RTEMS 6.1
| #define | __HAL_CRC_OUTPUTREVERSAL_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR |= CRC_CR_REV_OUT) |
| Set CRC output reversal. | |
| #define | __HAL_CRC_OUTPUTREVERSAL_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR &= ~(CRC_CR_REV_OUT)) |
| Unset CRC output reversal. | |
| #define | __HAL_CRC_POLYNOMIAL_CONFIG(__HANDLE__, __POLYNOMIAL__) ((__HANDLE__)->Instance->POL = (__POLYNOMIAL__)) |
| Set CRC non-default polynomial. | |
| #define __HAL_CRC_OUTPUTREVERSAL_DISABLE | ( | __HANDLE__ | ) | ((__HANDLE__)->Instance->CR &= ~(CRC_CR_REV_OUT)) |
| __HANDLE__ | CRC handle |
| None |
| #define __HAL_CRC_OUTPUTREVERSAL_ENABLE | ( | __HANDLE__ | ) | ((__HANDLE__)->Instance->CR |= CRC_CR_REV_OUT) |
| None |
| #define __HAL_CRC_POLYNOMIAL_CONFIG | ( | __HANDLE__, | |
| __POLYNOMIAL__ | |||
| ) | ((__HANDLE__)->Instance->POL = (__POLYNOMIAL__)) |
| __POLYNOMIAL__ | 7, 8, 16 or 32-bit polynomial |
| None |
