RTEMS 6.1
fsl_anatop_ai.h
1/*
2 * Copyright 2019,2021 NXP
3 * All rights reserved.
4 *
5 * SPDX-License-Identifier: BSD-3-Clause
6 */
7
8#ifndef _FSL_ANATOP_AI_H_
9#define _FSL_ANATOP_AI_H_
10
11#include "fsl_common.h"
20#define FSL_ANATOP_AI_DRIVER_VERSION (MAKE_VERSION(1, 0, 0))
26typedef enum _anatop_ai_itf
27{
36
40typedef enum _anatop_ai_reg
41{
122
123/* ----------------------------------------------------------------------------
124 -- AI PHY_LDO CTRL0 Register Masks
125 ---------------------------------------------------------------------------- */
126
129#define AI_PHY_LDO_CTRL0_LINREG_EN(x) \
130 (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_LINREG_EN_SHIFT)) & AI_PHY_LDO_CTRL0_LINREG_EN_MASK)
131#define AI_PHY_LDO_CTRL0_LINREG_EN_MASK (0x1U)
132#define AI_PHY_LDO_CTRL0_LINREG_EN_SHIFT (0U)
133
138#define AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS(x) \
139 (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS_SHIFT)) & AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS_MASK)
140#define AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS_MASK (0x2U)
141#define AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS_SHIFT (1U)
147#define AI_PHY_LDO_CTRL0_LIMIT_EN(x) \
148 (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_LIMIT_EN_SHIFT)) & AI_PHY_LDO_CTRL0_LIMIT_EN_MASK)
149#define AI_PHY_LDO_CTRL0_LIMIT_EN_MASK (0x4U)
150#define AI_PHY_LDO_CTRL0_LIMIT_EN_SHIFT (2U)
156#define AI_PHY_LDO_CTRL0_OUTPUT_TRG(x) \
157 (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_OUTPUT_TRG_SHIFT)) & AI_PHY_LDO_CTRL0_OUTPUT_TRG_MASK)
158#define AI_PHY_LDO_CTRL0_OUTPUT_TRG_MASK (0x1F0U)
159#define AI_PHY_LDO_CTRL0_OUTPUT_TRG_SHIFT (4U)
166#define AI_PHY_LDO_CTRL0_PHY_ISO_B(x) \
167 (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_PHY_ISO_B_SHIFT)) & AI_PHY_LDO_CTRL0_PHY_ISO_B_MASK)
168#define AI_PHY_LDO_CTRL0_PHY_ISO_B_MASK (0x8000U)
169#define AI_PHY_LDO_CTRL0_PHY_ISO_B_SHIFT (15U)
182#define AI_PHY_LDO_STAT0_LINREG_STAT(x) \
183 (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_STAT0_LINREG_STAT_SHIFT)) & AI_PHY_LDO_STAT0_LINREG_STAT_MASK)
184#define AI_PHY_LDO_STAT0_LINREG_STAT_MASK (0xFU)
185#define AI_PHY_LDO_STAT0_LINREG_STAT_SHIFT (0U)
186
195#define AI_BANDGAP_CTRL0_REFTOP_PWD(x) \
196 (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_PWD_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_PWD_MASK)
197#define AI_BANDGAP_CTRL0_REFTOP_PWD_MASK (0x1U)
198#define AI_BANDGAP_CTRL0_REFTOP_PWD_SHIFT (0U)
204#define AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD(x) \
205 (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD_SHIFT)) & \
206 AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD_MASK)
207#define AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD_MASK (0x2U)
