RTEMS 6.1
fsl_flexio_uart_edma.h
1/*
2 * Copyright (c) 2015, Freescale Semiconductor, Inc.
3 * Copyright 2016-2020 NXP
4 * All rights reserved.
5 *
6 * SPDX-License-Identifier: BSD-3-Clause
7 */
8#ifndef _FSL_FLEXIO_UART_EDMA_H_
9#define _FSL_FLEXIO_UART_EDMA_H_
10
11#include "fsl_flexio_uart.h"
12#include "fsl_edma.h"
13
19/*******************************************************************************
20 * Definitions
21 ******************************************************************************/
22
26#define FSL_FLEXIO_UART_EDMA_DRIVER_VERSION (MAKE_VERSION(2, 4, 1))
29/* Forward declaration of the handle typedef. */
31
35 status_t status,
36 void *userData);
37
42{
44 void *userData;
52 uint8_t nbytes;
54 volatile uint8_t txState;
55 volatile uint8_t rxState;
56};
57
58/*******************************************************************************
59 * API
60 ******************************************************************************/
61
62#if defined(__cplusplus)
63extern "C" {
64#endif
65
86 void *userData,
87 edma_handle_t *txEdmaHandle,
88 edma_handle_t *rxEdmaHandle);
89
105
121
131
141
154
168 size_t *count);
169
172#if defined(__cplusplus)
173}
174#endif
175
178#endif /* _FSL_UART_EDMA_H_ */
edma_handle_t * txEdmaHandle
Definition: fsl_flexio_uart_edma.h:49
Definition: fsl_flexio_uart_edma.h:54
void * userData
Definition: fsl_flexio_uart_edma.h:44
status_t FLEXIO_UART_TransferCreateHandleEDMA(FLEXIO_UART_Type *base, flexio_uart_edma_handle_t *handle, flexio_uart_edma_transfer_callback_t callback, void *userData, edma_handle_t *txEdmaHandle, edma_handle_t *rxEdmaHandle)
Initializes the UART handle which is used in transactional functions.
Definition: fsl_flexio_uart_edma.c:139
void FLEXIO_UART_TransferAbortSendEDMA(FLEXIO_UART_Type *base, flexio_uart_edma_handle_t *handle)
Aborts the sent data which using eDMA.
Definition: fsl_flexio_uart_edma.c:315
status_t FLEXIO_UART_TransferGetReceiveCountEDMA(FLEXIO_UART_Type *base, flexio_uart_edma_handle_t *handle, size_t *count)
Gets the number of bytes received.
Definition: fsl_flexio_uart_edma.c:360
size_t txDataSizeAll
Definition: fsl_flexio_uart_edma.h:46
status_t FLEXIO_UART_TransferSendEDMA(FLEXIO_UART_Type *base, flexio_uart_edma_handle_t *handle, flexio_uart_transfer_t *xfer)
Sends data using eDMA.
Definition: fsl_flexio_uart_edma.c:204
size_t rxDataSizeAll
Definition: fsl_flexio_uart_edma.h:47
status_t FLEXIO_UART_TransferReceiveEDMA(FLEXIO_UART_Type *base, flexio_uart_edma_handle_t *handle, flexio_uart_transfer_t *xfer)
Receives data using eDMA.
Definition: fsl_flexio_uart_edma.c:262
uint8_t nbytes
Definition: fsl_flexio_uart_edma.h:52
void(* flexio_uart_edma_transfer_callback_t)(FLEXIO_UART_Type *base, flexio_uart_edma_handle_t *handle, status_t status, void *userData)
UART transfer callback function.
Definition: fsl_flexio_uart_edma.h:33
void FLEXIO_UART_TransferAbortReceiveEDMA(FLEXIO_UART_Type *base, flexio_uart_edma_handle_t *handle)
Aborts the receive data which using eDMA.
Definition: fsl_flexio_uart_edma.c:336
edma_handle_t * rxEdmaHandle
Definition: fsl_flexio_uart_edma.h:50
Definition: fsl_flexio_uart_edma.h:55
status_t FLEXIO_UART_TransferGetSendCountEDMA(FLEXIO_UART_Type *base, flexio_uart_edma_handle_t *handle, size_t *count)
Gets the number of bytes sent out.
Definition: fsl_flexio_uart_edma.c:391
Definition: fsl_flexio_uart_edma.h:43
int32_t status_t
Type used for all status and error return values.
Definition: fsl_common.h:225
eDMA transfer handle structure
Definition: fsl_edma.h:244
UART eDMA handle.
Definition: fsl_flexio_uart_edma.h:42
Define FlexIO UART transfer structure.
Definition: fsl_flexio_uart.h:99
Define FlexIO UART access structure typedef.
Definition: fsl_flexio_uart.h:76
