RTEMS 6.1
bsp.h
1
9/*
10 * av5282 BSP header file
11 */
12
13#ifndef LIBBSP_M68K_AV5282_BSP_H
14#define LIBBSP_M68K_AV5282_BSP_H
15
26#ifndef ASM
27
28#include <bspopts.h>
30
31#include <rtems.h>
32#include <rtems/bspIo.h>
33
34/***************************************************************************/
36#include <mcf5282/mcf5282.h> /* internal MCF5282 modules */
37
38#ifdef __cplusplus
39extern "C" {
40#endif
41
42/***************************************************************************/
44struct rtems_bsdnet_ifconfig;
45extern int rtems_fec_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching );
46#define RTEMS_BSP_NETWORK_DRIVER_NAME "fs1"
47#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_fec_driver_attach
48
49/***************************************************************************/
52/* define which port the console should use - all other ports are then defined as general purpose */
53#define CONSOLE_PORT 0
54
55/* externals */
56
57/* constants */
58
59/* miscellaneous stuff assumed to exist */
60
61/* functions */
62
63uint32_t get_CPU_clock_speed(void);
64
65rtems_isr_entry set_vector(
66 rtems_isr_entry handler,
68 int type
69);
70
71/*
72 * Interrupt assignments
73 * Highest-priority listed first
74 */
75#define FEC_IRQ_LEVEL 4
76#define FEC_IRQ_RX_PRIORITY 7
77#define FEC_IRQ_TX_PRIORITY 6
78
79#define PIT3_IRQ_LEVEL 4
80#define PIT3_IRQ_PRIORITY 0
81
82#define UART0_IRQ_LEVEL 3
83#define UART0_IRQ_PRIORITY 7
84#define UART1_IRQ_LEVEL 3
85#define UART1_IRQ_PRIORITY 6
86#define UART2_IRQ_LEVEL 3
87#define UART2_IRQ_PRIORITY 5
88
89/*
90 * Prototypes for methods called from .S to alow dependency tracking
91 */
92void Init5282(void);
93
94#ifdef __cplusplus
95}
96#endif
97
98#endif /* !ASM */
99
102#endif
This header file provides the kernel character input/output support API.
This header file provides the default definition of BSP_INITIAL_EXTENSION.
ISR_Handler_entry rtems_isr_entry
Interrupt service routines installed by rtems_interrupt_catch() shall have this type.
Definition: intr.h:134
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
Definition: deflate.c:114
