RTEMS 6.1
Data Structures | Typedefs | Enumerations | Functions
struct  ALT_QSPI_DEV_SIZE_CONFIG_s
struct  ALT_QSPI_TIMING_CONFIG_s
struct  ALT_QSPI_DEV_INST_CONFIG_s
typedef enum ALT_QSPI_MODE_e ALT_QSPI_MODE_t
typedef enum ALT_QSPI_CS_MODE_e ALT_QSPI_CS_MODE_t
typedef enum ALT_QSPI_BAUD_DIV_e ALT_QSPI_BAUD_DIV_t
typedef struct ALT_QSPI_DEV_SIZE_CONFIG_s ALT_QSPI_DEV_SIZE_CONFIG_t
typedef enum ALT_QSPI_CLK_PHASE_e ALT_QSPI_CLK_PHASE_t
typedef enum ALT_QSPI_CLK_POLARITY_e ALT_QSPI_CLK_POLARITY_t
typedef struct ALT_QSPI_TIMING_CONFIG_s ALT_QSPI_TIMING_CONFIG_t
typedef struct ALT_QSPI_DEV_INST_CONFIG_s ALT_QSPI_DEV_INST_CONFIG_t
enum  ALT_QSPI_MODE_e { ALT_QSPI_MODE_SINGLE = 0 , ALT_QSPI_MODE_DUAL = 1 , ALT_QSPI_MODE_QUAD = 2 }
enum  ALT_QSPI_CS_MODE_e { ALT_QSPI_CS_MODE_SINGLE_SELECT = 0 , ALT_QSPI_CS_MODE_DECODE = 1 }
enum  ALT_QSPI_BAUD_DIV_e {
  ALT_QSPI_BAUD_DIV_2 = 0x0 , ALT_QSPI_BAUD_DIV_4 = 0x1 , ALT_QSPI_BAUD_DIV_6 = 0x2 , ALT_QSPI_BAUD_DIV_8 = 0x3 ,
  ALT_QSPI_BAUD_DIV_10 = 0x4 , ALT_QSPI_BAUD_DIV_12 = 0x5 , ALT_QSPI_BAUD_DIV_14 = 0x6 , ALT_QSPI_BAUD_DIV_16 = 0x7 ,
  ALT_QSPI_BAUD_DIV_18 = 0x8 , ALT_QSPI_BAUD_DIV_20 = 0x9 , ALT_QSPI_BAUD_DIV_22 = 0xA , ALT_QSPI_BAUD_DIV_24 = 0xB ,
  ALT_QSPI_BAUD_DIV_26 = 0xC , ALT_QSPI_BAUD_DIV_28 = 0xD , ALT_QSPI_BAUD_DIV_30 = 0xE , ALT_QSPI_BAUD_DIV_32 = 0xF
enum  ALT_QSPI_CLK_PHASE_e { ALT_QSPI_CLK_PHASE_ACTIVE = 0 , ALT_QSPI_CLK_PHASE_INACTIVE = 1 }
enum  ALT_QSPI_CLK_POLARITY_e { ALT_QSPI_CLK_POLARITY_LOW = 0 , ALT_QSPI_CLK_POLARITY_HIGH = 1 }
ALT_QSPI_BAUD_DIV_t alt_qspi_baud_rate_div_get (void)
ALT_STATUS_CODE alt_qspi_baud_rate_div_set (const ALT_QSPI_BAUD_DIV_t baud_rate_div)
ALT_STATUS_CODE alt_qspi_chip_select_config_get (uint32_t *cs, ALT_QSPI_CS_MODE_t *cs_mode)
ALT_STATUS_CODE alt_qspi_chip_select_config_set (const uint32_t cs, const ALT_QSPI_CS_MODE_t cs_mode)
ALT_STATUS_CODE alt_qspi_mode_bit_disable (void)
ALT_STATUS_CODE alt_qspi_mode_bit_enable (void)
uint32_t alt_qspi_mode_bit_config_get (void)
ALT_STATUS_CODE alt_qspi_mode_bit_config_set (const uint32_t mode_bits)
ALT_STATUS_CODE alt_qspi_device_size_config_get (ALT_QSPI_DEV_SIZE_CONFIG_t *cfg)
ALT_STATUS_CODE alt_qspi_device_size_config_set (const ALT_QSPI_DEV_SIZE_CONFIG_t *cfg)
ALT_STATUS_CODE alt_qspi_device_read_config_get (ALT_QSPI_DEV_INST_CONFIG_t *cfg)
ALT_STATUS_CODE alt_qspi_device_read_config_set (const ALT_QSPI_DEV_INST_CONFIG_t *cfg)
ALT_STATUS_CODE alt_qspi_device_write_config_get (ALT_QSPI_DEV_INST_CONFIG_t *cfg)
ALT_STATUS_CODE alt_qspi_device_write_config_set (const ALT_QSPI_DEV_INST_CONFIG_t *cfg)
ALT_STATUS_CODE alt_qspi_timing_config_get (ALT_QSPI_TIMING_CONFIG_t *cfg)
ALT_STATUS_CODE alt_qspi_timing_config_set (const ALT_QSPI_TIMING_CONFIG_t *cfg)
The declarations and functions in this group are used to configure the QSPI controller interface to external flash devices.