208#define AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD_SHIFT (1U)
215#define AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP(x) \
216 (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP_MASK)
217#define AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP_MASK (0x4U)
218#define AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP_SHIFT (2U)
224#define AI_BANDGAP_CTRL0_REFTOP_LOWPOWER(x) \
225 (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_LOWPOWER_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_LOWPOWER_MASK)
226#define AI_BANDGAP_CTRL0_REFTOP_LOWPOWER_MASK (0x8U)
227#define AI_BANDGAP_CTRL0_REFTOP_LOWPOWER_SHIFT (3U)
234#define AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF(x) \
235 (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF_SHIFT)) & \
236 AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF_MASK)
237#define AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF_MASK (0x10U)
238#define AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF_SHIFT (4U)
247#define AI_BANDGAP_CTRL0_REFTOP_VBGADJ(x) \
248 (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_VBGADJ_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_VBGADJ_MASK)
249#define AI_BANDGAP_CTRL0_REFTOP_VBGADJ_MASK (0xE0U)
250#define AI_BANDGAP_CTRL0_REFTOP_VBGADJ_SHIFT (5U)
263#define AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ(x) \
264 (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ_MASK)
265#define AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ_MASK (0x1C00U)
266#define AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ_SHIFT (10U)
284#define AI_BANDGAP_STAT0_REFTOP_VBGUP(x) \
285 (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_STAT0_REFTOP_VBGUP_SHIFT)) & AI_BANDGAP_STAT0_REFTOP_VBGUP_MASK)
286#define AI_BANDGAP_STAT0_REFTOP_VBGUP_MASK (0x1U)
287#define AI_BANDGAP_STAT0_REFTOP_VBGUP_SHIFT (0U)
292#define AI_RCOSC400M_CTRL0_REF_CLK_DIV(x) \
293 (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL0_REF_CLK_DIV_SHIFT)) & AI_RCOSC400M_CTRL0_REF_CLK_DIV_MASK)
294#define AI_RCOSC400M_CTRL0_REF_CLK_DIV_MASK (0x3F000000U)
295#define AI_RCOSC400M_CTRL0_REF_CLK_DIV_SHIFT (24U)
300#define AI_RCOSC400M_CTRL1_HYST_MINUS(x) \
301 (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL1_HYST_MINUS_SHIFT)) & AI_RCOSC400M_CTRL1_HYST_MINUS_MASK)
302#define AI_RCOSC400M_CTRL1_HYST_MINUS_MASK (0xFU)
303#define AI_RCOSC400M_CTRL1_HYST_MINUS_SHIFT (0U)
304
305#define AI_RCOSC400M_CTRL1_HYST_PLUS(x) \
306 (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL1_HYST_PLUS_SHIFT)) & AI_RCOSC400M_CTRL1_HYST_PLUS_MASK)
307#define AI_RCOSC400M_CTRL1_HYST_PLUS_MASK (0xF00U)
308#define AI_RCOSC400M_CTRL1_HYST_PLUS_SHIFT (8U)
309
310#define AI_RCOSC400M_CTRL1_TARGET_COUNT(x) \
