RTEMS 6.1
alt_qspi.h
1
7/******************************************************************************
8*
9* Copyright 2013 Altera Corporation. All Rights Reserved.
10*
11* Redistribution and use in source and binary forms, with or without
12* modification, are permitted provided that the following conditions are met:
13*
14* 1. Redistributions of source code must retain the above copyright notice,
15* this list of conditions and the following disclaimer.
16*
17* 2. Redistributions in binary form must reproduce the above copyright notice,
18* this list of conditions and the following disclaimer in the documentation
19* and/or other materials provided with the distribution.
20*
21* 3. The name of the author may not be used to endorse or promote products
22* derived from this software without specific prior written permission.
23*
24* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR
25* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
26* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO
27* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
28* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
29* OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
32* IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
33* OF SUCH DAMAGE.
34*
35******************************************************************************/
36
37/******************************************************************************
38*
39* !!!! Customer Be Aware, Exception!!!
40*
41* 1. Qspi Direct Access Mode is not working!
42*
43* This is because the qspi flash memory installed on our DevKit board, Micro
44* part N25Q00xx, 8 Gb, is not completely compatible with our embedded Synopsis
45* QSPI controller IP. Therefore there is no viable direct access code offered
46* in the lib. All the memory rea/write functionality is offered with indirect
47* access only.
48*
49* Should you install a different flash memory part in your custom board, and
50* wondering wether direct access mode works, please contact with us.
51*
52******************************************************************************/
53
58#ifndef __ALT_QSPI_H__
59#define __ALT_QSPI_H__
60
61#include <bsp/hwlib.h>
62
63#ifdef __cplusplus
64extern "C"
65{
66#endif /* __cplusplus */
67
68/******************************************************************************/
80/******************************************************************************/
89/******************************************************************************/
108
109/******************************************************************************/
120
121/******************************************************************************/
133
134/******************************************************************************/
142
143/******************************************************************************/
158{
168
178
183
189
194
200
205
217
225
233
241
249
255
257
258/******************************************************************************/
271uint32_t alt_qspi_int_status_get(void);
272
273/******************************************************************************/
289ALT_STATUS_CODE alt_qspi_int_clear(const uint32_t mask);
290
291/******************************************************************************/
316ALT_STATUS_CODE alt_qspi_int_disable(const uint32_t mask);
317
318/******************************************************************************/
343ALT_STATUS_CODE alt_qspi_int_enable(const uint32_t mask);
344
345/******************************************************************************/
351bool alt_qspi_is_idle(void);
352
355/******************************************************************************/
383/******************************************************************************/
