RTEMS 6.1
Modules | Macros
 FMC NAND Interrupt
 macros to handle NAND interrupts
 FMC NAND Macros
 macros to handle NAND device enable/disable
 FMC NOR/SRAM Macros
 macros to handle NOR device enable/disable and read/write operations
 FMC SDRAM Interrupt
 macros to handle SDRAM interrupts
#define IS_FMC_NORSRAM_BANK(__BANK__)
#define IS_FMC_MUX(__MUX__)
#define IS_FMC_MEMORY(__MEMORY__)
#define IS_FMC_NORSRAM_MEMORY_WIDTH(__WIDTH__)
#define IS_FMC_PAGESIZE(__SIZE__)
#define IS_FMC_WRITE_FIFO(__FIFO__)
#define IS_FMC_ACCESS_MODE(__MODE__)
#define IS_FMC_BURSTMODE(__STATE__)
#define IS_FMC_WAIT_POLARITY(__POLARITY__)
#define IS_FMC_WAIT_SIGNAL_ACTIVE(__ACTIVE__)
#define IS_FMC_WRITE_OPERATION(__OPERATION__)
#define IS_FMC_WAITE_SIGNAL(__SIGNAL__)
#define IS_FMC_EXTENDED_MODE(__MODE__)
#define IS_FMC_ASYNWAIT(__STATE__)
#define IS_FMC_DATA_LATENCY(__LATENCY__)   (((__LATENCY__) > 1U) && ((__LATENCY__) <= 17U))
#define IS_FMC_WRITE_BURST(__BURST__)
#define IS_FMC_CONTINOUS_CLOCK(__CCLOCK__)
#define IS_FMC_ADDRESS_SETUP_TIME(__TIME__)   ((__TIME__) <= 15U)
#define IS_FMC_ADDRESS_HOLD_TIME(__TIME__)   (((__TIME__) > 0U) && ((__TIME__) <= 15U))
#define IS_FMC_DATASETUP_TIME(__TIME__)   (((__TIME__) > 0U) && ((__TIME__) <= 255U))
#define IS_FMC_DATAHOLD_DURATION(__DATAHOLD__)   ((__DATAHOLD__) <= 3U)
#define IS_FMC_TURNAROUND_TIME(__TIME__)   ((__TIME__) <= 15U)
#define IS_FMC_CLK_DIV(__DIV__)   (((__DIV__) > 1U) && ((__DIV__) <= 16U))
#define IS_FMC_NORSRAM_DEVICE(__INSTANCE__)   ((__INSTANCE__) == FMC_NORSRAM_DEVICE)
#define IS_FMC_NORSRAM_EXTENDED_DEVICE(__INSTANCE__)   ((__INSTANCE__) == FMC_NORSRAM_EXTENDED_DEVICE)
#define IS_FMC_NAND_BANK(__BANK__)   ((__BANK__) == FMC_NAND_BANK3)
#define IS_FMC_WAIT_FEATURE(__FEATURE__)
#define IS_FMC_NAND_MEMORY_WIDTH(__WIDTH__)
#define IS_FMC_ECC_STATE(__STATE__)
#define IS_FMC_ECCPAGE_SIZE(__SIZE__)
#define IS_FMC_TCLR_TIME(__TIME__)   ((__TIME__) <= 255U)