311 (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL1_TARGET_COUNT_SHIFT)) & AI_RCOSC400M_CTRL1_TARGET_COUNT_MASK)
312#define AI_RCOSC400M_CTRL1_TARGET_COUNT_MASK (0xFFFF0000U)
313#define AI_RCOSC400M_CTRL1_TARGET_COUNT_SHIFT (16U)
318#define AI_RCOSC400M_CTRL2_TUNE_BYP(x) \
319 (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL2_TUNE_BYP_SHIFT)) & AI_RCOSC400M_CTRL2_TUNE_BYP_MASK)
320#define AI_RCOSC400M_CTRL2_TUNE_BYP_MASK (0x400U)
321#define AI_RCOSC400M_CTRL2_TUNE_BYP_SHIFT (10U)
322
323#define AI_RCOSC400M_CTRL2_TUNE_EN(x) \
324 (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL2_TUNE_EN_SHIFT)) & AI_RCOSC400M_CTRL2_TUNE_EN_MASK)
325#define AI_RCOSC400M_CTRL2_TUNE_EN_MASK (0x1000U)
326#define AI_RCOSC400M_CTRL2_TUNE_EN_SHIFT (12U)
327
328#define AI_RCOSC400M_CTRL2_TUNE_START(x) \
329 (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL2_TUNE_START_SHIFT)) & AI_RCOSC400M_CTRL2_TUNE_START_MASK)
330#define AI_RCOSC400M_CTRL2_TUNE_START_MASK (0x4000U)
331#define AI_RCOSC400M_CTRL2_TUNE_START_SHIFT (14U)
332
333#define AI_RCOSC400M_CTRL2_OSC_TUNE_VAL(x) \
334 (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL2_OSC_TUNE_VAL_SHIFT)) & AI_RCOSC400M_CTRL2_OSC_TUNE_VAL_MASK)
335#define AI_RCOSC400M_CTRL2_OSC_TUNE_VAL_MASK (0xFF000000U)
336#define AI_RCOSC400M_CTRL2_OSC_TUNE_VAL_SHIFT (24U)
341#define AI_RCOSC400M_CTRL3_CLR_ERR(x) \
342 (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL3_CLR_ERR_SHIFT)) & AI_RCOSC400M_CTRL3_CLR_ERR_MASK)
343#define AI_RCOSC400M_CTRL3_CLR_ERR_MASK (0x1U)
344#define AI_RCOSC400M_CTRL3_CLR_ERR_SHIFT (0U)
345
346#define AI_RCOSC400M_CTRL3_EN_1M_CLK(x) \
347 (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL3_EN_1M_CLK_SHIFT)) & AI_RCOSC400M_CTRL3_EN_1M_CLK_MASK)
348#define AI_RCOSC400M_CTRL3_EN_1M_CLK_MASK (0x100U)
349#define AI_RCOSC400M_CTRL3_EN_1M_CLK_SHIFT (8U)
350
351#define AI_RCOSC400M_CTRL3_MUX_1M_CLK(x) \
352 (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL3_MUX_1M_CLK_SHIFT)) & AI_RCOSC400M_CTRL3_MUX_1M_CLK_MASK)
353#define AI_RCOSC400M_CTRL3_MUX_1M_CLK_MASK (0x400U)
354#define AI_RCOSC400M_CTRL3_MUX_1M_CLK_SHIFT (10U)
355
356#define AI_RCOSC400M_CTRL3_COUNT_1M_CLK(x) \
357 (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL3_COUNT_1M_CLK_SHIFT)) & AI_RCOSC400M_CTRL3_COUNT_1M_CLK_MASK)
358#define AI_RCOSC400M_CTRL3_COUNT_1M_CLK_MASK (0xFFFF0000U)
359#define AI_RCOSC400M_CTRL3_COUNT_1M_CLK_SHIFT (16U)
364#define AI_RCOSC400M_STAT0_CLK1M_ERR(x) \
365 (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_STAT0_CLK1M_ERR_SHIFT)) & AI_RCOSC400M_STAT0_CLK1M_ERR_MASK)
366#define AI_RCOSC400M_STAT0_CLK1M_ERR_MASK (0x1U)
367#define AI_RCOSC400M_STAT0_CLK1M_ERR_SHIFT (0U)
372#define AI_RCOSC400M_STAT1_CURR_COUNT_VAL(x) \
373 (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_STAT1_CURR_COUNT_VAL_SHIFT)) & AI_RCOSC400M_STAT1_CURR_COUNT_VAL_MASK)
