RTEMS 6.1
dosfs Directory Reference
file  fat.c
 Low-level Operations on a Volume with a DOSFS FAT filesystem.
file  fat.h [code]
 Constants/Data Structures/Prototypes on a Volume with FAT Filesystem.
file  fat_fat_operations.c
 General operations on File Allocation Table.
file  fat_fat_operations.h [code]
 Constants/Data Structures/Prototypes for Files Allocation Table.
file  fat_file.c
 General operations on "fat-file".
file  fat_file.h [code]
 Constants/Data Structures/Prototypes for Operations on "fat-file".
file  msdos.h [code]
 The MSDOS Filesystem Constants/Data Structures/Prototypes.
file  msdos_conv.c
 MDOS Date Conversion.
file  msdos_conv_default.c
 Default Converter.
file  msdos_conv_utf8.c
 UTF-8 Converter.
file  msdos_create.c
 Create a new MSDOS FileSystem node.
file  msdos_dir.c
 MSDOS Directory Handlers Implementation.
file  msdos_eval.c
 MSDOS Evaluation Routines.
file  msdos_file.c
 MSDOS File Handlers Implementation.
file  msdos_format.c
 RTEMS MSDOS Format Functionality.
file  msdos_free.c
 Call Fat-File Close Routine.
file  msdos_fsunmount.c
 Shut Down MSDOS FileSystem.
file  msdos_handlers_dir.c
 Directory Handlers Table for MSDOS FileSystem.
file  msdos_handlers_file.c
 File Operations Table for MSDOS FileSystem.
file  msdos_init.c
 Init Routine for MSDOS.
file  msdos_initsupp.c
 MSDOS Filesystem Initialization.
file  msdos_misc.c
 Miscellaneous Routines Implementation for MSDOS FileSystem.
file  msdos_mknod.c
 Routine for Node Creation in MSDOS Filesystem.
file  msdos_rename.c
 Rename a MSDOS FileSystem Node.
file  msdos_rmnod.c
 Remove Node from MSDOS Directory.
file  msdos_statvfs.c
 Obtain MS-DOS filesystem information.
