS 6.1
| #define | __HAL_PWR_AVD_EXTI_ENABLE_IT() SET_BIT(EXTI->IMR1, PWR_EXTI_LINE_AVD) |
| Enable the AVD EXTI Line 16. | |
| #define | __HAL_PWR_AVD_EXTI_DISABLE_IT() CLEAR_BIT(EXTI->IMR1, PWR_EXTI_LINE_AVD) |
| Disable the AVD EXTI Line 16. | |
| #define | __HAL_PWR_AVD_EXTI_ENABLE_EVENT() SET_BIT(EXTI->EMR1, PWR_EXTI_LINE_AVD) |
| Enable event on AVD EXTI Line 16. | |
| #define | __HAL_PWR_AVD_EXTI_DISABLE_EVENT() CLEAR_BIT(EXTI->EMR1, PWR_EXTI_LINE_AVD) |
| Disable event on AVD EXTI Line 16. | |
| #define | __HAL_PWR_AVD_EXTI_ENABLE_RISING_EDGE() SET_BIT(EXTI->RTSR1, PWR_EXTI_LINE_AVD) |
| Enable the AVD Extended Interrupt Rising Trigger. | |
| #define | __HAL_PWR_AVD_EXTI_DISABLE_RISING_EDGE() CLEAR_BIT(EXTI->RTSR1, PWR_EXTI_LINE_AVD) |
| Disable the AVD Extended Interrupt Rising Trigger. | |
| #define | __HAL_PWR_AVD_EXTI_ENABLE_FALLING_EDGE() SET_BIT(EXTI->FTSR1, PWR_EXTI_LINE_AVD) |
| Enable the AVD Extended Interrupt Falling Trigger. | |
| #define | __HAL_PWR_AVD_EXTI_DISABLE_FALLING_EDGE() CLEAR_BIT(EXTI->FTSR1, PWR_EXTI_LINE_AVD) |
| Disable the AVD Extended Interrupt Falling Trigger. | |
| #define | __HAL_PWR_AVD_EXTI_ENABLE_RISING_FALLING_EDGE() |
| Enable the AVD Extended Interrupt Rising and Falling Trigger. | |
| #define | __HAL_PWR_AVD_EXTI_DISABLE_RISING_FALLING_EDGE() |
| Disable the AVD Extended Interrupt Rising & Falling Trigger. | |
| #define | __HAL_PWR_AVD_EXTI_GET_FLAG() ((READ_BIT(EXTI->PR1, PWR_EXTI_LINE_AVD) == PWR_EXTI_LINE_AVD) ? 1UL : 0UL) |
| Check whether the specified AVD EXTI interrupt flag is set or not. | |
| #define | __HAL_PWR_AVD_EXTI_CLEAR_FLAG() SET_BIT(EXTI->PR1, PWR_EXTI_LINE_AVD) |
| Clear the AVD EXTI flag. | |
| #define | __HAL_PWR_AVD_EXTI_GENERATE_SWIT() SET_BIT(EXTI->SWIER1, PWR_EXTI_LINE_AVD) |
| Generates a Software interrupt on AVD EXTI line. | |
| #define __HAL_PWR_AVD_EXTI_CLEAR_FLAG | ( | ) | SET_BIT(EXTI->PR1, PWR_EXTI_LINE_AVD) |
| None. |
| #define __HAL_PWR_AVD_EXTI_DISABLE_EVENT | ( | ) | CLEAR_BIT(EXTI->EMR1, PWR_EXTI_LINE_AVD) |
| None. |
| #define __HAL_PWR_AVD_EXTI_DISABLE_FALLING_EDGE | ( | ) | CLEAR_BIT(EXTI->FTSR1, PWR_EXTI_LINE_AVD) |
| None. |
| #define __HAL_PWR_AVD_EXTI_DISABLE_IT | ( | ) | CLEAR_BIT(EXTI->IMR1, PWR_EXTI_LINE_AVD) |
| None. |
| #define __HAL_PWR_AVD_EXTI_DISABLE_RISING_EDGE | ( | ) | CLEAR_BIT(EXTI->RTSR1, PWR_EXTI_LINE_AVD) |
| None. |
| #define __HAL_PWR_AVD_EXTI_DISABLE_RISING_FALLING_EDGE | ( | ) |
| None. |
| #define __HAL_PWR_AVD_EXTI_ENABLE_EVENT | ( | ) | SET_BIT(EXTI->EMR1, PWR_EXTI_LINE_AVD) |
| None. |
| #define __HAL_PWR_AVD_EXTI_ENABLE_FALLING_EDGE | ( | ) | SET_BIT(EXTI->FTSR1, PWR_EXTI_LINE_AVD) |
| None. |
| #define __HAL_PWR_AVD_EXTI_ENABLE_IT | ( | ) | SET_BIT(EXTI->IMR1, PWR_EXTI_LINE_AVD) |
| None. |
| #define __HAL_PWR_AVD_EXTI_ENABLE_RISING_EDGE | ( | ) | SET_BIT(EXTI->RTSR1, PWR_EXTI_LINE_AVD) |
| None. |
| #define __HAL_PWR_AVD_EXTI_ENABLE_RISING_FALLING_EDGE | ( | ) |
| None. |
| #define __HAL_PWR_AVD_EXTI_GENERATE_SWIT | ( | ) | SET_BIT(EXTI->SWIER1, PWR_EXTI_LINE_AVD) |
| None. |
| #define __HAL_PWR_AVD_EXTI_GET_FLAG | ( | ) | ((READ_BIT(EXTI->PR1, PWR_EXTI_LINE_AVD) == PWR_EXTI_LINE_AVD) ? 1UL : 0UL) |
| EXTI | AVD Line Status. |
