RTEMS 6.1
Mount options for the Journalling Flash File System, Version 2 (JFFS2). More...
| struct | rtems_jffs2_flash_control |
| JFFS2 flash device control. More... | |
| struct | rtems_jffs2_compressor_control |
| JFFS2 compressor control. More... | |
| struct | rtems_jffs2_compressor_zlib_control |
| ZLIB compressor control structure. More... | |
| struct | rtems_jffs2_mount_data |
| JFFS2 mount options. More... | |
| struct | rtems_jffs2_info |
| JFFS2 filesystem instance information. More... | |
| struct | rtems_jffs2_config |
| #define | RTEMS_JFFS2_GET_INFO _IOR('F', 1, rtems_jffs2_info) |
| IO control to get the JFFS2 filesystem instance information. | |
| #define | RTEMS_JFFS2_ON_DEMAND_GARBAGE_COLLECTION _IO('F', 2) |
| IO control to perform an on demand garbage collection in a JFFS2 filesystem instance. | |
| #define | RTEMS_JFFS2_FORCE_GARBAGE_COLLECTION _IO('F', 3) |
| IO control to force a garbage collection in a JFFS2 filesystem instance. | |
| #define | RTEMS_JFFS2_DELAYED_WRITE_TASK_PRIORITY_DEFAULT 15 |
Typedefs | |
| typedef int(* | rtems_jffs2_flash_read) (rtems_jffs2_flash_control *self, uint32_t offset, unsigned char *buffer, size_t size_of_buffer) |
| Read from flash operation. | |
| typedef int(* | rtems_jffs2_flash_write) (rtems_jffs2_flash_control *self, uint32_t offset, const unsigned char *buffer, size_t size_of_buffer) |
| Write to flash operation. | |
| typedef int(* | rtems_jffs2_flash_erase) (rtems_jffs2_flash_control *self, uint32_t offset) |
| Flash erase operation. | |
| typedef int(* | rtems_jffs2_flash_block_is_bad) (rtems_jffs2_flash_control *self, uint32_t offset, bool *bad) |
| Flash bad block check operation. | |
| typedef int(* | rtems_jffs2_flash_block_mark_bad) (rtems_jffs2_flash_control *self, uint32_t offset) |
| Flash bad block mark operation. | |
| typedef int(* | rtems_jffs2_flash_oob_write) (rtems_jffs2_flash_control *self, uint32_t offset, uint8_t *oobbuf, uint32_t obblen) |
| Flash oob write. | |
| typedef int(* | rtems_jffs2_flash_oob_read) (rtems_jffs2_flash_control *self, uint32_t offset, uint8_t *oobbuf, uint32_t obblen) |
| Flash oob read. | |
| typedef uint32_t(* | rtems_jffs2_flash_get_oob_size) (rtems_jffs2_flash_control *self) |
| Flash get oob size. | |
| typedef void(* | rtems_jffs2_flash_destroy) (rtems_jffs2_flash_control *self) |
| Flash destroy operation. | |
| typedef void(* | rtems_jffs2_trigger_garbage_collection) (rtems_jffs2_flash_control *self) |
| Trigger garbage collection operation. | |
| typedef struct rtems_jffs2_compressor_control | rtems_jffs2_compressor_control |
| typedef uint16_t(* | rtems_jffs2_compressor_compress) (rtems_jffs2_compressor_control *self, unsigned char *data_in, unsigned char *cdata_out, uint32_t *datalen, uint32_t *cdatalen) |
| Compress operation. | |
| typedef int(* | rtems_jffs2_compressor_decompress) (rtems_jffs2_compressor_control *self, uint16_t comprtype, unsigned char *cdata_in, unsigned char *data_out, uint32_t cdatalen, uint32_t datalen) |
| Decompress operation. | |
| typedef void(* | rtems_jffs2_compressor_destroy) (rtems_jffs2_compressor_control *self) |
| Compressor destroy operation. | |
| typedef struct rtems_jffs2_config | rtems_jffs2_config |
| uint16_t | rtems_jffs2_compressor_rtime_compress (rtems_jffs2_compressor_control *self, unsigned char *data_in, unsigned char *cdata_out, uint32_t *datalen, uint32_t *cdatalen) |
| RTIME compressor compress operation. | |