#define IS_FMC_TAR_TIME(__TIME__)   ((__TIME__) <= 255U)
#define IS_FMC_SETUP_TIME(__TIME__)   ((__TIME__) <= 254U)
#define IS_FMC_WAIT_TIME(__TIME__)   ((__TIME__) <= 254U)
#define IS_FMC_HOLD_TIME(__TIME__)   ((__TIME__) <= 254U)
#define IS_FMC_HIZ_TIME(__TIME__)   ((__TIME__) <= 254U)
#define IS_FMC_NAND_DEVICE(__INSTANCE__)   ((__INSTANCE__) == FMC_NAND_DEVICE)
#define IS_FMC_SDMEMORY_WIDTH(__WIDTH__)
#define IS_FMC_WRITE_PROTECTION(__WRITE__)
#define IS_FMC_SDCLOCK_PERIOD(__PERIOD__)
#define IS_FMC_READ_BURST(__RBURST__)
#define IS_FMC_READPIPE_DELAY(__DELAY__)
#define IS_FMC_COMMAND_MODE(__COMMAND__)
#define IS_FMC_COMMAND_TARGET(__TARGET__)
#define IS_FMC_LOADTOACTIVE_DELAY(__DELAY__)   (((__DELAY__) > 0U) && ((__DELAY__) <= 16U))
#define IS_FMC_EXITSELFREFRESH_DELAY(__DELAY__)   (((__DELAY__) > 0U) && ((__DELAY__) <= 16U))
#define IS_FMC_SELFREFRESH_TIME(__TIME__)   (((__TIME__) > 0U) && ((__TIME__) <= 16U))
#define IS_FMC_ROWCYCLE_DELAY(__DELAY__)   (((__DELAY__) > 0U) && ((__DELAY__) <= 16U))
#define IS_FMC_WRITE_RECOVERY_TIME(__TIME__)   (((__TIME__) > 0U) && ((__TIME__) <= 16U))
#define IS_FMC_RP_DELAY(__DELAY__)   (((__DELAY__) > 0U) && ((__DELAY__) <= 16U))
#define IS_FMC_RCD_DELAY(__DELAY__)   (((__DELAY__) > 0U) && ((__DELAY__) <= 16U))
#define IS_FMC_AUTOREFRESH_NUMBER(__NUMBER__)   (((__NUMBER__) > 0U) && ((__NUMBER__) <= 15U))
#define IS_FMC_MODE_REGISTER(__CONTENT__)   ((__CONTENT__) <= 8191U)
#define IS_FMC_REFRESH_RATE(__RATE__)   ((__RATE__) <= 8191U)
#define IS_FMC_SDRAM_DEVICE(__INSTANCE__)   ((__INSTANCE__) == FMC_SDRAM_DEVICE)
#define IS_FMC_SDRAM_BANK(__BANK__)
#define IS_FMC_COLUMNBITS_NUMBER(__COLUMN__)
#define IS_FMC_ROWBITS_NUMBER(__ROW__)
#define IS_FMC_INTERNALBANK_NUMBER(__NUMBER__)
#define IS_FMC_CAS_LATENCY(__LATENCY__)
#define __FMC_ENABLE()   (FMC_Bank1_R->BTCR[0] |= FMC_BCR1_FMCEN)
 Enable the FMC Peripheral.
#define __FMC_DISABLE()   (FMC_Bank1_R->BTCR[0] &= ~FMC_BCR1_FMCEN)
 Disable the FMC Peripheral.
