RTEMS 6.1
Capture Implementation file. More...
#include "capture.h"Go to the source code of this file.
| void | rtems_capture_set_extension_index (int index) |
| Capture set extension index. | |
| int | rtems_capture_get_extension_index (void) |
| Capture get extension index. | |
| uint32_t | rtems_capture_get_flags (void) |
| Capture get flags. | |
| void | rtems_capture_set_flags (uint32_t mask) |
| Capture set flags. | |
| rtems_status_code | rtems_capture_user_extension_open (void) |
| Capture user extension open. | |
| rtems_status_code | rtems_capture_user_extension_close (void) |
| Capture user extension close. | |
| bool | rtems_capture_trigger_fired (rtems_tcb *ft, rtems_tcb *tt, uint32_t events) |
| Capture check trigger. | |
| void | rtems_capture_print_trace_records (int total, bool csv) |
| Capture print trace records. | |
| void | rtems_capture_print_timestamp (uint64_t uptime) |
| Capture print timestamp. | |
| void | rtems_capture_print_record_task (int cpu, const rtems_capture_record *rec, const rtems_capture_task_record *task_rec) |
| Capture print record task. | |
| void | rtems_capture_print_record_capture (int cpu, const rtems_capture_record *rec, uint64_t diff, const rtems_name *name) |
| Capture print capture record. | |
| void | rtems_capture_print_watch_list (void) |
| Capture print watch list. | |
This file contains an interface between the capture engine and capture user extension methods.
| int rtems_capture_get_extension_index | ( | void | ) |
This function rturns the extension index for the capture engine.
| This | method returns the extension index. |
| uint32_t rtems_capture_get_flags | ( | void | ) |
Capture get flags.
This function gets the current flag settings for the capture engine.
| This | method returns the global capture flags. |
| void rtems_capture_print_record_capture | ( | int | cpu, |
| const rtems_capture_record * | rec, | ||
| uint64_t | diff, | ||
| const rtems_name * | name | ||
This function prints a user extension capture record.
| [in] | cpu | specifies the cpu the cpu the record was logged on. |
| [in] | rec | specifies the record. |
| [in] | diff | specifies the time between this and the last capture record. |
| [in] | name | specifies the name of the task, NULL if none. |
| [in] | task_count | number of tasks to search for. |
| void rtems_capture_print_record_task | ( | int | cpu, |
| const rtems_capture_task_record * | task_rec | ||
This function prints a capture record task. This record contains information to identify a task. It is refrenced in other records by the task id.
| [in] | rec | specifies the task record. |
| void rtems_capture_print_timestamp | ( | uint64_t | uptime | ) |
This function prints uptime in a timestamp format.
| [in] | uptime | specifies the timestamp to print |
| void rtems_capture_print_trace_records | ( | int | total, |
| bool | csv | ||
This function reads, prints and releases up to total trace records in either a csv format or an ascii table format.
| [in] | total | specifies the number of records to print |
| [in] | csv | specifies a comma seperated value format |
| void rtems_capture_print_watch_list | ( | void | ) |
This function prints a capture watch list
| void rtems_capture_set_extension_index | ( | int | index | ) |
This function is used to set the extension index for the capture engine.
| [in] | index | specifies the extension index to be used for capture engine data. |
| void rtems_capture_set_flags | ( | uint32_t | mask | ) |
Capture set flags.
This function sets a flag in the capture engine
| [in] | mask | specifies the flag to set |
This function checks if we have triggered or if this event is a cause of a trigger.
| [in] | ft | specifies specifices the capture from task |
| [in] | tt | specifies specifices the capture to task |
| [in] | events | specifies the events |
| This | method returns true if we have triggered or if the event is a cause of a trigger. |
| rtems_status_code rtems_capture_user_extension_close | ( | void | ) |
This function closes the capture user extensions.
| This | method returns RTEMS_SUCCESSFUL upon a successful delete of the user extensions. |
| rtems_status_code rtems_capture_user_extension_open | ( | void | ) |
This function creates the capture user extensions.
| This | method returns RTEMS_SUCCESSFUL upon successful creation of the user extensions. |
