RTEMS 6.1
Macros | Functions
Functions that configure Instruction and Data cache. More...
#define CCSIDR_WAYS(x)   (((x) & SCB_CCSIDR_ASSOCIATIVITY_Msk) >> SCB_CCSIDR_ASSOCIATIVITY_Pos)
#define CCSIDR_SETS(x)   (((x) & SCB_CCSIDR_NUMSETS_Msk ) >> SCB_CCSIDR_NUMSETS_Pos )
#define __SCB_DCACHE_LINE_SIZE   32U
#define __SCB_ICACHE_LINE_SIZE   32U
__STATIC_FORCEINLINE void SCB_EnableICache (void)
 Enable I-Cache.
__STATIC_FORCEINLINE void SCB_DisableICache (void)
 Disable I-Cache.
__STATIC_FORCEINLINE void SCB_InvalidateICache (void)
 Invalidate I-Cache.
__STATIC_FORCEINLINE void SCB_InvalidateICache_by_Addr (volatile void *addr, int32_t isize)
 I-Cache Invalidate by address.
__STATIC_FORCEINLINE void SCB_EnableDCache (void)
 Enable D-Cache.
__STATIC_FORCEINLINE void SCB_DisableDCache (void)
 Disable D-Cache.
__STATIC_FORCEINLINE void SCB_InvalidateDCache (void)
 Invalidate D-Cache.
__STATIC_FORCEINLINE void SCB_CleanDCache (void)
 Clean D-Cache.
__STATIC_FORCEINLINE void SCB_CleanInvalidateDCache (void)
 Clean & Invalidate D-Cache.
__STATIC_FORCEINLINE void SCB_InvalidateDCache_by_Addr (volatile void *addr, int32_t dsize)
 D-Cache Invalidate by address.
__STATIC_FORCEINLINE void SCB_CleanDCache_by_Addr (volatile void *addr, int32_t dsize)
 D-Cache Clean by address.
__STATIC_FORCEINLINE void SCB_CleanInvalidateDCache_by_Addr (volatile void *addr, int32_t dsize)
 D-Cache Clean and Invalidate by address.
◆ __SCB_DCACHE_LINE_SIZE
Cortex-M7 cache line size is fixed to 32 bytes (8 words). See also register SCB_CCSIDR
◆ __SCB_ICACHE_LINE_SIZE
◆ SCB_CleanDCache()
__STATIC_FORCEINLINE void SCB_CleanDCache ( void  )
Clean D-Cache.
Cleans D-Cache
◆ SCB_CleanDCache_by_Addr()
__STATIC_FORCEINLINE void SCB_CleanDCache_by_Addr ( volatile void *  addr,
int32_t  dsize
Cleans D-Cache for the given address D-Cache is cleaned starting from a 32 byte aligned address in 32 byte granularity. D-Cache memory blocks which are part of given address + given size are cleaned.
Parameters
[in]addraddress
[in]dsizesize of memory block (in number of bytes)
◆ SCB_CleanInvalidateDCache()
__STATIC_FORCEINLINE void SCB_CleanInvalidateDCache ( void  )
Cleans and Invalidates D-Cache
◆ SCB_CleanInvalidateDCache_by_Addr()
__STATIC_FORCEINLINE void SCB_CleanInvalidateDCache_by_Addr ( volatile void *  addr,
int32_t  dsize
Cleans and invalidates D_Cache for the given address D-Cache is cleaned and invalidated starting from a 32 byte aligned address in 32 byte granularity. D-Cache memory blocks which are part of given address + given size are cleaned and invalidated.
Parameters
[in]addraddress (aligned to 32-byte boundary)
◆ SCB_DisableDCache()
__STATIC_FORCEINLINE void SCB_DisableDCache ( void  )
Disable D-Cache.
Turns off D-Cache
◆ SCB_DisableICache()
__STATIC_FORCEINLINE void SCB_DisableICache ( void  )
Disable I-Cache.
Turns off I-Cache
◆ SCB_EnableDCache()
__STATIC_FORCEINLINE void SCB_EnableDCache ( void  )
Enable D-Cache.
Turns on D-Cache
◆ SCB_EnableICache()
__STATIC_FORCEINLINE void SCB_EnableICache ( void  )
Enable I-Cache.
Turns on I-Cache
◆ SCB_InvalidateDCache()
__STATIC_FORCEINLINE void SCB_InvalidateDCache ( void  )
Invalidate D-Cache.
Invalidates D-Cache
◆ SCB_InvalidateDCache_by_Addr()
__STATIC_FORCEINLINE void SCB_InvalidateDCache_by_Addr ( volatile void *  addr,
int32_t  dsize
Invalidates D-Cache for the given address. D-Cache is invalidated starting from a 32 byte aligned address in 32 byte granularity. D-Cache memory blocks which are part of given address + given size are invalidated.
Parameters
[in]addraddress
◆ SCB_InvalidateICache()
__STATIC_FORCEINLINE void SCB_InvalidateICache ( void  )
Invalidate I-Cache.
Invalidates I-Cache
◆ SCB_InvalidateICache_by_Addr()
__STATIC_FORCEINLINE void SCB_InvalidateICache_by_Addr ( volatile void *  addr,
int32_t  isize
Invalidates I-Cache for the given address. I-Cache is invalidated starting from a 32 byte aligned address in 32 byte granularity. I-Cache memory blocks which are part of given address + given size are invalidated.
Parameters
[in]addraddress
[in]isizesize of memory block (in number of bytes)
