RTEMS 6.1
vectors.h
1
10/*
11 * Copyright (C) 1999 Eric Valette (valette@crf.canon.fr)
12 * Canon Centre Recherche France.
13 *
14 * Copyright (C) 2007 Till Straumann <strauman@slac.stanford.edu>
15 *
16 * Copyright (C) 2009 embedded brains GmbH & Co. KG
17 *
18 * Enhanced by Jay Kulpinski <jskulpin@eng01.gdds.com>
19 * to support 603, 603e, 604, 604e exceptions
20 *
21 * Moved to "libcpu/powerpc/new-exceptions" and consolidated
22 * by Thomas Doerfler <Thomas.Doerfler@embedded-brains.de>
23 * to be common for all PPCs with new exceptions.
24 *
25 * Derived from file "libcpu/powerpc/new-exceptions/raw_exception.h".
26 * Derived from file "libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_bspsupp.h".
27 *
28 * The license and distribution terms for this file may be
29 * found in the file LICENSE in this distribution or at
30 * http://www.rtems.org/license/LICENSE.
31 */
32
33/* DO NOT INTRODUCE #ifdef <cpu_flavor> in this file */
34
35#ifndef LIBCPU_VECTORS_H
36#define LIBCPU_VECTORS_H
37
38#include <bspopts.h>
39#include <rtems/score/cpuimpl.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif
45
54#define ASM_RESET_VECTOR 0x01
55#define ASM_MACH_VECTOR 0x02
56#define ASM_PROT_VECTOR 0x03
57#define ASM_ISI_VECTOR 0x04
58#define ASM_EXT_VECTOR 0x05
59#define ASM_ALIGN_VECTOR 0x06
60#define ASM_PROG_VECTOR 0x07
61#define ASM_FLOAT_VECTOR 0x08
62#define ASM_DEC_VECTOR 0x09
63#define ASM_SYS_VECTOR 0x0C
64#define ASM_TRACE_VECTOR 0x0D
65
66#define ASM_PPC405_APU_UNAVAIL_VECTOR ASM_60X_VEC_ASSIST_VECTOR
67
68#define ASM_8XX_FLOATASSIST_VECTOR 0x0E
69#define ASM_8XX_SOFTEMUL_VECTOR 0x10
70#define ASM_8XX_ITLBMISS_VECTOR 0x11
71#define ASM_8XX_DTLBMISS_VECTOR 0x12
72#define ASM_8XX_ITLBERROR_VECTOR 0x13
73#define ASM_8XX_DTLBERROR_VECTOR 0x14
74#define ASM_8XX_DBREAK_VECTOR 0x1C
75#define ASM_8XX_IBREAK_VECTOR 0x1D
76#define ASM_8XX_PERIFBREAK_VECTOR 0x1E
77#define ASM_8XX_DEVPORT_VECTOR 0x1F
78
79#define ASM_5XX_FLOATASSIST_VECTOR 0x0E
80#define ASM_5XX_SOFTEMUL_VECTOR 0x10
81#define ASM_5XX_IPROT_VECTOR 0x13
82#define ASM_5XX_DPROT_VECTOR 0x14
83#define ASM_5XX_DBREAK_VECTOR 0x1C
84#define ASM_5XX_IBREAK_VECTOR 0x1D
85#define ASM_5XX_MEBREAK_VECTOR 0x1E
86#define ASM_5XX_NMEBREAK_VECTOR 0x1F
87
88#define ASM_60X_VEC_VECTOR 0x0A
89#define ASM_60X_PERFMON_VECTOR 0x0F
90#define ASM_60X_IMISS_VECTOR 0x10
91#define ASM_60X_DLMISS_VECTOR 0x11
92#define ASM_60X_DSMISS_VECTOR 0x12
93#define ASM_60X_ADDR_VECTOR 0x13
94#define ASM_60X_SYSMGMT_VECTOR 0x14
95#define ASM_60X_VEC_ASSIST_VECTOR 0x16
96#define ASM_60X_ITM_VECTOR 0x17
97
98/* Book E */
99#define ASM_BOOKE_CRIT_VECTOR 0x01
100/* We could use the std. decrementer vector # on bookE, too,
