RTEMS 6.1
Macros | Functions
dbg_console.c File Reference
#include "board.h"
#include <stdint.h>
#define CONSOLE_BAUDRATE   115200
#define CONSOLE_EDBG
#define CONSOLE_ON_USART
#define PIN_USART1_RXD_DBG    {PIO_PA21A_RXD1, PIOA, ID_PIOA, PIO_PERIPH_A, PIO_DEFAULT}
#define PIN_USART1_TXD_DBG    {PIO_PB4D_TXD1, PIOB, ID_PIOB, PIO_PERIPH_D, PIO_DEFAULT}
#define PINS_USART1   PIN_USART1_TXD_DBG, PIN_USART1_RXD_DBG
#define CONSOLE_Usart   USART1
#define CONSOLE_PINS   {PINS_USART1}
#define CONSOLE_ID   ID_USART1
void DBG_Configure (uint32_t baudrate, uint32_t masterClock)
 Configures an USART peripheral with the specified parameters.
void DBG_PutChar (uint8_t c)
 Outputs a character on the UART line.
uint32_t DBG_GetChar (void)
 Input a character from the UART line.
uint32_t DBG_IsRxReady (void)
 Check if there is Input from UART line.
void DBG_DumpFrame (uint8_t *pucFrame, uint32_t dwSize)
void DBG_DumpMemory (uint8_t *pucBuffer, uint32_t dwSize, uint32_t dwAddress)
uint32_t DBG_GetInteger (int32_t *pdwValue)
uint32_t DBG_GetIntegerMinMax (int32_t *pdwValue, int32_t dwMin, int32_t dwMax)
uint32_t DBG_GetHexa32 (uint32_t *pdwValue)
WEAK int puts (const char *ptr)
WEAK char * gets (char *ptr)
Implements UART console.
◆ CONSOLE_BAUDRATE
Console baud rate always using 115200.
◆ CONSOLE_EDBG
EDBG used USART1 as the console, but LON support on USART1 only
◆ CONSOLE_PINS
Pins description corresponding to Rxd,Txd, (Usart pins)
◆ CONSOLE_Usart
Usart Hw interface used by the console (Usart0).
◆ PIN_USART1_RXD_DBG
USART1 pin RX
◆ PIN_USART1_TXD_DBG
USART1 pin TX
◆ DBG_Configure()
void DBG_Configure ( uint32_t  baudrate,
Parameters
baudrateBaudrate at which the USART should operate (in Hz).
masterClockFrequency of the system master clock (in Hz).
◆ DBG_DumpFrame()
void DBG_DumpFrame ( uint8_t *  pucFrame,
uint32_t  dwSize
Displays the content of the given frame on the UART0.
Parameters
pucFramePointer to the frame to dump.
dwSizeBuffer size in bytes.
◆ DBG_DumpMemory()
void DBG_DumpMemory ( uint8_t *  pucBuffer,
uint32_t  dwSize,
uint32_t  dwAddress
Displays the content of the given buffer on the UART0.
Parameters
pucBufferPointer to the buffer to dump.
dwAddressStart address to display
◆ DBG_GetChar()
uint32_t DBG_GetChar ( void  )
Note
This function is synchronous
Returns
character received.
◆ DBG_GetHexa32()
uint32_t DBG_GetHexa32 ( uint32_t *  pdwValue)
Reads an hexadecimal number
Parameters
pdwValuePointer to the uint32_t variable to contain the input value.
◆ DBG_GetInteger()
uint32_t DBG_GetInteger ( int32_t *  pdwValue)
Reads an integer
Parameters
pdwValuePointer to a integer variable to contain the input value.
Returns
success(1) or failure(0)
◆ DBG_GetIntegerMinMax()
uint32_t DBG_GetIntegerMinMax ( int32_t *  pdwValue,
int32_t  dwMin,
int32_t  dwMax
Reads an integer and check the value
Parameters
dwMinMinimum value
dwMaxMaximum value
Returns
◆ DBG_IsRxReady()
uint32_t DBG_IsRxReady ( void  )
Returns
true if there is Input.
◆ DBG_PutChar()
void DBG_PutChar ( uint8_t  c)
Note
This function is synchronous (i.e. uses polling).
Parameters
cCharacter to send.