| int | rtems_jffs2_compressor_rtime_decompress (rtems_jffs2_compressor_control *self, uint16_t comprtype, unsigned char *cdata_in, unsigned char *data_out, uint32_t cdatalen, uint32_t datalen) |
| RTIME compressor decompress operation. | |
| uint16_t | rtems_jffs2_compressor_zlib_compress (rtems_jffs2_compressor_control *self, unsigned char *data_in, unsigned char *cdata_out, uint32_t *datalen, uint32_t *cdatalen) |
| ZLIB compressor compress operation. | |
| int | rtems_jffs2_compressor_zlib_decompress (rtems_jffs2_compressor_control *self, uint16_t comprtype, unsigned char *cdata_in, unsigned char *data_out, uint32_t cdatalen, uint32_t datalen) |
| ZLIB compressor decompress operation. | |
| int | rtems_jffs2_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data) |
| Initialization handler of the JFFS2 file system. | |
| const rtems_jffs2_config | jffs2_config |
The application must provide flash device geometry information and flash device operations in the flash control structure rtems_jffs2_flash_control.
The application can optionally provide a compressor control structure to enable data compression using the selected compression algorithm.
The application must enable JFFS2 support with rtems_filesystem_register() or CONFIGURE_FILESYSTEM_JFFS2 via <rtems/confdefs.h>.
An example mount with a simple memory based flash device simulation follows. The zlib is used for as the compressor.
| #define RTEMS_JFFS2_DELAYED_WRITE_TASK_PRIORITY_DEFAULT 15 |
Default delayed-write servicing task priority.
| #define RTEMS_JFFS2_FORCE_GARBAGE_COLLECTION _IO('F', 3) |
Use this operation with care since it may wear out your flash.
| #define RTEMS_JFFS2_GET_INFO _IOR('F', 1, rtems_jffs2_info) |
| #define RTEMS_JFFS2_ON_DEMAND_GARBAGE_COLLECTION _IO('F', 2) |
This operation is intended to be used by an optional garbage collection thread. See rtems_jffs2_flash_control::trigger_garbage_collection.
| typedef uint16_t(* rtems_jffs2_compressor_compress) (rtems_jffs2_compressor_control *self, unsigned char *data_in, unsigned char *cdata_out, uint32_t *datalen, uint32_t *cdatalen) |
Compress operation.
| [in,out] | self | The compressor control. |
| [in] | data_in | The uncompressed data. |
| [out] | cdata_out | Pointer to buffer with the compressed data. |
| [in,out] | datalen | On entry, the size in bytes of the uncompressed data. On exit, the size in bytes of uncompressed data which was actually compressed. |
| [in,out] | cdatalen | On entry, the size in bytes available for compressed data. On exit, the size in bytes of the actually compressed data. |
| typedef int(* rtems_jffs2_compressor_decompress) (rtems_jffs2_compressor_control *self, uint16_t comprtype, unsigned char *cdata_in, unsigned char *data_out, uint32_t cdatalen, uint32_t datalen) |
| [in] | comprtype | The compressor type. |
| [in] | cdata_in | The compressed data. |
| [out] | data_out | The uncompressed data. |
| [in] | cdatalen | The size in bytes of the compressed data. |
| [in] | datalen | The size in bytes of the uncompressed data. |
| 0 | Successful operation. |
| -EIO | An error occurred. Please note that the value is negative. |
| other | All other values are reserved and must not be used. |
| typedef void(* rtems_jffs2_compressor_destroy) (rtems_jffs2_compressor_control *self) |
The compressor destroy operation is called during unmount of the file system instance. It can be used to free the resources associated with the now unused compressor operations.