101 * but the bookE decrementer has slightly different semantics
102 * so we use a different vector (which happens to be
103 * the PIT vector on the 405 which is like the booke decrementer)
104 */
105#define ASM_BOOKE_DEC_VECTOR 0x10
106#define ASM_BOOKE_ITLBMISS_VECTOR 0x11
107#define ASM_BOOKE_DTLBMISS_VECTOR 0x12
108#define ASM_BOOKE_FIT_VECTOR 0x13
109#define ASM_BOOKE_WDOG_VECTOR 0x14
110#define ASM_BOOKE_APU_VECTOR 0x18
111#define ASM_BOOKE_DEBUG_VECTOR ASM_TRACE_VECTOR
112
113/* e200 and e500 */
114#define ASM_E500_SPE_UNAVAILABLE_VECTOR ASM_60X_VEC_VECTOR
115#define ASM_E500_EMB_FP_DATA_VECTOR 0x19
116#define ASM_E500_EMB_FP_ROUND_VECTOR 0x1A
117#define ASM_E500_PERFMON_VECTOR ASM_60X_PERFMON_VECTOR
118
119/* e300 */
120#define ASM_E300_CRIT_VECTOR 0x0A
121#define ASM_E300_PERFMON_VECTOR ASM_60X_PERFMON_VECTOR
122#define ASM_E300_IMISS_VECTOR ASM_60X_IMISS_VECTOR /* Special case: Shadowed GPRs */
123#define ASM_E300_DLMISS_VECTOR ASM_60X_DLMISS_VECTOR /* Special case: Shadowed GPRs */
124#define ASM_E300_DSMISS_VECTOR ASM_60X_DSMISS_VECTOR /* Special case: Shadowed GPRs */
125#define ASM_E300_ADDR_VECTOR ASM_60X_ADDR_VECTOR
126#define ASM_E300_SYSMGMT_VECTOR ASM_60X_SYSMGMT_VECTOR
127
128/*
129 * If you change that number make sure to adjust the wrapper code in ppc_exc.S
130 * and that ppc_exc_handler_table will be correctly initialized.
131 */
132#define LAST_VALID_EXC 0x1F
133
134/* DO NOT USE -- this symbol is DEPRECATED
135 * (only used by libbsp/shared/vectors/vectors.S
136 * which should not be used by new BSPs).
137 */
138#define ASM_60X_VEC_VECTOR_OFFSET 0xf20
139
140#define ASM_PPC405_FIT_VECTOR_OFFSET 0x1010
141#define ASM_PPC405_WDOG_VECTOR_OFFSET 0x1020
142#define ASM_PPC405_TRACE_VECTOR_OFFSET 0x2000
143
154/*
155 * The callee (high level exception code written in C)
156 * will store the Link Registers (return address) at entry r1 + 4 !!!.
157 * So let room for it!!!.
158 */
159#define LINK_REGISTER_CALLEE_UPDATE_ROOM 4
160
161#define EXC_GENERIC_SIZE (PPC_EXC_FRAME_SIZE + PPC_STACK_RED_ZONE_SIZE)
162
163#define PPC_EXC_INTERRUPT_FRAME_SIZE CPU_INTERRUPT_FRAME_SIZE
164
165#if defined(__ALTIVEC__) && !defined(PPC_MULTILIB_ALTIVEC)
166#define EXC_VEC_OFFSET EXC_GENERIC_SIZE
167#ifndef PPC_CACHE_ALIGNMENT
168#error "Missing include file!"
169#endif
170/* 20 volatile registers
171 * + cache-aligned area for vcsr, vrsave
172 * + area for alignment
173 */
174#define EXC_VEC_SIZE (16*20 + 2*PPC_CACHE_ALIGNMENT)
175#else
176#define EXC_VEC_SIZE (0)
177#endif
178
179/*
180 * maintain the EABI requested 8 bytes aligment
181 * As SVR4 ABI requires 16, make it 16 (as some
182 * exception may need more registers to be processed...)
