RTEMS 6.1
bsp.h
1
9/*
10 * mcf5235 BSP header file
11 */
12
13#ifndef LIBBSP_M68K_MCF5235_BSP_H
14#define LIBBSP_M68K_MCF5235_BSP_H
15
26#include <bspopts.h>
28#include <rtems.h>
29#include <rtems/bspIo.h>
30
31/***************************************************************************/
33#include <mcf5235/mcf5235.h> /* internal MCF5235 modules */
34
35#ifdef __cplusplus
36extern "C" {
37#endif
38
39/***************************************************************************/
41struct rtems_bsdnet_ifconfig;
42extern int rtems_fec_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching );
43#define RTEMS_BSP_NETWORK_DRIVER_NAME "fec0"
44#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_fec_driver_attach
45
46/***************************************************************************/
49/* define which port the console should use - all other ports are then defined as general purpose */
50#define CONSOLE_PORT 0
51
52/* functions */
53
54uint32_t get_CPU_clock_speed(void);
55rtems_isr_entry set_vector(
56 rtems_isr_entry handler,
58 int type
59);
60
61/*
62 * Interrupt assignments
63 * Highest-priority listed first
64 */
65#define FEC_IRQ_LEVEL 4
66#define FEC_IRQ_RX_PRIORITY 7
67#define FEC_IRQ_TX_PRIORITY 6
68
69#define PIT3_IRQ_LEVEL 4
70#define PIT3_IRQ_PRIORITY 0
71
72#define UART0_IRQ_LEVEL 3
73#define UART0_IRQ_PRIORITY 7
74#define UART1_IRQ_LEVEL 3
75#define UART1_IRQ_PRIORITY 6
76#define UART2_IRQ_LEVEL 3
77#define UART2_IRQ_PRIORITY 5
78
79/*
80 * Prototypes for BSP methods which cross file boundaries
81 */
82void Init5235(void);
83
84#ifdef __cplusplus
85}
86#endif
87
90#endif
This header file provides the kernel character input/output support API.
This header file provides the default definition of BSP_INITIAL_EXTENSION.
ISR_Handler_entry rtems_isr_entry
Interrupt service routines installed by rtems_interrupt_catch() shall have this type.
Definition: intr.h:134
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
Definition: deflate.c:114