404ALT_STATUS_CODE alt_qspi_read(void * dest, uint32_t src, size_t size);
405
406/******************************************************************************/
427ALT_STATUS_CODE alt_qspi_write(uint32_t dest, const void * src, size_t size);
428
431/******************************************************************************/
461/******************************************************************************/
467typedef enum ALT_QSPI_MODE_e
468{
480
481/******************************************************************************/
488{
495
496/******************************************************************************/
501{
519
520/******************************************************************************/
528{
529 uint32_t block_size;
534 uint32_t page_size;
539 uint32_t addr_size;
563
564/******************************************************************************/
570{
578
579/******************************************************************************/
584{
592
593/******************************************************************************/
603{
613 uint32_t cs_da;
621 uint32_t cs_dads;
634 uint32_t cs_eot;
647 uint32_t cs_sot;
659 uint32_t rd_datacap;
674
675/******************************************************************************/
683{
684 uint32_t op_code;
714 uint32_t dummy_cycles;
720
721/******************************************************************************/
728
729/******************************************************************************/
743
744/******************************************************************************/
759
760/******************************************************************************/
790 const ALT_QSPI_CS_MODE_t cs_mode);
791
792/******************************************************************************/
803
804/******************************************************************************/
815
816/******************************************************************************/
823uint32_t alt_qspi_mode_bit_config_get(void);
824
825/******************************************************************************/
841ALT_STATUS_CODE alt_qspi_mode_bit_config_set(const uint32_t mode_bits);
842
843/******************************************************************************/
856
857/******************************************************************************/
869
870/******************************************************************************/
883
884/******************************************************************************/
901
902/******************************************************************************/
915
916/******************************************************************************/
933
934/******************************************************************************/
949
950/******************************************************************************/
972
975/******************************************************************************/
1000/******************************************************************************/
1008
1009/******************************************************************************/
1017
1018/******************************************************************************/
1027uint32_t alt_qspi_ahb_remap_address_get(void);
1028
1029/******************************************************************************/
1045ALT_STATUS_CODE alt_qspi_ahb_remap_address_set(const uint32_t ahb_remap_addr);
1046
1047/******************************************************************************/
1059
1060/******************************************************************************/
1073
1076/******************************************************************************/