374#define AI_RCOSC400M_STAT1_CURR_COUNT_VAL_MASK (0xFFFF0000U)
375#define AI_RCOSC400M_STAT1_CURR_COUNT_VAL_SHIFT (16U)
380#define AI_RCOSC400M_STAT2_CURR_OSC_TUNE_VAL(x) \
381 (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_STAT2_CURR_OSC_TUNE_VAL_SHIFT)) & \
382 AI_RCOSC400M_STAT2_CURR_OSC_TUNE_VAL_MASK)
383#define AI_RCOSC400M_STAT2_CURR_OSC_TUNE_VAL_MASK (0xFF000000U)
384#define AI_RCOSC400M_STAT2_CURR_OSC_TUNE_VAL_SHIFT (24U)
389#define AI_PLL1G_CTRL0_HOLD_RING_OFF(x) \
390 (((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_HOLD_RING_OFF_SHIFT)) & AI_PLL1G_CTRL0_HOLD_RING_OFF_MASK)
391#define AI_PLL1G_CTRL0_HOLD_RING_OFF_MASK (0x2000UL)
392#define AI_PLL1G_CTRL0_HOLD_RING_OFF_SHIFT (13U)
393
394#define AI_PLL1G_CTRL0_POWER_UP(x) \
395 (((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_POWER_UP_SHIFT)) & AI_PLL1G_CTRL0_POWER_UP_MASK)
396#define AI_PLL1G_CTRL0_POWER_UP_MASK (0x4000UL)
397#define AI_PLL1G_CTRL0_POWER_UP_SHIFT (14U)
398
399#define AI_PLL1G_CTRL0_ENABLE(x) \
400 (((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_ENABLE_SHIFT)) & AI_PLL1G_CTRL0_ENABLE_MASK)
401#define AI_PLL1G_CTRL0_ENABLE_MASK (0x8000UL)
402#define AI_PLL1G_CTRL0_ENABLE_SHIFT (15U)
403
404#define AI_PLL1G_CTRL0_BYPASS(x) \
405 (((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_BYPASS_SHIFT)) & AI_PLL1G_CTRL0_BYPASS_MASK)
406#define AI_PLL1G_CTRL0_BYPASS_MASK (0x10000UL)
407#define AI_PLL1G_CTRL0_BYPASS_SHIFT (16U)
408
409#define AI_PLL1G_CTRL0_PLL_REG_EN(x) \
410 (((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_PLL_REG_EN_SHIFT)) & AI_PLL1G_CTRL0_PLL_REG_EN_MASK)
411#define AI_PLL1G_CTRL0_PLL_REG_EN_MASK (0x400000UL)
412#define AI_PLL1G_CTRL0_PLL_REG_EN_SHIFT (22U)
417#define AI_PLLAUDIO_CTRL0_HOLD_RING_OFF(x) \
418 (((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_HOLD_RING_OFF_SHIFT)) & AI_PLLAUDIO_CTRL0_HOLD_RING_OFF_MASK)
419#define AI_PLLAUDIO_CTRL0_HOLD_RING_OFF_MASK (0x2000UL)
420#define AI_PLLAUDIO_CTRL0_HOLD_RING_OFF_SHIFT (13U)
421
422#define AI_PLLAUDIO_CTRL0_POWER_UP(x) \
423 (((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_POWER_UP_SHIFT)) & AI_PLLAUDIO_CTRL0_POWER_UP_MASK)
424#define AI_PLLAUDIO_CTRL0_POWER_UP_MASK (0x4000UL)
425#define AI_PLLAUDIO_CTRL0_POWER_UP_SHIFT (14U)
426
427#define AI_PLLAUDIO_CTRL0_ENABLE(x) \
428 (((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_ENABLE_SHIFT)) & AI_PLLAUDIO_CTRL0_ENABLE_MASK)
429#define AI_PLLAUDIO_CTRL0_ENABLE_MASK (0x8000UL)
430#define AI_PLLAUDIO_CTRL0_ENABLE_SHIFT (15U)
431
432#define AI_PLLAUDIO_CTRL0_BYPASS(x) \
433 (((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_BYPASS_SHIFT)) & AI_PLLAUDIO_CTRL0_BYPASS_MASK)
434#define AI_PLLAUDIO_CTRL0_BYPASS_MASK (0x10000UL)
435#define AI_PLLAUDIO_CTRL0_BYPASS_SHIFT (16U)
436
