RTEMS 6.1
| #define | IS_FLASH_TYPEERASE(VALUE) |
| #define | IS_WRPSTATE(VALUE) |
| #define | IS_OPTIONBYTE(VALUE) |
| #define | IS_OB_BOOT_ADDRESS(ADDRESS) ((ADDRESS) <= 0x8013U) |
| #define | IS_OB_RDP_LEVEL(LEVEL) |
| #define | IS_OB_IWDG_SOURCE(SOURCE) (((SOURCE) == OB_IWDG_SW) || ((SOURCE) == OB_IWDG_HW)) |
| #define | IS_OB_STOP_SOURCE(SOURCE) (((SOURCE) == OB_STOP_NO_RST) || ((SOURCE) == OB_STOP_RST)) |
| #define | IS_OB_STDBY_SOURCE(SOURCE) (((SOURCE) == OB_STDBY_NO_RST) || ((SOURCE) == OB_STDBY_RST)) |
| #define | IS_OB_IWDG_STOP_FREEZE(FREEZE) (((FREEZE) == OB_IWDG_STOP_FREEZE) || ((FREEZE) == OB_IWDG_STOP_ACTIVE)) |
| #define | IS_OB_IWDG_STDBY_FREEZE(FREEZE) (((FREEZE) == OB_IWDG_STDBY_FREEZE) || ((FREEZE) == OB_IWDG_STDBY_ACTIVE)) |
| #define | IS_OB_BOR_LEVEL(LEVEL) |
| #define | IS_FLASH_LATENCY(LATENCY) |
| #define | IS_FLASH_SECTOR(SECTOR) ((SECTOR) < FLASH_SECTOR_TOTAL) |
| #define | IS_OB_WRP_SECTOR(SECTOR) ((SECTOR) != 0x00000000U) |
| #define | IS_OB_PCROP_RDP(CONFIG) |
| #define | IS_OB_SECURE_RDP(CONFIG) |
| #define | IS_OB_USER_IOHSLV(VALUE) (((VALUE) == OB_IOHSLV_DISABLE) || ((VALUE) == OB_IOHSLV_ENABLE)) |
| #define | IS_OB_IWDG1_SOURCE(SOURCE) (((SOURCE) == OB_IWDG1_SW) || ((SOURCE) == OB_IWDG1_HW)) |
| #define | IS_OB_STOP_D1_RESET(VALUE) (((VALUE) == OB_STOP_NO_RST_D1) || ((VALUE) == OB_STOP_RST_D1)) |
| #define | IS_OB_STDBY_D1_RESET(VALUE) (((VALUE) == OB_STDBY_NO_RST_D1) || ((VALUE) == OB_STDBY_RST_D1)) |
| #define | IS_OB_USER_IWDG_STOP(VALUE) (((VALUE) == OB_IWDG_STOP_FREEZE) || ((VALUE) == OB_IWDG_STOP_ACTIVE)) |
| #define | IS_OB_USER_IWDG_STDBY(VALUE) (((VALUE) == OB_IWDG_STDBY_FREEZE) || ((VALUE) == OB_IWDG_STDBY_ACTIVE)) |
| #define | IS_OB_USER_ST_RAM_SIZE(VALUE) |
| #define | IS_OB_USER_SECURITY(VALUE) (((VALUE) == OB_SECURITY_ENABLE) || ((VALUE) == OB_SECURITY_DISABLE)) |
| #define | IS_OB_USER_TYPE(TYPE) |
| #define | IS_OB_BOOT_ADD_OPTION(VALUE) |
| #define | IS_FLASH_TYPECRC(VALUE) |
| #define IS_FLASH_LATENCY | ( | LATENCY | ) |
| #define IS_FLASH_TYPECRC | ( | VALUE | ) |
| #define IS_FLASH_TYPEERASE | ( | VALUE | ) |
| #define IS_OB_BOOT_ADD_OPTION | ( | VALUE | ) |
| #define IS_OB_BOR_LEVEL | ( | LEVEL | ) |
| #define IS_OB_PCROP_RDP | ( | CONFIG | ) |
| #define IS_OB_RDP_LEVEL | ( | LEVEL | ) |
| #define IS_OB_SECURE_RDP | ( | CONFIG | ) |
| #define IS_OB_USER_ST_RAM_SIZE | ( | VALUE | ) |
| #define IS_OB_USER_TYPE | ( | TYPE | ) |
| #define IS_OPTIONBYTE | ( | VALUE | ) |
| #define IS_WRPSTATE | ( | VALUE | ) |
