RTEMS 6.1
Macros | Typedefs
cbs.h File Reference
Constants and Structures Associated with the CBS library in RTEMS. More...
#include <rtems/score/schedulercbs.h>
#define RTEMS_CBS_OK   SCHEDULER_CBS_OK
#define RTEMS_CBS_ERROR_GENERIC   SCHEDULER_CBS_ERROR_GENERIC
#define RTEMS_CBS_ERROR_NO_MEMORY   SCHEDULER_CBS_ERROR_NO_MEMORY
#define RTEMS_CBS_ERROR_INVALID_PARAMETER   SCHEDULER_CBS_ERROR_INVALID_PARAM
#define RTEMS_CBS_ERROR_UNAUTHORIZED   SCHEDULER_CBS_ERROR_UNAUTHORIZED
#define RTEMS_CBS_ERROR_UNIMPLEMENTED   SCHEDULER_CBS_ERROR_UNIMPLEMENTED
#define RTEMS_CBS_ERROR_MISSING_COMPONENT   SCHEDULER_CBS_ERROR_MISSING_COMPONENT
#define RTEMS_CBS_ERROR_INCONSISTENT_STATE   SCHEDULER_CBS_ERROR_INCONSISTENT_STATE
#define RTEMS_CBS_ERROR_SYSTEM_OVERLOAD   SCHEDULER_CBS_ERROR_SYSTEM_OVERLOAD
#define RTEMS_CBS_ERROR_INTERNAL_ERROR   SCHEDULER_CBS_ERROR_INTERNAL_ERROR
#define RTEMS_CBS_ERROR_NOT_FOUND   SCHEDULER_CBS_ERROR_NOT_FOUND
#define RTEMS_CBS_ERROR_FULL   SCHEDULER_CBS_ERROR_FULL
#define RTEMS_CBS_ERROR_EMPTY   SCHEDULER_CBS_ERROR_EMPTY
#define RTEMS_CBS_ERROR_NOSERVER   SCHEDULER_CBS_ERROR_NOSERVER
typedef Scheduler_CBS_Budget_overrun rtems_cbs_budget_overrun
typedef Scheduler_CBS_Server_id rtems_cbs_server_id
typedef Scheduler_CBS_Parameters rtems_cbs_parameters
This include file contains all the constants and structures associated with the CBS library in RTEMS.
Typedef Documentation
◆ rtems_cbs_budget_overrun
Callback function invoked when a budget overrun of a task occurs.
◆ rtems_cbs_parameters
Server parameters.
◆ rtems_cbs_server_id
Server id.
