RTEMS 6.1
#define COMP_WINDOWMODE_DISABLE   ((uint32_t)0x00000000)
#define COMP_WINDOWMODE_COMP1_INPUT_PLUS_COMMON   (COMP_CFGRx_WINMODE)
◆ COMP_WINDOWMODE_COMP1_INPUT_PLUS_COMMON
Window mode enable: Comparators instances pair COMP1 and COMP2 have their input plus connected together. The common input is COMP1 input plus (COMP2 input plus is no more accessible).
◆ COMP_WINDOWMODE_DISABLE
Window mode disable: Comparators instances pair COMP1 and COMP2 are independent
