RTEMS
6.1
score
cpu
nios2
include
asm.h
1
17
18
* COPYRIGHT:
19
20
* This file is based on similar code found in newlib available
21
* from ftp.cygnus.com. The file which was used had no copyright
22
* notice. This file is freely distributable as long as the source
23
* of the file is noted. This file is:
24
25
* COPYRIGHT (c) 1994-1997.
26
* On-Line Applications Research Corporation (OAR).
27
28
29
#ifndef _RTEMS_ASM_H
30
#define _RTEMS_ASM_H
31
32
33
* Indicate we are in an assembly file and get the basic CPU definitions.
34
35
36
#ifndef ASM
37
#define ASM
38
#endif
39
40
rtems/score/nios2.h
41
52
53
* Recent versions of GNU cpp define variables which indicate the
54
* need for underscores and percents. If not using GNU cpp or
55
* the version does not support this, then you will obviously
56
* have to define these as appropriate.
57
58
59
#ifndef __USER_LABEL_PREFIX__
60
#define __USER_LABEL_PREFIX__ _
61
#endif
62
63
#ifndef __REGISTER_PREFIX__
64
#define __REGISTER_PREFIX__
65
#endif
66
67
rtems/concat.h
68
69
/* Use the right prefix for global labels. */
70
71
#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
72
73
/* Use the right prefix for registers. */
74
75
#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
76
77
78
* define macros for all of the registers on this CPU
79
80
* EXAMPLE: #define d0 REG (d0)
81
82
83
84
* Define macros to handle section beginning and ends.
85
86
87
88
#define BEGIN_CODE_DCL .text
89
#define END_CODE_DCL
90
#define BEGIN_DATA_DCL .data
91
#define END_DATA_DCL
92
#define BEGIN_CODE .text
93
#define END_CODE
94
#define BEGIN_DATA
95
#define END_DATA
96
#define BEGIN_BSS
97
#define END_BSS
98
#define END
99
100
101
* Following must be tailor for a particular flavor of the C compiler.
102
* They may need to put underscores in front of the symbols.
103
104
105
#define PUBLIC(sym) .globl SYM (sym)
106
#define EXTERN(sym) .globl SYM (sym)
107
110
#endif
concat.h
nios2.h
NIOS II Set up Basic CPU Dependency Settings Based on Compiler Settings.
