RTEMS 6.1
Flash Disk Block Device Implementation. More...
#include <rtems.h>#include <rtems/libio.h>#include <errno.h>#include <stdlib.h>#include <stdio.h>#include <string.h>#include <unistd.h>#include <inttypes.h>#include <rtems/blkdev.h>#include <rtems/flashdisk.h>#include <rtems/thread.h>Data Structures | |
| struct | rtems_fdisk_page_desc |
| struct | rtems_fdisk_segment_ctl |
| struct | rtems_fdisk_segment_ctl_queue |
| struct | rtems_fdisk_device_ctl |
| struct | rtems_fdisk_block_ctl |
| struct | rtems_flashdisk |
| #define | RTEMS_FDISK_TRACE 1 |
| #define | RTEMS_FDISK_PAGE_ACTIVE (1 << 0) |
| #define | RTEMS_FDISK_PAGE_USED (1 << 1) |
| #define | rtems_fdisk_calc_crc16(_b, _c) rtems_fdisk_crc16_factor[((_b) ^ ((_c) & 0xff)) & 0xff] ^ (((_c) >> 8) & 0xff) |
Typedefs | |
| typedef struct rtems_fdisk_page_desc | rtems_fdisk_page_desc |
| typedef struct rtems_fdisk_segment_ctl | rtems_fdisk_segment_ctl |
| typedef struct rtems_fdisk_segment_ctl_queue | rtems_fdisk_segment_ctl_queue |
| typedef struct rtems_fdisk_device_ctl | rtems_fdisk_device_ctl |
| typedef struct rtems_fdisk_block_ctl | rtems_fdisk_block_ctl |
| typedef struct rtems_flashdisk | rtems_flashdisk |
| rtems_device_driver | rtems_fdisk_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg RTEMS_UNUSED) |
| #define rtems_fdisk_calc_crc16 | ( | _b, | |
| _c | |||
| ) | rtems_fdisk_crc16_factor[((_b) ^ ((_c) & 0xff)) & 0xff] ^ (((_c) >> 8) & 0xff) |
Calculate the CRC16 checksum.
| _b | The byte to checksum. |
| _c | The current checksum. |
| #define RTEMS_FDISK_PAGE_ACTIVE (1 << 0) |
Flag the page as active.
| #define RTEMS_FDISK_PAGE_USED (1 << 1) |
Flag the page as used.
| #define RTEMS_FDISK_TRACE 1 |
Control tracing. It can be compiled out of the code for small footprint targets. Leave in by default.
| typedef struct rtems_fdisk_block_ctl rtems_fdisk_block_ctl |
The Block control holds the segment and page with the data.
| typedef struct rtems_fdisk_device_ctl rtems_fdisk_device_ctl |
Flash Device Control holds the segment controls
| typedef struct rtems_fdisk_page_desc rtems_fdisk_page_desc |
The start of a segment has a segment control table. This hold the CRC and block number for the page.
| typedef struct rtems_fdisk_segment_ctl rtems_fdisk_segment_ctl |
Flash Segment Control holds the pointer to the segment, number of pages, various page stats and the memory copy of the page descriptors.
| typedef struct rtems_fdisk_segment_ctl_queue rtems_fdisk_segment_ctl_queue |
Segment control table queue.
| typedef struct rtems_flashdisk rtems_flashdisk |
The virtual block table holds the mapping for blocks as seen by the disk drivers to the device, segment and page numbers of the physical device.
| rtems_device_driver rtems_fdisk_initialize | ( | rtems_device_major_number | major, |
| rtems_device_minor_number | minor, | ||
| void *arg | RTEMS_UNUSED | ||
Flash disk device driver initialization.
| major | Flash disk major device number. |
| minor | Minor device number, not applicable. |
| arg | Initialization argument, not applicable. |
