RTEMS 6.1
Global BSP definitions. More...
#include <libcpu/powerpc-utility.h>#include <bspopts.h>#include <rtems.h>#include <rtems/irq.h>#include <mpc8xx.h>#include <mpc8xx/cpm.h>#include <mpc8xx/mmu.h>#include <mpc8xx/console.h>#include <bsp/vectors.h>#include <bsp/tqm.h>#include <bsp/default-initial-extension.h>Go to the source code of this file.
| LINKER_SYMBOL (TopRamReserved) | |
| LINKER_SYMBOL (bsp_ram_start) | |
| LINKER_SYMBOL (bsp_ram_end) | |
| LINKER_SYMBOL (bsp_ram_size) | |
| LINKER_SYMBOL (bsp_rom_start) | |
| LINKER_SYMBOL (bsp_rom_end) | |
| LINKER_SYMBOL (bsp_rom_size) | |
| LINKER_SYMBOL (bsp_section_text_start) | |
| LINKER_SYMBOL (bsp_section_text_end) | |
| LINKER_SYMBOL (bsp_section_text_size) | |
| LINKER_SYMBOL (bsp_section_data_start) | |
| LINKER_SYMBOL (bsp_section_data_end) | |
| LINKER_SYMBOL (bsp_section_data_size) | |
| LINKER_SYMBOL (bsp_section_bss_start) | |
| LINKER_SYMBOL (bsp_section_bss_end) | |
| LINKER_SYMBOL (bsp_section_bss_size) | |
| LINKER_SYMBOL (bsp_work_area_start) | |
| int | BSP_disconnect_clock_handler (void) |
| int | BSP_connect_clock_handler (rtems_irq_hdl) |
| char | serial_getc (void) |
| int | serial_tstc (void) |
| void | serial_init (void) |
| int | mbx8xx_console_get_configuration (void) |
| void | _InitTQM8xx (void) |
| rtems_status_code | bsp_register_spi (void) |
| void * | bsp_idle_thread (uintptr_t ignored) |
| Optimized idle task. | |
| void | cpu_init (void) |
| uint32_t | BSP_bus_frequency |
| uint32_t | bsp_clock_speed |
| System clock frequency. | |
