RTEMS 6.1
clocktick.c File Reference
This source file contains the implementation of rtems_clock_tick(). More...
#include <rtems/rtems/clock.h>
#include <rtems/score/timecounter.h>
rtems_status_code rtems_clock_tick (void)
 Announces a clock tick.
◆ rtems_clock_tick()
rtems_status_code rtems_clock_tick ( void  )
Notes
The directive is a legacy interface. It should not be called by applications directly. A Clock Driver may call this directive.
Constraints
The following constraints apply to this directive:
  • The directive may be called from within interrupt context.
  • The directive may be called from within device driver initialization context.
  • The directive may be called from within task context.
