RTEMS 6.1
bsp.h
1
9/*
10 * Copyright (c) 2005 Eric Norum <eric@norum.ca>
11 *
12 * COPYRIGHT (c) 2005.
13 * On-Line Applications Research Corporation (OAR).
14 *
15 * The license and distribution terms for this file may be
16 * found in the file LICENSE in this distribution or at
17 * http://www.rtems.org/license/LICENSE.
18 */
19
20#ifndef LIBBSP_M68K_UC5282_BSP_H
21#define LIBBSP_M68K_UC5282_BSP_H
22
33#include <bspopts.h>
35
36#include <rtems.h>
37#include <rtems/bspIo.h>
38
39#ifdef __cplusplus
40extern "C" {
41#endif
42
43/***************************************************************************/
45/*
46 * Uncomment to use instruction/data cache
47 * Leave commented to use instruction-only cache
48 */
49#define RTEMS_MCF5282_BSP_ENABLE_DATA_CACHE
50
51/***************************************************************************/
53#include <mcf5282/mcf5282.h> /* internal MCF5282 modules */
54
55/***************************************************************************/
57struct rtems_bsdnet_ifconfig;
58extern int rtems_fec_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching );
59#define RTEMS_BSP_NETWORK_DRIVER_NAME "fs1"
60#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_fec_driver_attach
61
62/***************************************************************************/
65/* define which port the console should use - all other ports are then defined as general purpose */
66#define CONSOLE_PORT 0
67
68/* functions */
69
70typedef struct {
71 unsigned int l;
72 void *v;
74
75#define RTEMS_BSP_PGM_ERASE_FIRST 0x1
76#define RTEMS_BSP_PGM_RESET_AFTER 0x2
77#define RTEMS_BSP_PGM_EXEC_AFTER 0x4
78#define RTEMS_BSP_PGM_HALT_AFTER 0x8
79
80uint32_t bsp_get_CPU_clock_speed(void);
81rtems_status_code bsp_allocate_interrupt(int level, int priority);
82int bsp_sysReset(int flags);
83int bsp_program(bsp_mnode_t *chain, int flags);
84unsigned const char *bsp_gethwaddr(int a);
85const char *bsp_getbenv(const char *a);
86int bsp_flash_erase_range(volatile unsigned short *flashptr, int start, int end);
87int bsp_flash_write_range(volatile unsigned short *flashptr, bsp_mnode_t *chain, int offset);
88
89rtems_isr_entry set_vector(
90 rtems_isr_entry handler,
92 int type
93);
94
95/*
96 * Interrupt assignments
97 * Highest-priority listed first
98 */
99#define FEC_IRQ_LEVEL 4
100#define FEC_IRQ_RX_PRIORITY 7
101#define FEC_IRQ_TX_PRIORITY 6
102
103#define PIT3_IRQ_LEVEL 4
104#define PIT3_IRQ_PRIORITY 0
105
106#define UART0_IRQ_LEVEL 3
107#define UART0_IRQ_PRIORITY 7
108#define UART1_IRQ_LEVEL 3
109#define UART1_IRQ_PRIORITY 6
110#define UART2_IRQ_LEVEL 3
111#define UART2_IRQ_PRIORITY 5
112
113/*
114 * Fake VME support
115 * This makes it easier to use EPICS driver support on this BSP.
116 */
117#define VME_AM_STD_SUP_ASCENDING 0x3f
118#define VME_AM_STD_SUP_PGM 0x3e
119#define VME_AM_STD_USR_ASCENDING 0x3b
120#define VME_AM_STD_USR_PGM 0x3a
121#define VME_AM_STD_SUP_DATA 0x3d
122#define VME_AM_STD_USR_DATA 0x39
123#define VME_AM_EXT_SUP_ASCENDING 0x0f
124#define VME_AM_EXT_SUP_PGM 0x0e
125#define VME_AM_EXT_USR_ASCENDING 0x0b
126#define VME_AM_EXT_USR_PGM 0x0a
127#define VME_AM_EXT_SUP_DATA 0x0d
128#define VME_AM_EXT_USR_DATA 0x09
129#define VME_AM_SUP_SHORT_IO 0x2d
130#define VME_AM_USR_SHORT_IO 0x29
131
132/*
133 * 'Extended' BSP support
134 */
135rtems_status_code bspExtInit(void);
136typedef void (*BSP_VME_ISR_t)(void *usrArg, unsigned long vector);
137BSP_VME_ISR_t BSP_getVME_isr(unsigned long vector, void **parg);
138int BSP_installVME_isr(unsigned long vector, BSP_VME_ISR_t handler, void *usrArg);
139int BSP_removeVME_isr(unsigned long vector, BSP_VME_ISR_t handler, void *usrArg);
140int BSP_enableVME_int_lvl(unsigned int level);
141int BSP_disableVME_int_lvl(unsigned int level);
142int BSP_vme2local_adrs(unsigned am, unsigned long vmeaddr, unsigned long *plocaladdr);
143
144/*
145 * This BSP provides its own IDLE task to override the RTEMS one.
146 * So we prototype it and define the constant confdefs.h expects
147 * to configure a BSP specific one.
148 */
149void *bsp_idle_thread( uintptr_t ignored );
150#define BSP_IDLE_TASK_BODY bsp_idle_thread
151
152/*
153 * The custom IDLE task keeps some idle statistics.
154 */
155int bsp_cpu_load_percentage(void);
156
157/*
158 * This is a helper method to determine the cause of a reset.
159 */
160void bsp_reset_cause(char *buf, size_t capacity);
161
162/*
163 * SRAM. The BSP uses SRAM for maintaining some clock-driver data
164 * and for ethernet descriptors (and the initial stack during
165 * early boot).
166 */
167
169 volatile uint16_t status;
170 uint16_t length;
171 volatile void *buffer;
173
174extern struct {
175 uint32_t idle_counter;
176 uint32_t filtered_idle;
177 uint32_t max_idle_count;
178 uint32_t pitc_per_tick;
179 uint32_t nsec_per_pitc;
180 uint32_t pad[3]; /* align to 16-bytes for descriptors */
181 mcf5282BufferDescriptor_t fec_descriptors[];
182 /* buffer descriptors are allocated from here */
183
184 /* initial stack is at top of SRAM (start.S) */
185} __SRAMBASE;
186
187#ifdef __cplusplus
188}
189#endif
190
193#endif
This header file provides the kernel character input/output support API.
This header file provides the default definition of BSP_INITIAL_EXTENSION.
ISR_Handler_entry rtems_isr_entry
Interrupt service routines installed by rtems_interrupt_catch() shall have this type.
Definition: intr.h:134
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
rtems_status_code
Definition: status.h:85
void * bsp_idle_thread(uintptr_t ignored)
Optimized idle task.
Definition: bspidle.c:39
Definition: bsp.h:70
Definition: deflate.c:114
Definition: bsp.h:168
