RTEMS 6.1
#define FLASH_PROGRAMMING_DELAY_0   0x00000000U
#define FLASH_PROGRAMMING_DELAY_1   FLASH_ACR_WRHIGHFREQ_0
#define FLASH_PROGRAMMING_DELAY_2   FLASH_ACR_WRHIGHFREQ_1
#define FLASH_PROGRAMMING_DELAY_3   FLASH_ACR_WRHIGHFREQ
◆ FLASH_PROGRAMMING_DELAY_0
programming delay set for Flash running at 70 MHz or below
◆ FLASH_PROGRAMMING_DELAY_1
programming delay set for Flash running between 70 MHz and 185 MHz
◆ FLASH_PROGRAMMING_DELAY_2
programming delay set for Flash running between 185 MHz and 225 MHz
◆ FLASH_PROGRAMMING_DELAY_3
programming delay set for Flash at startup
