RTEMS 6.1
Global BSP definitions. More...
#include <bspopts.h>
#include <bsp/default-initial-extension.h>
struct  pcc_map
#define RAM_START   0x00005000
#define RAM_END   0x00400000
#define pcc   ((volatile struct pcc_map * const) 0xfffe1000)
#define z8530   0xfffe3001
#define PCC_BASE_VECTOR   0x40 /* First user int */
#define SCC_VECTOR   PCC_BASE_VECTOR+3
#define TIMER_1_VECTOR   PCC_BASE_VECTOR+8
#define TIMER_2_VECTOR   PCC_BASE_VECTOR+9
#define SOFT_1_VECTOR   PCC_BASE_VECTOR+10
#define SOFT_2_VECTOR   PCC_BASE_VECTOR+11
#define USE_CHANNEL_A   1 /* 1 = use channel A for console */
#define USE_CHANNEL_B   0 /* 1 = use channel B for console */
#define CONSOLE_CONTROL   0xfffe3002
#define CONSOLE_DATA   0xfffe3003
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler.
rtems_isr_entry M68Kvec []
