RTEMS 6.1
irq.h File Reference
Malta Interrupt Definitions. More...
#include <rtems/irq.h>
#include <rtems/irq-extension.h>
#include <rtems/score/mips.h>
#define MALTA_CPU_INT_START   MIPS_INTERRUPT_BASE+0
#define MALTA_CPU_INT_SW0   MALTA_CPU_INT_START+0
#define MALTA_CPU_INT_SW2   MALTA_CPU_INT_START+1
#define MALTA_CPU_INT0   MALTA_CPU_INT_START+2
#define MALTA_CPU_INT1   MALTA_CPU_INT_START+3
#define MALTA_CPU_INT2   MALTA_CPU_INT_START+4
#define MALTA_CPU_INT3   MALTA_CPU_INT_START+5
#define MALTA_CPU_INT4   MALTA_CPU_INT_START+6
#define MALTA_CPU_INT5   MALTA_CPU_INT_START+7
#define MALTA_CPU_INT_LAST   MALTA_CPU_INT5
#define MALTA_SB_IRQ_START   MALTA_CPU_INT_LAST+1
#define MALTA_SB_IRQ_0   MALTA_SB_IRQ_START+0
#define MALTA_SB_IRQ_1   MALTA_SB_IRQ_START+1
#define MALTA_SB_IRQ_2   MALTA_SB_IRQ_START+2
#define MALTA_SB_IRQ_3   MALTA_SB_IRQ_START+3
#define MALTA_SB_IRQ_4   MALTA_SB_IRQ_START+4
#define MALTA_SB_IRQ_5   MALTA_SB_IRQ_START+5
#define MALTA_SB_IRQ_6   MALTA_SB_IRQ_START+6
#define MALTA_SB_IRQ_7   MALTA_SB_IRQ_START+7
#define MALTA_SB_IRQ_8   MALTA_SB_IRQ_START+8
#define MALTA_SB_IRQ_9   MALTA_SB_IRQ_START+9
#define MALTA_SB_IRQ_10   MALTA_SB_IRQ_START+10
#define MALTA_SB_IRQ_11   MALTA_SB_IRQ_START+11
#define MALTA_SB_IRQ_12   MALTA_SB_IRQ_START+12
#define MALTA_SB_IRQ_13   MALTA_SB_IRQ_START+13
#define MALTA_SB_IRQ_14   MALTA_SB_IRQ_START+14
#define MALTA_SB_IRQ_15   MALTA_SB_IRQ_START+15
#define MALTA_SB_IRQ_LAST   MALTA_SB_IRQ_15
#define MALTA_PCI_ADP_START   MALTA_SB_IRQ_LAST+1
#define MALTA_PCI_ADP20   MALTA_PCI_ADP_START+0
#define MALTA_PCI_ADP21   MALTA_PCI_ADP_START+1
#define MALTA_PCI_ADP22   MALTA_PCI_ADP_START+2
#define MALTA_PCI_ADP27   MALTA_PCI_ADP_START+3
#define MALTA_PCI_ADP28   MALTA_PCI_ADP_START+4
#define MALTA_PCI_ADP29   MALTA_PCI_ADP_START+5
#define MALTA_PCI_ADP30   MALTA_PCI_ADP_START+6
#define MALTA_PCI_ADP31   MALTA_PCI_ADP_START+7
#define MALTA_PCI_ADP_LAST   MALTA_PCI_ADP31
#define BSP_INTERRUPT_VECTOR_COUNT   (MALTA_PCI_ADP_LAST + 1)
#define MALTA_INT_SOUTHBRIDGE_INTR   MALTA_CPU_INT0
#define MALTA_INT_SOUTHBRIDGE_SMI   MALTA_CPU_INT1
#define MALTA_INT_TTY2   MALTA_CPU_INT2
#define MALTA_INT_COREHI   MALTA_CPU_INT3
#define MALTA_INT_CORELO   MALTA_CPU_INT4
#define MALTA_INT_TICKER   MALTA_CPU_INT5
#define MALTA_IRQ_TIMER_SOUTH_BRIDGE   MALTA_SB_IRQ_0
#define MALTA_IRQ_KEYBOARD_SUPERIO   MALTA_SB_IRQ_1
#define MALTA_IRQ_RESERVED1_SOUTH_BRIDGE   MALTA_SB_IRQ_2
#define MALTA_IRQ_TTY1   MALTA_SB_IRQ_3
#define MALTA_IRQ_TTY0   MALTA_SB_IRQ_4
#define MALTA_IRQ_NOT_USED   MALTA_SB_IRQ_5
#define MALTA_IRQ_FLOPPY_SUPERIO   MALTA_SB_IRQ_6
#define MALTA_IRQ_PARALLEL_PORT_SUPERIO   MALTA_SB_IRQ_7
#define MALTA_IRQ_REALTIME_CLOCK_SOUTH_BRIDGE   MALTA_SB_IRQ_8
#define MALTA_IRQ_I2C_SOUTH_BRIDGE   MALTA_SB_IRQ_9
#define MALTA_IRQ_PCI_A_B   MALTA_SB_IRQ_10
#define MALTA_IRQ_PCI_C_D   MALTA_SB_IRQ_11
#define MALTA_IRQ_MOUSE_SUPERIO   MALTA_SB_IRQ_12
#define MALTA_IRQ_RESERVED2_SOUTH_BRIDGE   MALTA_SB_IRQ_13
#define MALTA_IRQ_PRIMARY_IDE   MALTA_SB_IRQ_14
#define MALTA_IRQ_SECONDARY_IDE   MALTA_SB_IRQ_15
#define MALTA_IRQ_SOUTH_BRIDGE   MALTA_PCI_ADP20
#define MALTA_IRQ_ETHERNET   MALTA_IRQ_PCI_A_B
#define MALTA_IRQ_AUDIO   MALTA_PCI_ADP22
#define MALTA_IRQ_CORE_CARD   MALTA_PCI_ADP27
#define MALTA_IRQ_PCI_CONNECTOR_1   MALTA_PCI_ADP28
#define MALTA_IRQ_PCI_CONNECTOR_2   MALTA_PCI_ADP29
#define MALTA_IRQ_PCI_CONNECTOR_3   MALTA_PCI_ADP30
#define MALTA_IRQ_PCI_CONNECTOR_4   MALTA_PCI_ADP31
