RTEMS 6.1
clockimpl.h
2
12/* COPYRIGHT (c) 1989-2013.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_RTEMS_CLOCKIMPL_H
38#define _RTEMS_RTEMS_CLOCKIMPL_H
39
40#include <rtems/rtems/clock.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif
45
60typedef enum {
66
73
90 const rtems_time_of_day *the_tod,
91 TOD_Ticks_validation ticks_validation
92);
93
105 const rtems_time_of_day *the_tod
106);
107
110#ifdef __cplusplus
111}
112#endif
113
114#endif /* _RTEMS_RTEMS_CLOCKIMPL_H */
This header file defines the Clock Manager API.
rtems_status_code
Definition: status.h:85
The enumerators of this type determine if the ticks member is validated in _TOD_Validate().
Definition: clockimpl.h:60
Watchdog_Interval _TOD_To_seconds(const rtems_time_of_day *the_tod)
TOD to Seconds.
Definition: clocktodtoseconds.c:59
rtems_status_code _TOD_Validate(const rtems_time_of_day *the_tod, TOD_Ticks_validation ticks_validation)
Validates the time of day.
Definition: clocktodvalidate.c:57
@ TOD_ENABLE_TICKS_VALIDATION
Use this option to enable the validation of the ticks member in _TOD_Validate().
Definition: clockimpl.h:71
@ TOD_DISABLE_TICKS_VALIDATION
Use this option to disable the validation of the ticks member in _TOD_Validate().
Definition: clockimpl.h:65
uint32_t Watchdog_Interval
Type is used to specify the length of intervals.
Definition: watchdogticks.h:59
This type represents Classic API calendar times.
Definition: types.h:266
