RTEMS 6.1
This header file contains the implementation of the Cache Manager. More...
| void | rtems_cache_flush_multiple_data_lines (const void *d_addr, size_t n_bytes) |
| Flushes the data cache lines covering the memory area. | |
| void | rtems_cache_invalidate_multiple_data_lines (const void *d_addr, size_t n_bytes) |
| Invalidates the data cache lines covering the memory area. | |
| void | rtems_cache_flush_entire_data (void) |
| Flushes the entire data cache. | |
| void | rtems_cache_invalidate_entire_data (void) |
| Invalidates the entire data cache. | |
| size_t | rtems_cache_get_data_line_size (void) |
| Gets the data cache line size in bytes. | |
| size_t | rtems_cache_get_data_cache_size (uint32_t level) |
| Gets the data cache size in bytes for the cache level. | |
| void | rtems_cache_freeze_data (void) |
| Freezes the data caches. | |
| void | rtems_cache_unfreeze_data (void) |
| Unfreezes the data cache. | |
| void | rtems_cache_enable_data (void) |
| Enables the data cache. | |
| void | rtems_cache_disable_data (void) |
| Disables the data cache. | |
| void | rtems_cache_invalidate_multiple_instruction_lines (const void *i_addr, size_t n_bytes) |
| Invalidates the instruction cache lines covering the memory area. | |
| void | rtems_cache_invalidate_entire_instruction (void) |
| Invalidates the entire instruction cache. | |
| size_t | rtems_cache_get_instruction_line_size (void) |
| Gets the instruction cache line size in bytes. | |
| size_t | rtems_cache_get_instruction_cache_size (uint32_t level) |
| Gets the instruction cache size in bytes for the cache level. | |
| void | rtems_cache_freeze_instruction (void) |
| Freezes the instruction caches. | |
| void | rtems_cache_unfreeze_instruction (void) |
| Unfreezes the instruction cache. | |
| void | rtems_cache_enable_instruction (void) |
| Enables the instruction cache. | |
| void | rtems_cache_disable_instruction (void) |
| Disables the instruction cache. | |
| size_t | rtems_cache_get_maximal_line_size (void) |
| Gets the maximal cache line size in bytes of all caches (data, instruction, or unified). | |
| void | rtems_cache_instruction_sync_after_code_change (const void *code_addr, size_t n_bytes) |
| Ensures necessary synchronization required after code changes. | |
The functions in this file implement the API to the Cache Manager. This file is intended to be included in a cache implemention source file provided by the architecture or BSP, e.g.
In this file a couple of defines and inline functions may be provided and afterwards this file is included, e.g.
The cache implementation source file shall define
to enable the data cache support.
to enable the instruction cache support.
if it provides cache maintenance functions which operate on multiple lines. Otherwise a generic loop with single line operations will be used. It is strongly recommended to provide the implementation in terms of static inline functions for performance reasons.
if it provides functions to get the data and instruction cache sizes by level.
if special instructions must be used to synchronize the instruction caches after a code change.
if an external implementation of rtems_cache_disable_data() is provided, e.g. as an implementation in assembly code.
if the hardware provides no instruction cache snooping and the instruction cache invalidation needs software support.
The functions below are implemented with inline routines found in the cache implementation source file for each architecture or BSP. In the event that not support for a specific function for a cache is provided, the API routine does nothing (but does exist).
| void rtems_cache_freeze_data | ( | void | ) |
The following constraints apply to this directive:
| void rtems_cache_freeze_instruction | ( | void | ) |
| void rtems_cache_unfreeze_data | ( | void | ) |
| void rtems_cache_unfreeze_instruction | ( | void | ) |