The following steps describe how to initialize and configure the QSPI controller to operate with a flash device.
Typedef Documentation
◆ ALT_QSPI_BAUD_DIV_t
This type enumerates the QSPI controller master baud rate divisor selections.
◆ ALT_QSPI_CLK_PHASE_t
This type enumerates the QSPI clock phase activity options outside the SPI word.
◆ ALT_QSPI_CLK_POLARITY_t
This type enumerates the QSPI clock polarity options outside the SPI word.
◆ ALT_QSPI_CS_MODE_t
This type enumerates the mode configurations available for driving the ss_n[3:0] device chip selects. The chip selects may be controlled as either in a '1 of 4' or '4 to 16 decode' mode.
◆ ALT_QSPI_DEV_INST_CONFIG_t
Device Instruction Configuration
This type defines a structure for specifying the optimal instruction set configuration to use with a target flash device.
◆ ALT_QSPI_DEV_SIZE_CONFIG_t
Device Size Configuration
This type defines the structure used to specify flash device size and write protect regions.
◆ ALT_QSPI_MODE_t
This type enumerates the operational modes the QSPI controller can be configured for. It may apply to instruction, address, and/or data width interactions between the QSPI controller and the flash device.
◆ ALT_QSPI_TIMING_CONFIG_t
QSPI Controller Timing Configuration
This type defines the structure used to configure timing paramaters used by the QSPI controller to communicate with a target flash device.
All timing values are defined in cycles of the SPI master ref clock.
◆ ALT_QSPI_BAUD_DIV_e
ALT_QSPI_BAUD_DIV_2
Divide by 2
ALT_QSPI_BAUD_DIV_4
Divide by 4
ALT_QSPI_BAUD_DIV_6
Divide by 6
ALT_QSPI_BAUD_DIV_8
Divide by 8
Divide by 10
Divide by 12
Divide by 14
Divide by 16
Divide by 18
Divide by 20
Divide by 22
Divide by 24
Divide by 26
Divide by 28
Divide by 30
Divide by 32
◆ ALT_QSPI_CLK_PHASE_e
The SPI clock is active outside the word
The SPI clock is inactive outside the word
◆ ALT_QSPI_CLK_POLARITY_e
SPI clock is quiescent low outside the word.
SPI clock is quiescent high outside the word.
◆ ALT_QSPI_CS_MODE_e
Select 1 of 4 chip select ss_n[3:0]
Select external 4 to 16 decode of ss_n[3:0].
◆ ALT_QSPI_MODE_e
Use Standard Single SPI (SIO-SPI) mode (bits always transferred into the device on DQ0 only). Supported by all SPI flash devices.
ALT_QSPI_MODE_DUAL
Use Dual SPI (DIO-SPI) SPI mode where bits are transferred on DQ0 and DQ1.
ALT_QSPI_MODE_QUAD
Use Dual SPI (QIO-SPI) SPI mode where bits are transferred on DQ0, DQ1, DQ3, and DQ3.
◆ alt_qspi_baud_rate_div_get()
ALT_QSPI_BAUD_DIV_t alt_qspi_baud_rate_div_get ( void  )
Get the current value of the QSPI master baud rate divisor.
Returns
The value of the QSPI master baud rate divisor.
◆ alt_qspi_baud_rate_div_set()
ALT_STATUS_CODE alt_qspi_baud_rate_div_set ( const ALT_QSPI_BAUD_DIV_t  baud_rate_div)
Set the current value of the QSPI master baud rate divisor.
Sets the value of the QSPI master baud rate divisor.
Parameters
baud_rate_divThe master baud rate divisor. Valid range includes even values 2 to 32.
Return values
ALT_E_SUCCESSIndicates successful completion.
ALT_E_ERRORIndicates an error occurred.
◆ alt_qspi_chip_select_config_get()
ALT_STATUS_CODE alt_qspi_chip_select_config_get ( uint32_t *  cs,
Get the current QSPI device peripheral chip select output and decode function configuration values.
Parameters
cs[out] The chip select line output values.
cs_mode[out] The decode mode to use for the chip selects.
Return values
◆ alt_qspi_chip_select_config_set()
ALT_STATUS_CODE alt_qspi_chip_select_config_set ( const uint32_t  cs,
Set the QSPI device peripheral chip select outputs and decode function configuration.
The chip select lines output values operate according to the selected chip select decode mode. If cs_mode is ALT_QSPI_CS_MODE_SINGLE_SELECT then cs[3:0] are output thus:
cs[3:0] n_ss_out[3:0]
xxx0 1110
xx01 1101
x011 1011
0111 0111
1111 1111 (no peripheral selected)
Otherwise if cs_mode is ALT_QSPI_CS_MODE_DECODE then cs[3:0] directly drives n_ss_out[3:0].
Parameters
csThe chip select line output values.
cs_modeThe decode mode to use for the chip selects.