◆ __FMC_DISABLE
#define __FMC_DISABLE ( )    (FMC_Bank1_R->BTCR[0] &= ~FMC_BCR1_FMCEN)
Return values
None
◆ __FMC_ENABLE
#define __FMC_ENABLE ( )    (FMC_Bank1_R->BTCR[0] |= FMC_BCR1_FMCEN)
Return values
None
◆ IS_FMC_ACCESS_MODE
#define IS_FMC_ACCESS_MODE (   __MODE__)
Value:
(((__MODE__) == FMC_ACCESS_MODE_A) || \
((__MODE__) == FMC_ACCESS_MODE_B) || \
((__MODE__) == FMC_ACCESS_MODE_C) || \
((__MODE__) == FMC_ACCESS_MODE_D))
◆ IS_FMC_ASYNWAIT
#define IS_FMC_ASYNWAIT (   __STATE__)
Value:
(((__STATE__) == FMC_ASYNCHRONOUS_WAIT_DISABLE) || \
((__STATE__) == FMC_ASYNCHRONOUS_WAIT_ENABLE))
◆ IS_FMC_BURSTMODE
#define IS_FMC_BURSTMODE (   __STATE__)
Value:
(((__STATE__) == FMC_BURST_ACCESS_MODE_DISABLE) || \
((__STATE__) == FMC_BURST_ACCESS_MODE_ENABLE))
◆ IS_FMC_CAS_LATENCY
#define IS_FMC_CAS_LATENCY (   __LATENCY__)
Value:
(((__LATENCY__) == FMC_SDRAM_CAS_LATENCY_1) || \
((__LATENCY__) == FMC_SDRAM_CAS_LATENCY_2) || \
((__LATENCY__) == FMC_SDRAM_CAS_LATENCY_3))
◆ IS_FMC_COLUMNBITS_NUMBER
#define IS_FMC_COLUMNBITS_NUMBER (   __COLUMN__)
Value:
(((__COLUMN__) == FMC_SDRAM_COLUMN_BITS_NUM_8) || \
((__COLUMN__) == FMC_SDRAM_COLUMN_BITS_NUM_9) || \
((__COLUMN__) == FMC_SDRAM_COLUMN_BITS_NUM_10) || \
((__COLUMN__) == FMC_SDRAM_COLUMN_BITS_NUM_11))
◆ IS_FMC_COMMAND_MODE
#define IS_FMC_COMMAND_MODE (   __COMMAND__)
Value:
(((__COMMAND__) == FMC_SDRAM_CMD_NORMAL_MODE) || \
((__COMMAND__) == FMC_SDRAM_CMD_CLK_ENABLE) || \
((__COMMAND__) == FMC_SDRAM_CMD_PALL) || \
((__COMMAND__) == FMC_SDRAM_CMD_AUTOREFRESH_MODE) || \
((__COMMAND__) == FMC_SDRAM_CMD_LOAD_MODE) || \
((__COMMAND__) == FMC_SDRAM_CMD_SELFREFRESH_MODE) || \
((__COMMAND__) == FMC_SDRAM_CMD_POWERDOWN_MODE))
◆ IS_FMC_COMMAND_TARGET
#define IS_FMC_COMMAND_TARGET (   __TARGET__)
Value:
(((__TARGET__) == FMC_SDRAM_CMD_TARGET_BANK1) || \
((__TARGET__) == FMC_SDRAM_CMD_TARGET_BANK2) || \
((__TARGET__) == FMC_SDRAM_CMD_TARGET_BANK1_2))
◆ IS_FMC_CONTINOUS_CLOCK
#define IS_FMC_CONTINOUS_CLOCK (   __CCLOCK__)
Value:
(((__CCLOCK__) == FMC_CONTINUOUS_CLOCK_SYNC_ONLY) || \
((__CCLOCK__) == FMC_CONTINUOUS_CLOCK_SYNC_ASYNC))
◆ IS_FMC_ECC_STATE
#define IS_FMC_ECC_STATE (   __STATE__)
Value:
(((__STATE__) == FMC_NAND_ECC_DISABLE) || \
((__STATE__) == FMC_NAND_ECC_ENABLE))