183 */
184#define EXCEPTION_FRAME_END (EXC_GENERIC_SIZE + EXC_VEC_SIZE)
185
188#ifndef ASM
189
197
210
215
216void BSP_printStackTrace(const BSP_Exception_frame *excPtr);
217
226typedef enum {
227 PPC_EXC_INVALID = 0,
228 PPC_EXC_ASYNC = 1,
229 PPC_EXC_CLASSIC = 2,
230 PPC_EXC_CLASSIC_ASYNC = PPC_EXC_CLASSIC | PPC_EXC_ASYNC,
231 PPC_EXC_405_CRITICAL = 4,
232 PPC_EXC_405_CRITICAL_ASYNC = PPC_EXC_405_CRITICAL | PPC_EXC_ASYNC,
233 PPC_EXC_BOOKE_CRITICAL = 6,
234 PPC_EXC_BOOKE_CRITICAL_ASYNC = PPC_EXC_BOOKE_CRITICAL | PPC_EXC_ASYNC,
235 PPC_EXC_E500_MACHCHK = 8,
236 PPC_EXC_E500_MACHCHK_ASYNC = PPC_EXC_E500_MACHCHK | PPC_EXC_ASYNC,
237 PPC_EXC_NAKED = 10
239
243typedef uint8_t ppc_exc_categories [LAST_VALID_EXC + 1];
244
245static inline bool ppc_exc_is_valid_category(ppc_exc_category category)
246{
247 return (unsigned) category <= (unsigned) PPC_EXC_NAKED;
248}
249
256void *ppc_exc_vector_address(unsigned vector, void *vector_base);
257
262const ppc_exc_categories *ppc_exc_categories_for_cpu(ppc_cpu_id_t cpu);
263
268static inline const ppc_exc_categories *ppc_exc_current_categories(void)
269{
270 return ppc_exc_categories_for_cpu(ppc_cpu_current());
271}
272
278 const ppc_exc_categories *categories,
279 unsigned vector
280);
281
296 unsigned vector,
297 void *vector_base,
298 ppc_exc_category category,
299 uint32_t *prologue,
300 size_t *prologue_size
301);
302
303static inline void ppc_exc_initialize_interrupt_stack(uintptr_t stack_begin)
304{
305 uintptr_t stack_size = rtems_configuration_get_interrupt_stack_size();
306 uintptr_t stack_end = stack_begin + stack_size;
307 uintptr_t stack_pointer = stack_end - PPC_MINIMUM_STACK_FRAME_SIZE;
308
309 /* Ensure proper interrupt stack alignment */
310 stack_pointer &= ~((uintptr_t) CPU_STACK_ALIGNMENT - 1);
311
312 /* Tag interrupt stack bottom */
313 *(uint32_t *) stack_pointer = 0;
314
315 /* Move interrupt stack values to special purpose registers */
316 PPC_SET_SPECIAL_PURPOSE_REGISTER(SPRG1, stack_pointer);
317 PPC_SET_SPECIAL_PURPOSE_REGISTER(SPRG2, stack_begin);
318}
319
326 uintptr_t interrupt_stack_begin,
327 void *vector_base
328);
329
343static inline void ppc_exc_initialize(void)
344{
346 (uintptr_t) _ISR_Stack_area_begin,
347 NULL
348 );
349}
350
359typedef int (*ppc_exc_handler_t)(BSP_Exception_frame *f, unsigned vector);
360
366int ppc_exc_handler_default(BSP_Exception_frame *f, unsigned int vector);
367
368#ifndef PPC_EXC_CONFIG_BOOKE_ONLY
369
380extern uint32_t ppc_exc_msr_bits;
381
382#endif /* PPC_EXC_CONFIG_BOOKE_ONLY */
383
397extern uint32_t ppc_exc_cache_wb_check;
398
399#ifndef PPC_EXC_CONFIG_USE_FIXED_HANDLER
403 extern ppc_exc_handler_t ppc_exc_handler_table [LAST_VALID_EXC + 1];
404
409#else /* PPC_EXC_CONFIG_USE_FIXED_HANDLER */
413 extern const ppc_exc_handler_t ppc_exc_handler_table [LAST_VALID_EXC + 1];
414
418 void bsp_interrupt_dispatch(uintptr_t exception_number);
419#endif /* PPC_EXC_CONFIG_USE_FIXED_HANDLER */
420
444
449
460extern uint32_t (*ppc_exc_get_DAR)(void);
461
462void
463ppc_exc_wrapup(BSP_Exception_frame *f);
464
471int ppc_exc_alignment_handler(BSP_Exception_frame *frame, unsigned excNum);
472
475/*
476 * Compatibility with pc386
477 */
478typedef exception_handler_t cpuExcHandlerType;
479
480#endif /* ASM */
481
482#ifdef __cplusplus
483}
484#endif
485
486#endif /* LIBCPU_VECTORS_H */
rtems_status_code
Definition: status.h:85
#define rtems_configuration_get_interrupt_stack_size()
Gets the interrupt stack size in bytes of this application.
