RTEMS 6.1
Macros | Functions
efc.h File Reference
#include "chip.h"
#include <stdint.h>
#define IFLASH_SECTOR_SIZE   65536u
#define EFC_FCMD_GETD   0x00 /* Get Flash Descriptor */
#define EFC_FCMD_WP   0x01 /* Write page */
#define EFC_FCMD_WPL   0x02 /* Write page and lock */
#define EFC_FCMD_EWP   0x03 /* Erase page and write page */
#define EFC_FCMD_EWPL   0x04 /* Erase page and write page then lock */
#define EFC_FCMD_EA   0x05 /* Erase all */
#define EFC_FCMD_EPA   0x07 /* Erase pages */
#define EFC_FCMD_SLB   0x08 /* Set Lock Bit */
#define EFC_FCMD_CLB   0x09 /* Clear Lock Bit */
#define EFC_FCMD_GLB   0x0A /* Get Lock Bit */
#define EFC_FCMD_SFB   0x0B /* Set GPNVM Bit */
#define EFC_FCMD_CFB   0x0C /* Clear GPNVM Bit */
#define EFC_FCMD_GFB   0x0D /* Get GPNVM Bit */
#define EFC_FCMD_STUI   0x0E /* Start unique ID */
#define EFC_FCMD_SPUI   0x0F /* Stop unique ID */
#define EFC_FCMD_GCALB   0x10 /* Get CALIB Bit */
#define EFC_FCMD_ES   0x11 /* Erase Sector */
#define EFC_FCMD_WUS   0x12 /* Write User Signature */
#define EFC_FCMD_EUS   0x13 /* Erase User Signature */
#define EFC_FCMD_STUS   0x14 /* Start Read User Signature */
#define EFC_FCMD_SPUS   0x15 /* Stop Read User Signature */
#define CHIP_FLASH_IAP_ADDRESS   (0x00800008)
void EFC_EnableFrdyIt (Efc *efc)
 Enables the flash ready interrupt source on the EEFC peripheral.
void EFC_DisableFrdyIt (Efc *efc)
 Disables the flash ready interrupt source on the EEFC peripheral.
void EFC_SetWaitState (Efc *efc, uint8_t cycles)
 Set read/write wait state on the EEFC peripheral.
void EFC_TranslateAddress (Efc **pEfc, uint32_t dwAddress, uint16_t *pwPage, uint16_t *pwOffset)
 Translates the given address page and offset values.
void EFC_ComputeAddress (Efc *efc, uint16_t wPage, uint16_t wOffset, uint32_t *pdwAddress)
 Computes the address of a flash access given the page and offset.
uint32_t EFC_PerformCommand (Efc *efc, uint32_t dwCommand, uint32_t dwArgument, uint32_t dwUseIAP)
 Performs the given command and wait until its completion (or an error).
uint32_t EFC_GetStatus (Efc *efc)
 Returns the current status of the EEFC.
uint32_t EFC_GetResult (Efc *efc)
 Returns the result of the last executed command.
void EFC_SetFlashAccessMode (Efc *efc, uint32_t dwMode)
 Set flash access mode.
Purpose
Interface for configuration the Enhanced Embedded Flash Controller (EEFC) peripheral.
Usage
  1. Enable/disable flash ready interrupt sources using EFC_EnableFrdyIt() and EFC_DisableFrdyIt().
  2. Translates the given address into which EEFC, page and offset values for difference density flash memory using EFC_TranslateAddress().
  3. Computes the address of a flash access given the EFC, page and offset for difference density flash memory using EFC_ComputeAddress().
  4. Start the executing command with EFC_PerformCommand()
  5. Retrieve the current status of the EFC using EFC_GetStatus().
  6. Retrieve the result of the last executed command with EFC_GetResult().
◆ EFC_ComputeAddress()
void EFC_ComputeAddress ( Efc efc,
uint16_t  wPage,
uint16_t  wOffset,
uint32_t *  pdwAddress
Parameters
efcPointer to a Efc instance
pagePage number.
offsetByte offset inside page.
pAddressComputed address (optional).
◆ EFC_DisableFrdyIt()
void EFC_DisableFrdyIt ( Efc efc)
Parameters
◆ EFC_EnableFrdyIt()
void EFC_EnableFrdyIt ( Efc efc)
Parameters
◆ EFC_GetResult()
uint32_t EFC_GetResult ( Efc efc)
Parameters
◆ EFC_GetStatus()
uint32_t EFC_GetStatus ( Efc efc)
Note
Keep in mind that this function clears the value of some status bits (LOCKE, PROGE).
Parameters
◆ EFC_PerformCommand()
uint32_t EFC_PerformCommand ( Efc efc,
uint32_t  dwCommand,
uint32_t  dwUseIAP
Parameters
commandCommand to perform.
argumentOptional command argument.
Returns
0 if successful, otherwise returns an error code.
◆ EFC_SetFlashAccessMode()
void EFC_SetFlashAccessMode ( Efc efc,
uint32_t  dwMode
Parameters
dwMode- 0:128-bit, (1<<24):64-bit
◆ EFC_SetWaitState()
void EFC_SetWaitState ( Efc efc,
uint8_t  ucCycles
Parameters
cyclesthe number of wait states in cycle.
◆ EFC_TranslateAddress()
void EFC_TranslateAddress ( Efc **  ppEfc,
uint32_t  dwAddress,
uint16_t *  pwPage,
uint16_t *  pwOffset
Note
The resulting values are stored in the provided variables if they are not null.
Parameters
addressAddress to translate.
pPageFirst page accessed.
pOffsetByte offset in first page.
