RTEMS 6.1
This source file contains the implementation of rtems_chain_append(), rtems_chain_append_with_empty_check(), rtems_chain_extract(), rtems_chain_get(), rtems_chain_get_with_empty_check(), rtems_chain_insert(), rtems_chain_prepend(), and rtems_chain_prepend_with_empty_check(). More...
| void | rtems_chain_extract (rtems_chain_node *node) |
| Extract the specified node from a chain. | |
| rtems_chain_node * | rtems_chain_get (rtems_chain_control *chain) |
| Obtain the first node on a chain. | |
| void | rtems_chain_insert (rtems_chain_node *after_node, rtems_chain_node *node) |
| Insert a node on a chain. | |
| void | rtems_chain_append (rtems_chain_control *chain, rtems_chain_node *node) |
| Append a node on the end of a chain. | |
| void | rtems_chain_prepend (rtems_chain_control *chain, rtems_chain_node *node) |
| Prepend a node. | |
| bool | rtems_chain_append_with_empty_check (rtems_chain_control *chain, rtems_chain_node *node) |
| Checks if the chain is empty and appends the node. | |
| bool | rtems_chain_prepend_with_empty_check (rtems_chain_control *chain, rtems_chain_node *node) |
| Checks if the chain is empty and prepends the node. | |
| bool | rtems_chain_get_with_empty_check (rtems_chain_control *chain, rtems_chain_node **node) |
| Tries to get the first node and check if the chain is empty afterwards. | |