Definition: config.h:440
#define PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val)
Sets the Special Purpose Register with number spr to the value in val.
Definition: powerpc-utility.h:590
char _ISR_Stack_area_begin[]
The interrupt stack area begin.
uint32_t(* ppc_exc_get_DAR)(void)
Function for DAR access.
Definition: ppc_exc_print.c:65
void ppc_exc_initialize_with_vector_base(uintptr_t interrupt_stack_begin, void *vector_base)
Initializes the exception handling.
Definition: ppc_exc_initialize.c:80
uint8_t ppc_exc_categories[LAST_VALID_EXC+1]
Categorie set type.
Definition: vectors.h:243
ppc_exc_handler_t ppc_exc_handler_table[LAST_VALID_EXC+1]
High-level exception handler table.
Definition: ppc_exc_hdl.c:55
int(* ppc_exc_handler_t)(BSP_Exception_frame *f, unsigned vector)
High-level exception handler type.
Definition: vectors.h:359
Cache write back check flag.
Definition: ppc_exc_initialize.c:30
ppc_exc_category ppc_exc_category_for_vector(const ppc_exc_categories *categories, unsigned vector)
Returns the category for the vector vector using the category set categories.
Definition: ppc_exc_categories.c:318
void * ppc_exc_vector_address(unsigned vector, void *vector_base)
Returns the entry address of the vector.
Definition: ppc_exc_address.c:60
Default high-level exception handler.
Definition: ppc_exc_hdl.c:45
void C_exception_handler(BSP_Exception_frame *excPtr)
Default global exception handler.
Definition: ppc_exc_global_handler.c:22
exception_handler_t globalExceptHdl
Global exception handler.
Definition: ppc_exc_hdl.c:52
ppc_exc_handler_t ppc_exc_get_handler(unsigned vector)
Returns the currently active high-level exception handler.
Definition: ppc_exc_hdl.c:61
rtems_status_code ppc_exc_set_handler(unsigned vector, ppc_exc_handler_t hdl)
Set high-level exception handler.
Definition: ppc_exc_hdl.c:73
ppc_exc_category
Exception categories.
Definition: vectors.h:226
rtems_status_code ppc_exc_make_prologue(unsigned vector, void *vector_base, ppc_exc_category category, uint32_t *prologue, size_t *prologue_size)
Makes a minimal prologue for the vector vector with the category category.
Definition: ppc_exc_prologue.c:104
void(* exception_handler_t)(BSP_Exception_frame *)
Global exception handler type.
Definition: vectors.h:209
const ppc_exc_categories * ppc_exc_categories_for_cpu(ppc_cpu_id_t cpu)
Returns the category set for a CPU of type cpu, or NULL if there is no category set available for thi...
Definition: ppc_exc_categories.c:252
Standard aligment handler.
Definition: ppc_exc_alignment.c:31
Bits for MSR update.
Definition: ppc_exc_hdl.c:41
General purpose assembler macros, linker command file support and some inline functions for direct re...
The set of registers that specifies the complete processor state.
Definition: cpu.h:446
