RTEMS 6.1
Macros | Functions
cpu.c File Reference
PowerPC Dependent Source. More...
#include <rtems/score/cpuimpl.h>
#define PPC_ASSERT_OFFSET(field, off)
#define PPC_EXC_ASSERT_OFFSET(field, off)
#define PPC_EXC_ASSERT_CANONIC_OFFSET(field)    PPC_EXC_ASSERT_OFFSET(field, field ## _OFFSET)
#define PPC_EXC_MIN_ASSERT_OFFSET(field, off)
#define PPC_EXC_MIN_ASSERT_CANONIC_OFFSET(field)    PPC_EXC_MIN_ASSERT_OFFSET(field, field ## _OFFSET)
 PPC_ASSERT_OFFSET (gpr1, GPR1)
 PPC_ASSERT_OFFSET (msr, MSR)
 PPC_ASSERT_OFFSET (lr, LR)
 PPC_ASSERT_OFFSET (cr, CR)
 PPC_ASSERT_OFFSET (gpr14, GPR14)
 PPC_ASSERT_OFFSET (gpr15, GPR15)
 PPC_ASSERT_OFFSET (gpr16, GPR16)
 PPC_ASSERT_OFFSET (gpr17, GPR17)
 PPC_ASSERT_OFFSET (gpr18, GPR18)
 PPC_ASSERT_OFFSET (gpr19, GPR19)
 PPC_ASSERT_OFFSET (gpr20, GPR20)
 PPC_ASSERT_OFFSET (gpr21, GPR21)
 PPC_ASSERT_OFFSET (gpr22, GPR22)
 PPC_ASSERT_OFFSET (gpr23, GPR23)
 PPC_ASSERT_OFFSET (gpr24, GPR24)
 PPC_ASSERT_OFFSET (gpr25, GPR25)
 PPC_ASSERT_OFFSET (gpr26, GPR26)
 PPC_ASSERT_OFFSET (gpr27, GPR27)
 PPC_ASSERT_OFFSET (gpr28, GPR28)
 PPC_ASSERT_OFFSET (gpr29, GPR29)
 PPC_ASSERT_OFFSET (gpr30, GPR30)
 PPC_ASSERT_OFFSET (gpr31, GPR31)
 PPC_ASSERT_OFFSET (tp, TP)
 PPC_ASSERT_OFFSET (isr_dispatch_disable, ISR_DISPATCH_DISABLE)
 RTEMS_STATIC_ASSERT (sizeof(Context_Control) % PPC_DEFAULT_CACHE_LINE_SIZE==0, ppc_context_size)
 PPC_EXC_ASSERT_OFFSET (EXC_SRR0, SRR0_FRAME_OFFSET)
 PPC_EXC_ASSERT_OFFSET (EXC_SRR1, SRR1_FRAME_OFFSET)
 PPC_EXC_ASSERT_OFFSET (_EXC_number, EXCEPTION_NUMBER_OFFSET)
 PPC_EXC_ASSERT_CANONIC_OFFSET (EXC_CR)
 PPC_EXC_ASSERT_CANONIC_OFFSET (EXC_CTR)
 PPC_EXC_ASSERT_CANONIC_OFFSET (EXC_XER)
 PPC_EXC_ASSERT_CANONIC_OFFSET (EXC_LR)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR0)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR1)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR2)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR3)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR4)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR5)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR6)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR7)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR8)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR9)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR10)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR11)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR12)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR13)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR14)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR15)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR16)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR17)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR18)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR19)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR20)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR21)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR22)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR23)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR24)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR25)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR26)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR27)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR28)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR29)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR30)
 PPC_EXC_ASSERT_CANONIC_OFFSET (GPR31)
 PPC_EXC_MIN_ASSERT_OFFSET (EXC_SRR0, SRR0_FRAME_OFFSET)
 PPC_EXC_MIN_ASSERT_OFFSET (EXC_SRR1, SRR1_FRAME_OFFSET)
 PPC_EXC_MIN_ASSERT_OFFSET (EXC_INTERRUPT_ENTRY_INSTANT, PPC_EXC_INTERRUPT_ENTRY_INSTANT_OFFSET)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (EXC_CR)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (EXC_CTR)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (EXC_XER)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (EXC_LR)
 PPC_EXC_MIN_ASSERT_OFFSET (EXC_INTERRUPT_FRAME, PPC_EXC_INTERRUPT_FRAME_OFFSET)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR0)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR1)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR2)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR3)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR4)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR5)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR6)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR7)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR8)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR9)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR10)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR11)
 PPC_EXC_MIN_ASSERT_CANONIC_OFFSET (GPR12)
 RTEMS_STATIC_ASSERT (CPU_INTERRUPT_FRAME_SIZE % CPU_STACK_ALIGNMENT==0, CPU_INTERRUPT_FRAME_SIZE)
 RTEMS_STATIC_ASSERT (PPC_EXC_FRAME_SIZE % CPU_STACK_ALIGNMENT==0, PPC_EXC_FRAME_SIZE)
 RTEMS_STATIC_ASSERT (sizeof(CPU_Exception_frame)+FRAME_LINK_SPACE<=PPC_EXC_FRAME_SIZE, CPU_Exception_frame)
◆ PPC_ASSERT_OFFSET
#define PPC_ASSERT_OFFSET (   field,
  off
Value:
offsetof(ppc_context, field) + PPC_DEFAULT_CACHE_LINE_SIZE \
== PPC_CONTEXT_OFFSET_ ## off, \
ppc_context_offset_ ## field \
#define RTEMS_STATIC_ASSERT(_cond, _msg)
It is defined if a static analysis run is performed.
Definition: basedefs.h:841
Definition: cpu.h:223
◆ PPC_EXC_ASSERT_OFFSET
#define PPC_EXC_ASSERT_OFFSET (   field,
  off
Value:
offsetof(CPU_Exception_frame, field) + FRAME_LINK_SPACE == off, \
CPU_Exception_frame_offset_ ## field \
The set of registers that specifies the complete processor state.
Definition: cpu.h:446
◆ PPC_EXC_MIN_ASSERT_OFFSET
#define PPC_EXC_MIN_ASSERT_OFFSET (   field,
  off
Value:
offsetof(CPU_Interrupt_frame, field) == off, \
CPU_Interrupt_frame_offset_ ## field \
Interrupt stack frame (ISF).
Definition: cpuimpl.h:64