Return values
◆ alt_qspi_device_read_config_get()
ALT_STATUS_CODE alt_qspi_device_read_config_get ( ALT_QSPI_DEV_INST_CONFIG_t cfg)
Get the current QSPI device read instruction configuration.
Parameters
cfg[out] Pointer to a ALT_QSPI_DEV_INST_CONFIG_t structure to contain the returned QSPI controller instruction configuration used when performing read transactions with the device.
Return values
◆ alt_qspi_device_read_config_set()
ALT_STATUS_CODE alt_qspi_device_read_config_set ( const ALT_QSPI_DEV_INST_CONFIG_t cfg)
Set the QSPI device read instruction configuration.
This API requires that the QSPI controller be idle, as determined by alt_qspi_is_idle().
Parameters
cfgPointer to a ALT_QSPI_DEV_INST_CONFIG_t structure specifying the desired op code, transfer widths, and dummy cycles for the QSPI controller to use when performing read transactions with the device.
Return values
◆ alt_qspi_device_size_config_get()
ALT_STATUS_CODE alt_qspi_device_size_config_get ( ALT_QSPI_DEV_SIZE_CONFIG_t cfg)
Get the current flash device size and write protection configuration.
Parameters
cfg[out] Pointer to a ALT_QSPI_DEV_SIZE_CONFIG_t structure to contain the returned flash device size and write protection configuration.
Return values
◆ alt_qspi_device_size_config_set()
ALT_STATUS_CODE alt_qspi_device_size_config_set ( const ALT_QSPI_DEV_SIZE_CONFIG_t cfg)
Set the flash device size and write protection configuration.
Parameters
cfgPointer to a ALT_QSPI_DEV_SIZE_CONFIG_t structure containing the flash device size and write protection configuration.
Return values
◆ alt_qspi_device_write_config_get()
ALT_STATUS_CODE alt_qspi_device_write_config_get ( ALT_QSPI_DEV_INST_CONFIG_t cfg)
Get the current QSPI device write instruction configuration.
Parameters
cfg[out] Pointer to a ALT_QSPI_DEV_INST_CONFIG_t structure to contain the returned QSPI controller instruction configuration used when performing write transactions with the device.
Return values
◆ alt_qspi_device_write_config_set()
ALT_STATUS_CODE alt_qspi_device_write_config_set ( const ALT_QSPI_DEV_INST_CONFIG_t cfg)
Set the QSPI device write instruction configuration.
Parameters
cfgPointer to a ALT_QSPI_DEV_INST_CONFIG_t structure specifying the desired op code, transfer widths, and dummy cycles for the QSPI controller to use when performing write transactions with the device.
Return values
◆ alt_qspi_mode_bit_config_get()
uint32_t alt_qspi_mode_bit_config_get ( void  )
Get the current value of the Mode Bit Configuration register.
Returns
The 8 bit value that is sent to the device following the address bytes when the mode bit is enabled (see: alt_qspi_mode_bit_enable())
◆ alt_qspi_mode_bit_config_set()
ALT_STATUS_CODE alt_qspi_mode_bit_config_set ( const uint32_t  mode_bits)
Set the value of the Mode Bit Configuration register.
Set the value of the 8 bits that are sent to the device following the address bytes when the mode bit is enabled (see: alt_qspi_mode_bit_enable())
Parameters
mode_bitsThe 8 bit value sent to the device following the address bytes.
Return values
◆ alt_qspi_mode_bit_disable()
ALT_STATUS_CODE alt_qspi_mode_bit_disable ( void  )
Disable the mode bits from being sent after the address bytes.
Prevent the mode bits defined in the Mode Bit Configuration register from being sent following the address bytes.
Return values
◆ alt_qspi_mode_bit_enable()
ALT_STATUS_CODE alt_qspi_mode_bit_enable ( void  )
Enable the mode bits to be sent after the address bytes.
Ensure the mode bits defined in the Mode Bit Configuration register to be sent following the address bytes.
Return values
◆ alt_qspi_timing_config_get()
ALT_STATUS_CODE alt_qspi_timing_config_get ( ALT_QSPI_TIMING_CONFIG_t cfg)
Get the QSPI device delay and timing configuration parameters.
This function returns the settings of the chip select delay and timing configurations.
Parameters
cfg[out] Pointer to a ALT_QSPI_TIMING_CONFIG_t structure to return the device timing and delay settings.
Return values
◆ alt_qspi_timing_config_set()
ALT_STATUS_CODE alt_qspi_timing_config_set ( const ALT_QSPI_TIMING_CONFIG_t cfg)
Set the QSPI device delay and timing configuration parameters.
This function allows the user to configure how the chip select is driven after each flash access. This is required as each device may have different timing requirements. As the serial clock frequency is increased, these timing parameters become more important and can be adjusted to meet the requirements of a specific flash device. All timings are defined in cycles of the SPI master ref clock.
Parameters
cfgPointer to a ALT_QSPI_TIMING_CONFIG_t structure specifying the desired timing and delay settings.
Return values
