RTEMS 6.1
console.h
2
12/*
13 * Copyright (C) 2020 embedded brains GmbH & Co. KG
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_CONFDEFS_SIMPLECONSOLE_H
38#define _RTEMS_CONFDEFS_SIMPLECONSOLE_H
39
40#ifndef __CONFIGURATION_TEMPLATE_h
41#error "Do not include this file directly, use <rtems/confdefs.h> instead"
42#endif
43
44#ifdef CONFIGURE_INIT
45
46#if defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER) \
47 && defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER)
48 #error "CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER and CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER are mutually exclusive"
49#endif
50
51#if defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER) \
52 || defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER)
53
54#include <rtems/console.h>
55#include <rtems/sysinit.h>
56
57#ifdef __cplusplus
58extern "C" {
59#endif
60
61#ifdef CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
64 RTEMS_SYSINIT_DEVICE_DRIVERS,
65 RTEMS_SYSINIT_ORDER_SECOND
66 );
67#endif
68
69#ifdef CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
72 RTEMS_SYSINIT_DEVICE_DRIVERS,
73 RTEMS_SYSINIT_ORDER_SECOND
74 );
75#endif
76
77#ifdef __cplusplus
78}
79#endif
80
81#endif /* CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
82 || CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER */
83
84#endif /* CONFIGURE_INIT */
85
86#endif /* _RTEMS_CONFDEFS_SIMPLECONSOLE_H */
Console Driver for all Boards.
void _Console_simple_task_Initialize(void)
Initializes a simple task console device.
Definition: consolesimpletask.c:217
void _Console_simple_Initialize(void)
Initializes a simple console device.
Definition: consolesimple.c:91
#define RTEMS_SYSINIT_ITEM(handler, module, order)
Creates the system initialization item associated with the handler, module, and order.
Definition: sysinit.h:204
This header file provides the API of the System Initialization Support.
