RTEMS 6.1
nios2.h File Reference
NIOS II Set up Basic CPU Dependency Settings Based on Compiler Settings. More...
#define CPU_NAME   "NIOS2"
#define CPU_MODEL_NAME   "nios2"
This file sets up basic CPU dependency settings based on compiler settings. For example, it can determine if floating point is available. This particular implementation is specific to the NIOS2 port.