◆ IS_FMC_ECCPAGE_SIZE
#define IS_FMC_ECCPAGE_SIZE (   __SIZE__)
Value:
(((__SIZE__) == FMC_NAND_ECC_PAGE_SIZE_256BYTE) || \
((__SIZE__) == FMC_NAND_ECC_PAGE_SIZE_512BYTE) || \
((__SIZE__) == FMC_NAND_ECC_PAGE_SIZE_1024BYTE) || \
((__SIZE__) == FMC_NAND_ECC_PAGE_SIZE_2048BYTE) || \
((__SIZE__) == FMC_NAND_ECC_PAGE_SIZE_4096BYTE) || \
((__SIZE__) == FMC_NAND_ECC_PAGE_SIZE_8192BYTE))
◆ IS_FMC_EXTENDED_MODE
#define IS_FMC_EXTENDED_MODE (   __MODE__)
Value:
(((__MODE__) == FMC_EXTENDED_MODE_DISABLE) || \
((__MODE__) == FMC_EXTENDED_MODE_ENABLE))
◆ IS_FMC_INTERNALBANK_NUMBER
#define IS_FMC_INTERNALBANK_NUMBER (   __NUMBER__)
Value:
(((__NUMBER__) == FMC_SDRAM_INTERN_BANKS_NUM_2) || \
((__NUMBER__) == FMC_SDRAM_INTERN_BANKS_NUM_4))
◆ IS_FMC_MEMORY
#define IS_FMC_MEMORY (   __MEMORY__)
Value:
(((__MEMORY__) == FMC_MEMORY_TYPE_SRAM) || \
((__MEMORY__) == FMC_MEMORY_TYPE_PSRAM)|| \
((__MEMORY__) == FMC_MEMORY_TYPE_NOR))
◆ IS_FMC_MUX
#define IS_FMC_MUX (   __MUX__)
Value:
(((__MUX__) == FMC_DATA_ADDRESS_MUX_DISABLE) || \
((__MUX__) == FMC_DATA_ADDRESS_MUX_ENABLE))
◆ IS_FMC_NAND_MEMORY_WIDTH
#define IS_FMC_NAND_MEMORY_WIDTH (   __WIDTH__)
Value:
(((__WIDTH__) == FMC_NAND_MEM_BUS_WIDTH_8) || \
((__WIDTH__) == FMC_NAND_MEM_BUS_WIDTH_16))
◆ IS_FMC_NORSRAM_BANK
#define IS_FMC_NORSRAM_BANK (   __BANK__)
Value:
(((__BANK__) == FMC_NORSRAM_BANK1) || \
((__BANK__) == FMC_NORSRAM_BANK2) || \
((__BANK__) == FMC_NORSRAM_BANK3) || \
((__BANK__) == FMC_NORSRAM_BANK4))
◆ IS_FMC_NORSRAM_MEMORY_WIDTH
#define IS_FMC_NORSRAM_MEMORY_WIDTH (   __WIDTH__)
Value:
(((__WIDTH__) == FMC_NORSRAM_MEM_BUS_WIDTH_8) || \
((__WIDTH__) == FMC_NORSRAM_MEM_BUS_WIDTH_16) || \
((__WIDTH__) == FMC_NORSRAM_MEM_BUS_WIDTH_32))
◆ IS_FMC_PAGESIZE
#define IS_FMC_PAGESIZE (   __SIZE__)
Value:
(((__SIZE__) == FMC_PAGE_SIZE_NONE) || \
((__SIZE__) == FMC_PAGE_SIZE_128) || \
((__SIZE__) == FMC_PAGE_SIZE_256) || \
((__SIZE__) == FMC_PAGE_SIZE_512) || \
((__SIZE__) == FMC_PAGE_SIZE_1024))
◆ IS_FMC_READ_BURST
#define IS_FMC_READ_BURST (   __RBURST__)
Value:
(((__RBURST__) == FMC_SDRAM_RBURST_DISABLE) || \
((__RBURST__) == FMC_SDRAM_RBURST_ENABLE))
◆ IS_FMC_READPIPE_DELAY
#define IS_FMC_READPIPE_DELAY (   __DELAY__)
Value:
(((__DELAY__) == FMC_SDRAM_RPIPE_DELAY_0) || \