437#define AI_PLLAUDIO_CTRL0_PLL_REG_EN(x) \
438 (((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_PLL_REG_EN_SHIFT)) & AI_PLLAUDIO_CTRL0_PLL_REG_EN_MASK)
439#define AI_PLLAUDIO_CTRL0_PLL_REG_EN_MASK (0x400000UL)
440#define AI_PLLAUDIO_CTRL0_PLL_REG_EN_SHIFT (22U)
445#define AI_PLLVIDEO_CTRL0_HOLD_RING_OFF(x) \
446 (((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_HOLD_RING_OFF_SHIFT)) & AI_PLLVIDEO_CTRL0_HOLD_RING_OFF_MASK)
447#define AI_PLLVIDEO_CTRL0_HOLD_RING_OFF_MASK (0x2000UL)
448#define AI_PLLVIDEO_CTRL0_HOLD_RING_OFF_SHIFT (13U)
449
450#define AI_PLLVIDEO_CTRL0_POWER_UP(x) \
451 (((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_POWER_UP_SHIFT)) & AI_PLLVIDEO_CTRL0_POWER_UP_MASK)
452#define AI_PLLVIDEO_CTRL0_POWER_UP_MASK (0x4000UL)
453#define AI_PLLVIDEO_CTRL0_POWER_UP_SHIFT (14U)
454
455#define AI_PLLVIDEO_CTRL0_ENABLE(x) \
456 (((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_ENABLE_SHIFT)) & AI_PLLVIDEO_CTRL0_ENABLE_MASK)
457#define AI_PLLVIDEO_CTRL0_ENABLE_MASK (0x8000UL)
458#define AI_PLLVIDEO_CTRL0_ENABLE_SHIFT (15U)
459
460#define AI_PLLVIDEO_CTRL0_BYPASS(x) \
461 (((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_BYPASS_SHIFT)) & AI_PLLVIDEO_CTRL0_BYPASS_MASK)
462#define AI_PLLVIDEO_CTRL0_BYPASS_MASK (0x10000UL)
463#define AI_PLLVIDEO_CTRL0_BYPASS_SHIFT (16U)
464
465#define AI_PLLVIDEO_CTRL0_PLL_REG_EN(x) \
466 (((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_PLL_REG_EN_SHIFT)) & AI_PLLVIDEO_CTRL0_PLL_REG_EN_MASK)
467#define AI_PLLVIDEO_CTRL0_PLL_REG_EN_MASK (0x400000UL)
468#define AI_PLLVIDEO_CTRL0_PLL_REG_EN_SHIFT (22U)
473/*******************************************************************************
474 * API
475 ******************************************************************************/
476
477#if defined(__cplusplus)
478extern "C" {
479#endif /* __cplusplus */
480
490uint32_t ANATOP_AI_Access(anatop_ai_itf_t itf, bool isWrite, anatop_ai_reg_t addr, uint32_t wdata);
491
500void ANATOP_AI_Write(anatop_ai_itf_t itf, anatop_ai_reg_t addr, uint32_t wdata);
501
511
523 anatop_ai_itf_t itf, anatop_ai_reg_t addr, uint32_t wdata, uint32_t mask, uint32_t shift);
524
525/* @} */
526
527#if defined(__cplusplus)
528}
529#endif /* __cplusplus */
530
533#endif /* _FSL_ANATOP_AI_H_ */
void ANATOP_AI_WriteWithMaskShift(anatop_ai_itf_t itf, anatop_ai_reg_t addr, uint32_t wdata, uint32_t mask, uint32_t shift)
AI interface write with mask and shift.
Definition: fsl_anatop_ai.c:350
uint32_t ANATOP_AI_Read(anatop_ai_itf_t itf, anatop_ai_reg_t addr)
AI interface reading.
Definition: fsl_anatop_ai.c:343
AI interface writing.
Definition: fsl_anatop_ai.c:338
AI interface access.
Definition: fsl_anatop_ai.c:14
enum _anatop_ai_itf anatop_ai_itf_t
Anatop AI ITF enumeration.
_anatop_ai_reg
The enumeration of ANATOP AI Register.
