RTEMS 6.1
barrierdata.h
2
13/* COPYRIGHT (c) 1989-2008.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_RTEMS_BARRIERDATA_H
39#define _RTEMS_RTEMS_BARRIERDATA_H
40
41#include <rtems/rtems/barrier.h>
44
45#ifdef __cplusplus
46extern "C" {
47#endif
48
58typedef struct {
66
71
81#define BARRIER_INFORMATION_DEFINE( max ) \
82 OBJECTS_INFORMATION_DEFINE( \
83 _Barrier, \
84 OBJECTS_CLASSIC_API, \
85 OBJECTS_RTEMS_BARRIERS, \
86 Barrier_Control, \
87 max, \
88 OBJECTS_NO_STRING_NAME, \
89 NULL \
90 )
91
94#ifdef __cplusplus
95}
96#endif
97
98#endif
99/* end of include file */
This header file defines the Barrier Manager API.
This header file provides interfaces of the Barrier Handler which are used by the implementation and ...
uint32_t rtems_attribute
This type represents Classic API attributes.
Definition: attr.h:96
Objects_Information _Barrier_Information
The Classic Barrier objects information.
This header file provides data structures used by the implementation and the Application Configuratio...
Definition: barrierdata.h:58
rtems_attribute attribute_set
Definition: barrierdata.h:64
CORE_barrier_Control Barrier
Definition: barrierdata.h:62
Objects_Control Object
Definition: barrierdata.h:60
This control block is used to manage a barrier.
Definition: corebarrier.h:64
Definition: objectdata.h:61
The information structure used to manage each API class of objects.
Definition: objectdata.h:198
