RTEMS 6.1
| #define | IWDG_ENABLE_WRITE_ACCESS(__HANDLE__) WRITE_REG((__HANDLE__)->Instance->KR, IWDG_KEY_WRITE_ACCESS_ENABLE) |
| Enable write access to IWDG_PR, IWDG_RLR and IWDG_WINR registers. | |
| #define | IWDG_DISABLE_WRITE_ACCESS(__HANDLE__) WRITE_REG((__HANDLE__)->Instance->KR, IWDG_KEY_WRITE_ACCESS_DISABLE) |
| Disable write access to IWDG_PR, IWDG_RLR and IWDG_WINR registers. | |
| #define | IS_IWDG_PRESCALER(__PRESCALER__) |
| Check IWDG prescaler value. | |
| #define | IS_IWDG_RELOAD(__RELOAD__) ((__RELOAD__) <= IWDG_RLR_RL) |
| Check IWDG reload value. | |
| #define | IS_IWDG_WINDOW(__WINDOW__) ((__WINDOW__) <= IWDG_WINR_WIN) |
| Check IWDG window value. | |
| #define IS_IWDG_PRESCALER | ( | __PRESCALER__ | ) |
| __PRESCALER__ | IWDG prescaler value |
| None |
| #define IS_IWDG_RELOAD | ( | __RELOAD__ | ) | ((__RELOAD__) <= IWDG_RLR_RL) |
| __RELOAD__ | IWDG reload value |
| None |
| #define IS_IWDG_WINDOW | ( | __WINDOW__ | ) | ((__WINDOW__) <= IWDG_WINR_WIN) |
| __WINDOW__ | IWDG window value |
| None |
| #define IWDG_DISABLE_WRITE_ACCESS | ( | __HANDLE__ | ) | WRITE_REG((__HANDLE__)->Instance->KR, IWDG_KEY_WRITE_ACCESS_DISABLE) |
| __HANDLE__ | IWDG handle |
| None |
| #define IWDG_ENABLE_WRITE_ACCESS | ( | __HANDLE__ | ) | WRITE_REG((__HANDLE__)->Instance->KR, IWDG_KEY_WRITE_ACCESS_ENABLE) |
| None |