1093/******************************************************************************/
1126ALT_STATUS_CODE alt_qspi_indirect_read_start(const uint32_t flash_addr,
1127 const size_t num_bytes);
1128
1129/******************************************************************************/
1138
1139/******************************************************************************/
1147
1148/******************************************************************************/
1159
1160/******************************************************************************/
1172
1173/******************************************************************************/
1190
1191/******************************************************************************/
1202
1203/******************************************************************************/
1238ALT_STATUS_CODE alt_qspi_indirect_write_start(const uint32_t flash_addr,
1239 const size_t num_bytes);
1240
1241/******************************************************************************/
1250
1251/******************************************************************************/
1259
1260/******************************************************************************/
1271
1272/******************************************************************************/
1284
1285/******************************************************************************/
1302
1303/******************************************************************************/
1316
1317/******************************************************************************/
1339#define ALT_QSPI_SRAM_FIFO_SIZE (512)
1340
1341/*
1342 * The size of the onboard SRAM in entries. Each entry is word (32-bit) sized.
1343 */
1344#define ALT_QSPI_SRAM_FIFO_ENTRY_COUNT (512 / sizeof(uint32_t))
1345
1346/******************************************************************************/
1367uint32_t alt_qspi_sram_partition_get(void);
1368
1369/******************************************************************************/
1384ALT_STATUS_CODE alt_qspi_sram_partition_set(const uint32_t read_part_size);
1385
1390/******************************************************************************/
1398/******************************************************************************/
1411ALT_STATUS_CODE alt_qspi_erase_subsector(const uint32_t addr);
1412
1413/******************************************************************************/
1426ALT_STATUS_CODE alt_qspi_erase_sector(const uint32_t addr);
1427
1428/******************************************************************************/
1436
1439/******************************************************************************/
1464/******************************************************************************/
1472
1473/******************************************************************************/
1484
1485/******************************************************************************/
1503ALT_STATUS_CODE alt_qspi_dma_config_get(uint32_t * single_type_sz,
1504 uint32_t * burst_type_sz);
1505
1506/******************************************************************************/
1530ALT_STATUS_CODE alt_qspi_dma_config_set(const uint32_t single_type_sz,
1531 const uint32_t burst_type_sz);
1532
1533
1538#ifdef __cplusplus
1539}
1540#endif /* __cplusplus */
1541#endif /* __ALT_QSPI_H__ */
Definition: alt_qspi.c:1947
Definition: alt_qspi.c:1937
ALT_STATUS_CODE alt_qspi_disable(void)
Definition: alt_qspi.c:415
ALT_STATUS_CODE alt_qspi_enable(void)
Definition: alt_qspi.c:422
Definition: alt_qspi.c:525
Definition: alt_qspi.c:565
ALT_QSPI_INT_STATUS_e
Definition: alt_qspi.h:158
Definition: alt_qspi.c:546
enum ALT_QSPI_INT_STATUS_e ALT_QSPI_INT_STATUS_t
ALT_STATUS_CODE alt_qspi_uninit(void)
Definition: alt_qspi.c:407
Definition: alt_qspi.c:586
ALT_STATUS_CODE alt_qspi_init(void)
