RTEMS 6.1
Modules | Functions
 CMSIS SIMD Intrinsics
__STATIC_FORCEINLINE void __enable_irq (void)
 Enable IRQ Interrupts.
__STATIC_FORCEINLINE void __disable_irq (void)
 Disable IRQ Interrupts.
__STATIC_FORCEINLINE uint32_t __get_CONTROL (void)
 Get Control Register.
__STATIC_FORCEINLINE void __set_CONTROL (uint32_t control)
 Set Control Register.
__STATIC_FORCEINLINE uint32_t __get_IPSR (void)
 Get IPSR Register.
__STATIC_FORCEINLINE uint32_t __get_APSR (void)
 Get APSR Register.
__STATIC_FORCEINLINE uint32_t __get_xPSR (void)
 Get xPSR Register.
__STATIC_FORCEINLINE uint32_t __get_PSP (void)
 Get Process Stack Pointer.
__STATIC_FORCEINLINE void __set_PSP (uint32_t topOfProcStack)
 Set Process Stack Pointer.
__STATIC_FORCEINLINE uint32_t __get_MSP (void)
 Get Main Stack Pointer.
__STATIC_FORCEINLINE void __set_MSP (uint32_t topOfMainStack)
 Set Main Stack Pointer.
__STATIC_FORCEINLINE uint32_t __get_PRIMASK (void)
 Get Priority Mask.
__STATIC_FORCEINLINE void __set_PRIMASK (uint32_t priMask)
 Set Priority Mask.
__STATIC_FORCEINLINE uint32_t __get_FPSCR (void)
 Get FPSCR.
__STATIC_FORCEINLINE void __set_FPSCR (uint32_t fpscr)
 Set FPSCR.
◆ __disable_irq()
__STATIC_FORCEINLINE void __disable_irq ( void  )
Disables IRQ interrupts by setting special-purpose register PRIMASK. Can only be executed in Privileged modes.
◆ __enable_irq()
__STATIC_FORCEINLINE void __enable_irq ( void  )
Enables IRQ interrupts by clearing special-purpose register PRIMASK. Can only be executed in Privileged modes.
◆ __get_APSR()
__STATIC_FORCEINLINE uint32_t __get_APSR ( void  )
Get APSR Register.
Returns the content of the APSR Register.
Returns
APSR Register value
◆ __get_CONTROL()
__STATIC_FORCEINLINE uint32_t __get_CONTROL ( void  )
Returns the content of the Control Register.
Returns
Control Register value
◆ __get_FPSCR()
__STATIC_FORCEINLINE uint32_t __get_FPSCR ( void  )
Get FPSCR.
Returns the current value of the Floating Point Status/Control register.
Returns
Floating Point Status/Control register value
◆ __get_IPSR()
__STATIC_FORCEINLINE uint32_t __get_IPSR ( void  )
Get IPSR Register.
Returns the content of the IPSR Register.
Returns
IPSR Register value
◆ __get_MSP()
__STATIC_FORCEINLINE uint32_t __get_MSP ( void  )
Returns the current value of the Main Stack Pointer (MSP).
Returns
MSP Register value
◆ __get_PRIMASK()
__STATIC_FORCEINLINE uint32_t __get_PRIMASK ( void  )
Get Priority Mask.
Returns the current state of the priority mask bit from the Priority Mask Register.
Returns
Priority Mask value
◆ __get_PSP()
__STATIC_FORCEINLINE uint32_t __get_PSP ( void  )
Returns the current value of the Process Stack Pointer (PSP).
Returns
PSP Register value
◆ __get_xPSR()
__STATIC_FORCEINLINE uint32_t __get_xPSR ( void  )
Get xPSR Register.
Returns the content of the xPSR Register.
Returns
xPSR Register value
◆ __set_CONTROL()
__STATIC_FORCEINLINE void __set_CONTROL ( uint32_t  control)
Writes the given value to the Control Register.
Parameters
[in]controlControl Register value to set
◆ __set_FPSCR()
__STATIC_FORCEINLINE void __set_FPSCR ( uint32_t  fpscr)
Set FPSCR.
Assigns the given value to the Floating Point Status/Control register.
Parameters
[in]fpscrFloating Point Status/Control value to set
◆ __set_MSP()
__STATIC_FORCEINLINE void __set_MSP ( uint32_t  topOfMainStack)
Assigns the given value to the Main Stack Pointer (MSP).
Parameters
[in]topOfMainStackMain Stack Pointer value to set
◆ __set_PRIMASK()
__STATIC_FORCEINLINE void __set_PRIMASK ( uint32_t  priMask)
Set Priority Mask.
Assigns the given value to the Priority Mask Register.
Parameters
[in]priMaskPriority Mask
◆ __set_PSP()
__STATIC_FORCEINLINE void __set_PSP ( uint32_t  topOfProcStack)
Assigns the given value to the Process Stack Pointer (PSP).
Parameters
[in]topOfProcStackProcess Stack Pointer value to set