Definition: fsl_anatop_ai.h:41
enum _anatop_ai_reg anatop_ai_reg_t
_anatop_ai_itf
Definition: fsl_anatop_ai.h:27
@ kAI_RCOSC400M_STAT0
Definition: fsl_anatop_ai.h:70
@ kAI_PLLAUDIO_CTRL0_SET
Definition: fsl_anatop_ai.h:97
@ kAI_PLLAUDIO_CTRL0_CLR
Definition: fsl_anatop_ai.h:98
@ kAI_RCOSC400M_CTRL2
Definition: fsl_anatop_ai.h:62
@ kAI_PLLVIDEO_CTRL0_SET
Definition: fsl_anatop_ai.h:110
@ kAI_PHY_LDO_STAT0
Definition: fsl_anatop_ai.h:46
@ kAI_PLLAUDIO_CTRL3
Definition: fsl_anatop_ai.h:105
@ kAI_RCOSC400M_STAT1_TOG
Definition: fsl_anatop_ai.h:77
@ kAI_PLLVIDEO_CTRL1
Definition: fsl_anatop_ai.h:112
@ kAI_PHY_LDO_CTRL0_CLR
Definition: fsl_anatop_ai.h:44
@ kAI_RCOSC400M_CTRL0_SET
Definition: fsl_anatop_ai.h:55
@ kAI_PHY_LDO_CTRL0
Definition: fsl_anatop_ai.h:42
@ kAI_PHY_LDO_STAT0_TOG
Definition: fsl_anatop_ai.h:49
@ kAI_RCOSC400M_CTRL2_TOG
Definition: fsl_anatop_ai.h:65
@ kAI_PLLAUDIO_CTRL2_CLR
Definition: fsl_anatop_ai.h:104
@ kAI_RCOSC400M_CTRL1_TOG
Definition: fsl_anatop_ai.h:61
Definition: fsl_anatop_ai.h:102
@ kAI_PLL1G_CTRL1
Definition: fsl_anatop_ai.h:86
@ kAI_RCOSC400M_CTRL1_CLR
Definition: fsl_anatop_ai.h:60
@ kAI_RCOSC400M_CTRL3_SET
Definition: fsl_anatop_ai.h:67
@ kAI_RCOSC400M_CTRL2_SET
Definition: fsl_anatop_ai.h:63
@ kAI_PLLVIDEO_CTRL3_SET
Definition: fsl_anatop_ai.h:119
@ kAI_PLL1G_CTRL1_SET
Definition: fsl_anatop_ai.h:87
@ kAI_RCOSC400M_STAT0_CLR
Definition: fsl_anatop_ai.h:72
@ kAI_PLL1G_CTRL1_CLR
Definition: fsl_anatop_ai.h:88
@ kAI_RCOSC400M_STAT1_SET
Definition: fsl_anatop_ai.h:75
Definition: fsl_anatop_ai.h:58
@ kAI_RCOSC400M_CTRL0_TOG
Definition: fsl_anatop_ai.h:57
@ kAI_BANDGAP_CTRL0
Definition: fsl_anatop_ai.h:51
@ kAI_RCOSC400M_STAT0_TOG
Definition: fsl_anatop_ai.h:73
@ kAI_PLL1G_CTRL0
Definition: fsl_anatop_ai.h:83
@ kAI_PLLVIDEO_CTRL0_CLR
Definition: fsl_anatop_ai.h:111
@ kAI_PLLVIDEO_CTRL1_CLR
Definition: fsl_anatop_ai.h:114
@ kAI_PLL1G_CTRL3
Definition: fsl_anatop_ai.h:92
@ kAI_PLLVIDEO_CTRL3_CLR
Definition: fsl_anatop_ai.h:120
Definition: fsl_anatop_ai.h:54
@ kAI_RCOSC400M_STAT1_CLR
Definition: fsl_anatop_ai.h:76
@ kAI_PHY_LDO_CTRL0_SET
Definition: fsl_anatop_ai.h:43
