RTEMS 6.1
#define __HAL_COMP_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_COMP_STATE_RESET)
 Reset COMP handle state.
#define COMP_CLEAR_ERRORCODE(__HANDLE__)   ((__HANDLE__)->ErrorCode = HAL_COMP_ERROR_NONE)
 Clear COMP error code (set it to no error code "HAL_COMP_ERROR_NONE").
#define __HAL_COMP_ENABLE(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_EN)
 Enable the specified comparator.
#define __HAL_COMP_DISABLE(__HANDLE__)   CLEAR_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_EN)
 Disable the specified comparator.
#define __HAL_COMP_LOCK(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_LOCK)
 Lock the specified comparator configuration.
#define __HAL_COMP_IS_LOCKED(__HANDLE__)   (READ_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_LOCK) == COMP_CFGRx_LOCK)
 Check whether the specified comparator is locked.
◆ __HAL_COMP_DISABLE
#define __HAL_COMP_DISABLE (   __HANDLE__)    CLEAR_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_EN)
Parameters
__HANDLE__COMP handle
Return values
None
◆ __HAL_COMP_ENABLE
#define __HAL_COMP_ENABLE (   __HANDLE__)    SET_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_EN)
Parameters
Return values
None
◆ __HAL_COMP_IS_LOCKED
#define __HAL_COMP_IS_LOCKED (   __HANDLE__)    (READ_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_LOCK) == COMP_CFGRx_LOCK)
Parameters
Return values
Value0 if COMP instance is not locked, value 1 if COMP instance is locked
◆ __HAL_COMP_LOCK
#define __HAL_COMP_LOCK (   __HANDLE__)    SET_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_LOCK)
Note
Using this macro induce HAL COMP handle state machine being no more in line with COMP instance state. To keep HAL COMP handle state machine updated, it is recommended to use function "HAL_COMP_Lock')".
Parameters
Return values
None
◆ __HAL_COMP_RESET_HANDLE_STATE
#define __HAL_COMP_RESET_HANDLE_STATE (   __HANDLE__)    ((__HANDLE__)->State = HAL_COMP_STATE_RESET)
Parameters
Return values
None
◆ COMP_CLEAR_ERRORCODE
#define COMP_CLEAR_ERRORCODE (   __HANDLE__)    ((__HANDLE__)->ErrorCode = HAL_COMP_ERROR_NONE)
Parameters
Return values
None