Definition: alt_qspi.c:312
Definition: alt_qspi.c:532
@ ALT_QSPI_INT_STATUS_ILL_AHB_ACCESS
Definition: alt_qspi.h:199
@ ALT_QSPI_INT_STATUS_IDAC_WTRMK_TRIG
Definition: alt_qspi.h:204
@ ALT_QSPI_INT_STATUS_IDAC_OP_COMPLETE
Definition: alt_qspi.h:182
@ ALT_QSPI_INT_STATUS_TX_FIFO_NOT_FULL
Definition: alt_qspi.h:224
@ ALT_QSPI_INT_STATUS_RX_FIFO_FULL
Definition: alt_qspi.h:248
@ ALT_QSPI_INT_STATUS_RX_OVF
Definition: alt_qspi.h:216
@ ALT_QSPI_INT_STATUS_IDAC_OP_REJECT
Definition: alt_qspi.h:188
@ ALT_QSPI_INT_STATUS_IDAC_RD_FULL
Definition: alt_qspi.h:254
@ ALT_QSPI_INT_STATUS_TX_FIFO_FULL
Definition: alt_qspi.h:232
@ ALT_QSPI_INT_STATUS_WR_PROT_VIOL
Definition: alt_qspi.h:193
@ ALT_QSPI_INT_STATUS_UFL
Definition: alt_qspi.h:177
@ ALT_QSPI_INT_STATUS_RX_FIFO_NOT_EMPTY
Definition: alt_qspi.h:240
@ ALT_QSPI_INT_STATUS_MODE_FAIL
Definition: alt_qspi.h:167
ALT_STATUS_CODE alt_qspi_ahb_address_remap_enable(void)
Definition: alt_qspi.c:1647
Definition: alt_qspi.c:1619
ALT_STATUS_CODE alt_qspi_ahb_address_remap_disable(void)
Definition: alt_qspi.c:1638
ALT_STATUS_CODE alt_qspi_direct_disable(void)
Definition: alt_qspi.c:1601
Definition: alt_qspi.c:1625
ALT_STATUS_CODE alt_qspi_direct_enable(void)
Definition: alt_qspi.c:1610
enum ALT_QSPI_CS_MODE_e ALT_QSPI_CS_MODE_t
ALT_STATUS_CODE alt_qspi_device_size_config_get(ALT_QSPI_DEV_SIZE_CONFIG_t *cfg)
Definition: alt_qspi.c:1245
ALT_QSPI_CS_MODE_e
Definition: alt_qspi.h:488
ALT_STATUS_CODE alt_qspi_timing_config_set(const ALT_QSPI_TIMING_CONFIG_t *cfg)
Definition: alt_qspi.c:1524
ALT_STATUS_CODE alt_qspi_chip_select_config_set(const uint32_t cs, const ALT_QSPI_CS_MODE_t cs_mode)
Definition: alt_qspi.c:1167
enum ALT_QSPI_CLK_POLARITY_e ALT_QSPI_CLK_POLARITY_t
ALT_QSPI_BAUD_DIV_t alt_qspi_baud_rate_div_get(void)
Definition: alt_qspi.c:1134
ALT_STATUS_CODE alt_qspi_chip_select_config_get(uint32_t *cs, ALT_QSPI_CS_MODE_t *cs_mode)
Definition: alt_qspi.c:1156
Definition: alt_qspi.h:584
enum ALT_QSPI_BAUD_DIV_e ALT_QSPI_BAUD_DIV_t
ALT_STATUS_CODE alt_qspi_timing_config_get(ALT_QSPI_TIMING_CONFIG_t *cfg)
Definition: alt_qspi.c:1504
enum ALT_QSPI_CLK_PHASE_e ALT_QSPI_CLK_PHASE_t
struct ALT_QSPI_DEV_SIZE_CONFIG_s ALT_QSPI_DEV_SIZE_CONFIG_t
struct ALT_QSPI_DEV_INST_CONFIG_s ALT_QSPI_DEV_INST_CONFIG_t
ALT_STATUS_CODE alt_qspi_device_size_config_set(const ALT_QSPI_DEV_SIZE_CONFIG_t *cfg)
Definition: alt_qspi.c:1274
Definition: alt_qspi.c:1216
enum ALT_QSPI_MODE_e ALT_QSPI_MODE_t
Definition: alt_qspi.h:570
ALT_QSPI_MODE_e
Definition: alt_qspi.h:468
ALT_STATUS_CODE alt_qspi_baud_rate_div_set(const ALT_QSPI_BAUD_DIV_t baud_rate_div)
Definition: alt_qspi.c:1140
struct ALT_QSPI_TIMING_CONFIG_s ALT_QSPI_TIMING_CONFIG_t
ALT_STATUS_CODE alt_qspi_device_read_config_get(ALT_QSPI_DEV_INST_CONFIG_t *cfg)
Definition: alt_qspi.c:1325
ALT_STATUS_CODE alt_qspi_mode_bit_disable(void)
Definition: alt_qspi.c:1198
ALT_QSPI_BAUD_DIV_e
Definition: alt_qspi.h:501
ALT_STATUS_CODE alt_qspi_mode_bit_enable(void)
Definition: alt_qspi.c:1207
Definition: alt_qspi.c:1223
ALT_STATUS_CODE alt_qspi_device_read_config_set(const ALT_QSPI_DEV_INST_CONFIG_t *cfg)
Definition: alt_qspi.c:1339
ALT_STATUS_CODE alt_qspi_device_write_config_get(ALT_QSPI_DEV_INST_CONFIG_t *cfg)
Definition: alt_qspi.c:1410
ALT_STATUS_CODE alt_qspi_device_write_config_set(const ALT_QSPI_DEV_INST_CONFIG_t *cfg)
Definition: alt_qspi.c:1427
@ ALT_QSPI_CS_MODE_SINGLE_SELECT
Definition: alt_qspi.h:489
@ ALT_QSPI_CS_MODE_DECODE
Definition: alt_qspi.h:491
@ ALT_QSPI_CLK_POLARITY_LOW
Definition: alt_qspi.h:585
@ ALT_QSPI_CLK_POLARITY_HIGH
Definition: alt_qspi.h:588
@ ALT_QSPI_CLK_PHASE_ACTIVE
Definition: alt_qspi.h:571
@ ALT_QSPI_CLK_PHASE_INACTIVE
Definition: alt_qspi.h:574
@ ALT_QSPI_MODE_DUAL
Definition: alt_qspi.h:473
@ ALT_QSPI_MODE_QUAD
Definition: alt_qspi.h:476
