RTEMS 6.1
chainappendnotify.c File Reference
This source file contains the implementation of rtems_chain_append_with_notification(). More...
#include <rtems/chain.h>
rtems_status_code rtems_chain_append_with_notification (rtems_chain_control *chain, rtems_chain_node *node, rtems_id task, rtems_event_set events)
 Appends the node to the chain and sends the events to the task if the chain was empty before the append.