((__DELAY__) == FMC_SDRAM_RPIPE_DELAY_1) || \
((__DELAY__) == FMC_SDRAM_RPIPE_DELAY_2))
◆ IS_FMC_ROWBITS_NUMBER
#define IS_FMC_ROWBITS_NUMBER (   __ROW__)
Value:
(((__ROW__) == FMC_SDRAM_ROW_BITS_NUM_11) || \
((__ROW__) == FMC_SDRAM_ROW_BITS_NUM_12) || \
((__ROW__) == FMC_SDRAM_ROW_BITS_NUM_13))
◆ IS_FMC_SDCLOCK_PERIOD
#define IS_FMC_SDCLOCK_PERIOD (   __PERIOD__)
Value:
(((__PERIOD__) == FMC_SDRAM_CLOCK_DISABLE) || \
((__PERIOD__) == FMC_SDRAM_CLOCK_PERIOD_2) || \
((__PERIOD__) == FMC_SDRAM_CLOCK_PERIOD_3))
◆ IS_FMC_SDMEMORY_WIDTH
#define IS_FMC_SDMEMORY_WIDTH (   __WIDTH__)
Value:
(((__WIDTH__) == FMC_SDRAM_MEM_BUS_WIDTH_8) || \
((__WIDTH__) == FMC_SDRAM_MEM_BUS_WIDTH_16) || \
((__WIDTH__) == FMC_SDRAM_MEM_BUS_WIDTH_32))
◆ IS_FMC_SDRAM_BANK
#define IS_FMC_SDRAM_BANK (   __BANK__)
Value:
(((__BANK__) == FMC_SDRAM_BANK1) || \
((__BANK__) == FMC_SDRAM_BANK2))
◆ IS_FMC_WAIT_FEATURE
#define IS_FMC_WAIT_FEATURE (   __FEATURE__)
Value:
(((__FEATURE__) == FMC_NAND_WAIT_FEATURE_DISABLE) || \
((__FEATURE__) == FMC_NAND_WAIT_FEATURE_ENABLE))
◆ IS_FMC_WAIT_POLARITY
#define IS_FMC_WAIT_POLARITY (   __POLARITY__)
Value:
(((__POLARITY__) == FMC_WAIT_SIGNAL_POLARITY_LOW) || \
((__POLARITY__) == FMC_WAIT_SIGNAL_POLARITY_HIGH))
◆ IS_FMC_WAIT_SIGNAL_ACTIVE
#define IS_FMC_WAIT_SIGNAL_ACTIVE (   __ACTIVE__)
Value:
(((__ACTIVE__) == FMC_WAIT_TIMING_BEFORE_WS) || \
((__ACTIVE__) == FMC_WAIT_TIMING_DURING_WS))
◆ IS_FMC_WAITE_SIGNAL
#define IS_FMC_WAITE_SIGNAL (   __SIGNAL__)
Value:
(((__SIGNAL__) == FMC_WAIT_SIGNAL_DISABLE) || \
((__SIGNAL__) == FMC_WAIT_SIGNAL_ENABLE))
◆ IS_FMC_WRITE_BURST
#define IS_FMC_WRITE_BURST (   __BURST__)
Value:
(((__BURST__) == FMC_WRITE_BURST_DISABLE) || \
((__BURST__) == FMC_WRITE_BURST_ENABLE))
◆ IS_FMC_WRITE_FIFO
#define IS_FMC_WRITE_FIFO (   __FIFO__)
Value:
(((__FIFO__) == FMC_WRITE_FIFO_DISABLE) || \
((__FIFO__) == FMC_WRITE_FIFO_ENABLE))
◆ IS_FMC_WRITE_OPERATION
#define IS_FMC_WRITE_OPERATION (   __OPERATION__)
Value:
(((__OPERATION__) == FMC_WRITE_OPERATION_DISABLE) || \
((__OPERATION__) == FMC_WRITE_OPERATION_ENABLE))
◆ IS_FMC_WRITE_PROTECTION
#define IS_FMC_WRITE_PROTECTION (   __WRITE__)
Value:
(((__WRITE__) == FMC_SDRAM_WRITE_PROTECTION_DISABLE) || \
((__WRITE__) == FMC_SDRAM_WRITE_PROTECTION_ENABLE))
