RTEMS 6.1
fb_default_mode.h File Reference
Variable for the definition of the default graphical mode to be initialized. More...
const char *const rtems_fb_default_mode
 Allows to enable initialization of VESA real mode driver from an application by setting the value of this variable to non null value in user's module. The value of this variable will be then updated when linked with application's object.
Variable Documentation
◆ rtems_fb_default_mode
const char* const rtems_fb_default_mode
extern
Further the value should point to string in the following format: "<resX>x<resY>[-<bpp>]" - e.g. "1024x768-32" "auto" - try EDID to find mode that fits the display attached best "none" / "off" - do not initialize the driver the given parameters are used if applicable.
Command line argument "--video=" has priority over this string.