@ kAI_PLLAUDIO_CTRL3_CLR
Definition: fsl_anatop_ai.h:107
@ kAI_PLL1G_CTRL2_CLR
Definition: fsl_anatop_ai.h:91
@ kAI_RCOSC400M_STAT2_TOG
Definition: fsl_anatop_ai.h:81
@ kAI_RCOSC400M_CTRL3_CLR
Definition: fsl_anatop_ai.h:68
Definition: fsl_anatop_ai.h:96
@ kAI_PLLVIDEO_CTRL2
Definition: fsl_anatop_ai.h:115
@ kAI_PLLAUDIO_CTRL3_SET
Definition: fsl_anatop_ai.h:106
@ kAI_PLLVIDEO_CTRL2_CLR
Definition: fsl_anatop_ai.h:117
@ kAI_PHY_LDO_STAT0_CLR
Definition: fsl_anatop_ai.h:48
@ kAI_RCOSC400M_CTRL2_CLR
Definition: fsl_anatop_ai.h:64
@ kAI_PLL1G_CTRL2_SET
Definition: fsl_anatop_ai.h:90
@ kAI_PLLAUDIO_CTRL1_SET
Definition: fsl_anatop_ai.h:100
Definition: fsl_anatop_ai.h:78
@ kAI_PLLAUDIO_CTRL1_CLR
Definition: fsl_anatop_ai.h:101
@ kAI_PHY_LDO_STAT0_SET
Definition: fsl_anatop_ai.h:47
@ kAI_PLLVIDEO_CTRL2_SET
Definition: fsl_anatop_ai.h:116
Definition: fsl_anatop_ai.h:99
@ kAI_PLLAUDIO_CTRL2_SET
Definition: fsl_anatop_ai.h:103
Definition: fsl_anatop_ai.h:118
Definition: fsl_anatop_ai.h:74
@ kAI_PLLVIDEO_CTRL1_SET
Definition: fsl_anatop_ai.h:113
@ kAI_PLL1G_CTRL2
Definition: fsl_anatop_ai.h:89
Definition: fsl_anatop_ai.h:66
Definition: fsl_anatop_ai.h:109
@ kAI_RCOSC400M_CTRL1_SET
Definition: fsl_anatop_ai.h:59
@ kAI_PLL1G_CTRL0_SET
Definition: fsl_anatop_ai.h:84
@ kAI_RCOSC400M_STAT2_SET
Definition: fsl_anatop_ai.h:79
@ kAI_RCOSC400M_CTRL0_CLR
Definition: fsl_anatop_ai.h:56
@ kAI_PHY_LDO_CTRL0_TOG
Definition: fsl_anatop_ai.h:45
@ kAI_PLL1G_CTRL3_SET
Definition: fsl_anatop_ai.h:93
@ kAI_BANDGAP_STAT0
Definition: fsl_anatop_ai.h:52
@ kAI_RCOSC400M_CTRL3_TOG
Definition: fsl_anatop_ai.h:69
@ kAI_RCOSC400M_STAT2_CLR
Definition: fsl_anatop_ai.h:80
@ kAI_RCOSC400M_STAT0_SET
Definition: fsl_anatop_ai.h:71
@ kAI_PLL1G_CTRL3_CLR
Definition: fsl_anatop_ai.h:94
@ kAI_PLL1G_CTRL0_CLR
Definition: fsl_anatop_ai.h:85
@ kAI_Itf_Audio
Definition: fsl_anatop_ai.h:30
@ kAI_Itf_400m
Definition: fsl_anatop_ai.h:32
@ kAI_Itf_Video
Definition: fsl_anatop_ai.h:31
@ kAI_Itf_1g
Definition: fsl_anatop_ai.h:29
@ kAI_Itf_Ldo
Definition: fsl_anatop_ai.h:28
@ kAI_Itf_Bandgap
Definition: fsl_anatop_ai.h:34
@ kAI_Itf_Temp
Definition: fsl_anatop_ai.h:33
