RTEMS 6.1
RTEMS Performance Monitoring and Measurement Framework. More...
#include <ctype.h>#include <stdlib.h>#include <stdio.h>#include <string.h>#include <inttypes.h>#include <rtems.h>#include <rtems/capture-cli.h>#include <rtems/captureimpl.h>#include <rtems/monitor.h>#include <rtems/cpuuse.h>Data Structures | |
| struct | rtems_capture_cli_triggers |
| #define | RC_UNUSED RTEMS_UNUSED |
| #define | RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS (20) |
| #define | RTEMS_CAPTURE_CLI_TRIGGERS_NUM (sizeof (rtems_capture_cli_trigger) / sizeof (rtems_capture_cli_triggers)) |
Typedefs | |
| typedef struct rtems_capture_cli_triggers | rtems_capture_cli_triggers |
| typedef enum rtems_capture_cli_trig_state | rtems_capture_cli_trig_state |
Enumerations | |
| enum | rtems_capture_cli_trig_state { trig_type , trig_to , trig_from_from , trig_from } |
| rtems_status_code | rtems_capture_cli_init (rtems_capture_timestamp timestamp) |
This is the Target Interface Command Line Interface. You need start the RTEMS monitor.
| rtems_status_code rtems_capture_cli_init | ( | rtems_capture_timestamp | timestamp | ) |
This function initialises the command line interface to the capture engine.
