#define | GRCAN_FDOPT_NOM 0 |
#define | GRCAN_FDOPT_FDBTR 0x01 |
#define | GRCAN_FDOPT_FDFRM 0x02 |
#define | GRCAN_FDMASK (GRCAN_FDOPT_FDBTR | GRCAN_FDOPT_FDFRM) |
#define | GRCAN_CFG_ABORT 0x00000001 |
#define | GRCAN_CFG_ENABLE0 0x00000002 |
#define | GRCAN_CFG_ENABLE1 0x00000004 |
#define | GRCAN_CFG_SELECTION 0x00000008 |
#define | GRCAN_CFG_SILENT 0x00000010 |
#define | GRCAN_CFG_BPR 0x00000300 |
#define | GRCAN_CFG_RSJ 0x00007000 |
#define | GRCAN_CFG_PS1 0x00f00000 |
#define | GRCAN_CFG_PS2 0x000f0000 |
#define | GRCAN_CFG_SCALER 0xff000000 |
#define | GRCAN_CFG_BPR_BIT 8 |
#define | GRCAN_CFG_RSJ_BIT 12 |
#define | GRCAN_CFG_PS1_BIT 20 |
#define | GRCAN_CFG_PS2_BIT 16 |
#define | GRCAN_CFG_SCALER_BIT 24 |
#define | GRCAN_CTRL_RESET 0x2 |
#define | GRCAN_CTRL_ENABLE 0x1 |
#define | GRCAN_TXCTRL_ENABLE 1 |
#define | GRCAN_TXCTRL_ONGOING 1 |
#define | GRCAN_RXCTRL_ENABLE 1 |
#define | GRCAN_RXCTRL_ONGOING 1 |
#define | GRCANFD_NBTR_SCALER 0x00ff0000 |
#define | GRCANFD_NBTR_PS1 0x0000fc00 |
#define | GRCANFD_NBTR_PS2 0x000003e0 |
#define | GRCANFD_NBTR_SJW 0x0000001f |
#define | GRCANFD_NBTR_SCALER_BIT 16 |
#define | GRCANFD_NBTR_PS1_BIT 10 |
#define | GRCANFD_NBTR_PS2_BIT 5 |
#define | GRCANFD_NBTR_SJW_BIT 0 |
#define | GRCANFD_FDBTR_SCALER 0x00ff0000 |
#define | GRCANFD_FDBTR_PS1 0x00003c00 |
#define | GRCANFD_FDBTR_PS2 0x000001e0 |
#define | GRCANFD_FDBTR_SJW 0x0000000f |
#define | GRCANFD_FDBTR_SCALER_BIT 16 |
#define | GRCANFD_FDBTR_PS1_BIT 10 |
#define | GRCANFD_FDBTR_PS2_BIT 5 |
#define | GRCANFD_FDBTR_SJW_BIT 0 |
#define | GRCAN_IRQ_IRQ 0 |
#define | GRCAN_IRQ_TXSYNC 1 |
#define | GRCAN_IRQ_RXSYNC 2 |
#define | GRCAN_ERR_IRQ 0x1 |
#define | GRCAN_OFF_IRQ 0x2 |
#define | GRCAN_OR_IRQ 0x4 |
#define | GRCAN_RXAHBERR_IRQ 0x8 |
#define | GRCAN_TXAHBERR_IRQ 0x10 |
#define | GRCAN_RXIRQ_IRQ 0x20 |
#define | GRCAN_TXIRQ_IRQ 0x40 |
#define | GRCAN_RXFULL_IRQ 0x80 |
#define | GRCAN_TXEMPTY_IRQ 0x100 |
#define | GRCAN_RX_IRQ 0x200 |
#define | GRCAN_TX_IRQ 0x400 |
#define | GRCAN_RXSYNC_IRQ 0x800 |
#define | GRCAN_TXSYNC_IRQ 0x1000 |
#define | GRCAN_RXERR_IRQ 0x2000 |
#define | GRCAN_TXERR_IRQ 0x4000 |
#define | GRCAN_RXMISS_IRQ 0x8000 |
#define | GRCAN_TXLOSS_IRQ 0x10000 |
#define | GRCAN_STAT_PASS 0x1 |
#define | GRCAN_STAT_OFF 0x2 |
#define | GRCAN_STAT_OR 0x4 |
#define | GRCAN_STAT_AHBERR 0x8 |
#define | GRCAN_STAT_ACTIVE 0x10 |
#define | GRCAN_STAT_RXERRCNT 0xff00 |
#define | GRCAN_STAT_TXERRCNT 0xff0000 |
int | grcan_dev_count (void) |
void * | grcan_open (int dev_no) |
void * | grcan_open_by_name (char *name, int *dev_no) |
int | grcan_close (void *d) |
int | grcan_canfd_capable (void *d) |
int | grcan_read (void *d, CANMsg *msg, size_t count) |
int | grcanfd_read (void *d, CANFDMsg *msg, size_t count) |
int | grcan_write (void *d, CANMsg *msg, size_t count) |
int | grcanfd_write (void *d, CANFDMsg *msg, size_t ucount) |
int | grcan_get_state (void *d) |
int | grcan_start (void *d) |
int | grcan_stop (void *d) |
int | grcan_flush (void *d) |
int | grcan_set_silent (void *d, int silent) |
int | grcan_set_abort (void *d, int abort) |
int | grcan_set_selection (void *d, const struct grcan_selection *selection) |
int | grcan_set_speed (void *d, unsigned int hz) |
int | grcan_set_btrs (void *d, const struct grcan_timing *timing) |
int | grcanfd_set_speed (void *d, unsigned int nomhz, unsigned int fdhz) |
int | grcanfd_set_btrs (void *d, const struct grcanfd_timing *nominal, const struct grcanfd_timing *fd) |
int | grcan_set_rxblock (void *d, int block) |
int | grcan_set_txblock (void *d, int block) |
int | grcan_set_txcomplete (void *d, int complete) |
int | grcan_set_rxcomplete (void *d, int complete) |
int | grcan_get_stats (void *d, struct grcan_stats *stats) |
int | grcan_clr_stats (void *d) |
int | grcan_set_afilter (void *d, const struct grcan_filter *filter) |
int | grcan_set_sfilter (void *d, const struct grcan_filter *filter) |
int | grcan_get_status (void *d, unsigned int *status) |
void | grcan_register_drv (void) |
Driver API for the GRLIB GRCAN and GRCANFD controllers.
