RTEMS 6.1
MDMA Error Codes. More...
| #define | HAL_MDMA_ERROR_NONE ((uint32_t)0x00000000U) |
| #define | HAL_MDMA_ERROR_READ_XFER ((uint32_t)0x00000001U) |
| #define | HAL_MDMA_ERROR_WRITE_XFER ((uint32_t)0x00000002U) |
| #define | HAL_MDMA_ERROR_MASK_DATA ((uint32_t)0x00000004U) |
| #define | HAL_MDMA_ERROR_LINKED_LIST ((uint32_t)0x00000008U) |
| #define | HAL_MDMA_ERROR_ALIGNMENT ((uint32_t)0x00000010U) |
| #define | HAL_MDMA_ERROR_BLOCK_SIZE ((uint32_t)0x00000020U) |
| #define | HAL_MDMA_ERROR_TIMEOUT ((uint32_t)0x00000040U) |
| #define | HAL_MDMA_ERROR_NO_XFER ((uint32_t)0x00000080U) |
| #define | HAL_MDMA_ERROR_BUSY ((uint32_t)0x00000100U) |
MDMA Error Codes.
| #define HAL_MDMA_ERROR_ALIGNMENT ((uint32_t)0x00000010U) |
Address/Size alignment error
| #define HAL_MDMA_ERROR_BLOCK_SIZE ((uint32_t)0x00000020U) |
Block Size error
| #define HAL_MDMA_ERROR_BUSY ((uint32_t)0x00000100U) |
DeInit or SW trigger requested with Xfer ongoing
| #define HAL_MDMA_ERROR_LINKED_LIST ((uint32_t)0x00000008U) |
Linked list Data error
| #define HAL_MDMA_ERROR_MASK_DATA ((uint32_t)0x00000004U) |
Error Mask Data error
| #define HAL_MDMA_ERROR_NO_XFER ((uint32_t)0x00000080U) |
Abort or SW trigger requested with no Xfer ongoing
| #define HAL_MDMA_ERROR_NONE ((uint32_t)0x00000000U) |
No error
| #define HAL_MDMA_ERROR_READ_XFER ((uint32_t)0x00000001U) |
Read Transfer error
| #define HAL_MDMA_ERROR_TIMEOUT ((uint32_t)0x00000040U) |
Timeout error
| #define HAL_MDMA_ERROR_WRITE_XFER ((uint32_t)0x00000002U) |
Write Transfer error