| typedef struct rtems_jffs2_config rtems_jffs2_config |
JFFS2 configuration definition. See confdefs.h for support on using this structure.
| typedef int(* rtems_jffs2_flash_block_is_bad) (rtems_jffs2_flash_control *self, uint32_t offset, bool *bad) |
This operation checks whether a block is bad.
| [in,out] | self | The flash control. |
| [in] | offset | The offset in bytes of the block to check. |
| [out] | The | result of the bad block check. |
| typedef int(* rtems_jffs2_flash_block_mark_bad) (rtems_jffs2_flash_control *self, uint32_t offset) |
This operation marks a block bad.
| [in] | offset | The offset in bytes of the block to mark bad. |
| typedef void(* rtems_jffs2_flash_destroy) (rtems_jffs2_flash_control *self) |
The flash destroy operation is called during unmount of the file system instance. It can be used to free the resources associated with the now unused flash control
| typedef int(* rtems_jffs2_flash_erase) (rtems_jffs2_flash_control *self, uint32_t offset) |
This operation must erase one block specified by the offset.
| [in] | offset | The offset to erase from the flash begin in bytes. |
| typedef uint32_t(* rtems_jffs2_flash_get_oob_size) (rtems_jffs2_flash_control *self) |
Flash get oob size.
This operation gets the size of the out-of-band/spare bytes for each page.
| The | size of the OOB/spare area available to each page |
| typedef int(* rtems_jffs2_flash_oob_read) (rtems_jffs2_flash_control *self, uint32_t offset, uint8_t *oobbuf, uint32_t obblen) |
Flash oob read.
This operation reads the out-of-band/spare bytes for the block matching the given offset in bytes.
| [out] | pointer | to the buffer which will have the oob/spare bytes data written to it. |
| [in] | length | of the buffer which will hold the oob/spare bytes. |
| typedef int(* rtems_jffs2_flash_oob_write) (rtems_jffs2_flash_control *self, uint32_t offset, uint8_t *oobbuf, uint32_t obblen) |
Flash oob write.
This operation writes the out-of-band/spare bytes for the block matching the given offset in bytes.
| [in] | pointer | to the buffer which will be written to the oob/spare bytes. |
| [in] | length | of the buffer which will be written to the oob/spare bytes. |
| typedef int(* rtems_jffs2_flash_read) (rtems_jffs2_flash_control *self, uint32_t offset, unsigned char *buffer, size_t size_of_buffer) |
| [in] | offset | The offset to read from the flash begin in bytes. |
| [out] | buffer | The buffer receiving the data. |
| [in] | size_of_buffer | The size of the buffer in bytes. |
| typedef int(* rtems_jffs2_flash_write) (rtems_jffs2_flash_control *self, uint32_t offset, const unsigned char *buffer, size_t size_of_buffer) |
| [in] | offset | The offset to write from the flash begin in bytes. |
| [in] | buffer | The buffer containing the data to write. |
| typedef void(* rtems_jffs2_trigger_garbage_collection) (rtems_jffs2_flash_control *self) |
An optional garbage collection thread may perform now a garbage collection using the RTEMS_JFFS2_ON_DEMAND_GARBAGE_COLLECTION IO control.
The garbage collection must not run in the executing context.
| [in] | self | The flash control. |
| int rtems_jffs2_initialize | ( | rtems_filesystem_mount_table_entry_t * | mt_entry, |
| const void * | data | ||
| [in,out] | mt_entry | The mount table entry. |
| [in] | data | The mount options are mandatory for JFFS2 and data must point to a valid rtems_jffs2_mount_data structure used for this file system instance. |
| -1 | An error occurred. The errno indicates the error. |
extern |
External reference to the configuration.
The configuration is provided by the application.