@ ALT_QSPI_MODE_SINGLE
Definition: alt_qspi.h:469
@ ALT_QSPI_BAUD_DIV_8
Definition: alt_qspi.h:505
@ ALT_QSPI_BAUD_DIV_12
Definition: alt_qspi.h:507
@ ALT_QSPI_BAUD_DIV_26
Definition: alt_qspi.h:514
@ ALT_QSPI_BAUD_DIV_10
Definition: alt_qspi.h:506
@ ALT_QSPI_BAUD_DIV_6
Definition: alt_qspi.h:504
@ ALT_QSPI_BAUD_DIV_28
Definition: alt_qspi.h:515
@ ALT_QSPI_BAUD_DIV_20
Definition: alt_qspi.h:511
@ ALT_QSPI_BAUD_DIV_30
Definition: alt_qspi.h:516
@ ALT_QSPI_BAUD_DIV_14
Definition: alt_qspi.h:508
@ ALT_QSPI_BAUD_DIV_32
Definition: alt_qspi.h:517
@ ALT_QSPI_BAUD_DIV_18
Definition: alt_qspi.h:510
Definition: alt_qspi.h:502
@ ALT_QSPI_BAUD_DIV_22
Definition: alt_qspi.h:512
@ ALT_QSPI_BAUD_DIV_16
Definition: alt_qspi.h:509
@ ALT_QSPI_BAUD_DIV_4
Definition: alt_qspi.h:503
@ ALT_QSPI_BAUD_DIV_24
Definition: alt_qspi.h:513
ALT_STATUS_CODE alt_qspi_dma_disable(void)
Definition: alt_qspi.c:2118
ALT_STATUS_CODE alt_qspi_dma_config_set(const uint32_t single_type_sz, const uint32_t burst_type_sz)
Definition: alt_qspi.c:2171
ALT_STATUS_CODE alt_qspi_dma_config_get(uint32_t *single_type_sz, uint32_t *burst_type_sz)
Definition: alt_qspi.c:2136
ALT_STATUS_CODE alt_qspi_dma_enable(void)
Definition: alt_qspi.c:2127
Definition: alt_qspi.c:2005
Definition: alt_qspi.c:1988
ALT_STATUS_CODE alt_qspi_erase_chip(void)
Definition: alt_qspi.c:2034
ALT_STATUS_CODE alt_qspi_write(uint32_t dest, const void *src, size_t size)
Definition: alt_qspi.c:809
ALT_STATUS_CODE alt_qspi_read(void *dest, uint32_t src, size_t size)
Definition: alt_qspi.c:694
ALT_STATUS_CODE alt_qspi_indirect_write_watermark_set(const uint32_t watermark)
Definition: alt_qspi.c:1913
ALT_STATUS_CODE alt_qspi_indirect_read_start(const uint32_t flash_addr, const size_t num_bytes)
Definition: alt_qspi.c:1669
ALT_STATUS_CODE alt_qspi_indirect_write_start(const uint32_t flash_addr, const size_t num_bytes)
Definition: alt_qspi.c:1793
ALT_STATUS_CODE alt_qspi_indirect_read_cancel(void)
Definition: alt_qspi.c:1737
uint32_t alt_qspi_indirect_read_watermark_get(void)
Definition: alt_qspi.c:1754
bool alt_qspi_indirect_read_is_complete(void)
Definition: alt_qspi.c:1774
ALT_STATUS_CODE alt_qspi_indirect_write_finish(void)
Definition: alt_qspi.c:1869
uint32_t alt_qspi_indirect_write_watermark_get(void)
Definition: alt_qspi.c:1907
ALT_STATUS_CODE alt_qspi_indirect_read_finish(void)
Definition: alt_qspi.c:1732
ALT_STATUS_CODE alt_qspi_indirect_read_watermark_set(const uint32_t watermark)
Definition: alt_qspi.c:1760
ALT_STATUS_CODE alt_qspi_indirect_write_cancel(void)
Definition: alt_qspi.c:1878
uint32_t alt_qspi_indirect_write_fill_level(void)
Definition: alt_qspi.c:1899
bool alt_qspi_indirect_write_is_complete(void)
Definition: alt_qspi.c:1927
uint32_t alt_qspi_indirect_read_fill_level(void)
Definition: alt_qspi.c:1746
int32_t ALT_STATUS_CODE
Definition: hwlib.h:60
Definition: alt_qspi.h:683
ALT_QSPI_MODE_t inst_type
Definition: alt_qspi.h:687
ALT_QSPI_MODE_t data_xfer_type
Definition: alt_qspi.h:705
Definition: alt_qspi.h:714
ALT_QSPI_MODE_t addr_xfer_type
Definition: alt_qspi.h:696
uint32_t op_code
Definition: alt_qspi.h:684
Definition: alt_qspi.h:528
uint32_t upper_wrprot_block
Definition: alt_qspi.h:550
bool wrprot_enable
Definition: alt_qspi.h:556
uint32_t addr_size
Definition: alt_qspi.h:539
uint32_t page_size
Definition: alt_qspi.h:534
uint32_t lower_wrprot_block
Definition: alt_qspi.h:544
uint32_t block_size
Definition: alt_qspi.h:529
Definition: alt_qspi.h:603
uint32_t cs_da
Definition: alt_qspi.h:613
uint32_t cs_dads
Definition: alt_qspi.h:621
uint32_t cs_sot
Definition: alt_qspi.h:647
uint32_t rd_datacap
Definition: alt_qspi.h:659
ALT_QSPI_CLK_POLARITY_t clk_pol
Definition: alt_qspi.h:609
ALT_QSPI_CLK_PHASE_t clk_phase
Definition: alt_qspi.h:604
uint32_t cs_eot
Definition: alt_qspi.h:634
