RTEMS 6.1
usart.c File Reference
#include "chip.h"
#include <assert.h>
void USART_SetBaudrate (Usart *pUsart, uint8_t OverSamp, uint32_t baudrate, uint32_t masterClock)
 Configures an USART baudrate.
void USART_Configure (Usart *pUsart, uint32_t mode, uint32_t baudrate, uint32_t masterClock)
 Configures an USART peripheral with the specified parameters.
void USART_SetTransmitterEnabled (Usart *pUsart, uint8_t enabled)
 Enables or disables the transmitter of an USART peripheral.
void USART_DisableRx (Usart *pUsart)
 Disables the Receiver of an USART peripheral.
void USART_DisableTx (Usart *pUsart)
 Disables the transmitter of an USART peripheral.
void USART_EnableRx (Usart *pUsart)
 Enables the Receiver of an USART peripheral.
void USART_EnableTx (Usart *pUsart)
 Enables the transmitter of an USART peripheral.
void USART_ResetRx (Usart *pUsart)
 Resets or disables the Receiver of an USART peripheral.
void USART_ResetTx (Usart *pUsart)
 resets and disables the transmitter of an USART peripheral.
void USART_SetReceiverEnabled (Usart *pUsart, uint8_t enabled)
 Enables or disables the receiver of an USART peripheral.
void USART_SetRTSEnabled (Usart *pUsart, uint8_t enabled)
 Enables or disables the Request To Send (RTS) of an USART peripheral.
void USART_Write (Usart *pUsart, uint16_t data, volatile uint32_t timeOut)
 Sends one packet of data through the specified USART peripheral. This function operates synchronously, so it only returns when the data has been actually sent.
uint16_t USART_Read (Usart *pUsart, volatile uint32_t timeOut)
 Reads and return a packet of data on the specified USART peripheral. This function operates asynchronously, so it waits until some data has been received.
uint8_t USART_IsDataAvailable (Usart *pUsart)
 Returns 1 if some data has been received and can be read from an USART; otherwise returns 0.
void USART_PutChar (Usart *pUsart, uint8_t c)
uint32_t USART_IsRxReady (Usart *pUsart)
 Return 1 if a character can be read in USART.
uint32_t USART_GetStatus (Usart *pUsart)
 Get present status.
void USART_EnableIt (Usart *pUsart, uint32_t mode)
 Enable interrupt.
void USART_DisableIt (Usart *pUsart, uint32_t mode)
 Disable interrupt.
uint32_t USART_GetItMask (Usart *pUsart)
 Return interrupt mask.
uint8_t USART_GetChar (Usart *pUsart)
 Reads and returns a character from the USART.
void USART_EnableRecvTimeOut (Usart *pUsart, uint32_t Timeout)
 Enable Rx Timeout for USART.
void USART_EnableTxTimeGaurd (Usart *pUsart, uint32_t TimeGaurd)
 Enable Tx Timeout for USART.
void USART_AcknowledgeRxTimeOut (Usart *pUsart, uint8_t Periodic)
 Acknowledge Rx timeout and sets to Idle or periodic repetitive state.
Implementation of USART (Universal Synchronous Asynchronous Receiver Transmitter) controller.
◆ USART_AcknowledgeRxTimeOut()
void USART_AcknowledgeRxTimeOut ( Usart pUsart,
uint8_t  Periodic
Parameters
pUsartPointer to an USART peripheral.
PeriodicIf timeout is periodic or should wait for new char
Returns
None
◆ USART_Configure()
void USART_Configure ( Usart pUsart,
uint32_t  mode,
uint32_t  baudrate,
Parameters
pUsartPointer to the USART peripheral to configure.
modeDesired value for the USART mode register (see the datasheet).
baudrateBaudrate at which the USART should operate (in Hz).
masterClockFrequency of the system master clock (in Hz).
◆ USART_DisableIt()
void USART_DisableIt ( Usart pUsart,
uint32_t  mode
Disable interrupt.
Parameters
modeInterrupt mode.
◆ USART_DisableRx()
void USART_DisableRx ( Usart pUsart)
Parameters
◆ USART_DisableTx()
void USART_DisableTx ( Usart pUsart)
Parameters
◆ USART_EnableIt()
void USART_EnableIt ( Usart pUsart,
uint32_t  mode
Enable interrupt.
Parameters
modeInterrupt mode.
◆ USART_EnableRecvTimeOut()
void USART_EnableRecvTimeOut ( Usart pUsart,
uint32_t  Timeout
Parameters
TimeoutTimeout value
Returns
None
◆ USART_EnableRx()
void USART_EnableRx ( Usart pUsart)
Parameters
◆ USART_EnableTx()
void USART_EnableTx ( Usart pUsart)
Parameters
◆ USART_EnableTxTimeGaurd()
void USART_EnableTxTimeGaurd ( Usart pUsart,
uint32_t  TimeGaurd
Parameters
TimeGaurdTimeGaurd value
Returns
None
◆ USART_GetChar()
uint8_t USART_GetChar ( Usart pUsart)
Note
This function is synchronous (i.e. uses polling).
Parameters
Returns
Character received.
◆ USART_GetItMask()
uint32_t USART_GetItMask ( Usart pUsart)
Parameters
◆ USART_GetStatus()
uint32_t USART_GetStatus ( Usart pUsart)
Get present status.
Parameters
◆ USART_IsDataAvailable()
uint8_t USART_IsDataAvailable ( Usart pUsart)
Parameters
pUsartPointer to an USART instance.
◆ USART_IsRxReady()
uint32_t USART_IsRxReady ( Usart pUsart)
Parameters
◆ USART_PutChar()
void USART_PutChar ( Usart pUsart,
uint8_t  c
Parameters
cCharacter to send
◆ USART_Read()
uint16_t USART_Read ( Usart pUsart,
Parameters
timeOutTime out value (0 -> no timeout).
◆ USART_ResetRx()
void USART_ResetRx ( Usart pUsart)
Parameters
◆ USART_ResetTx()
void USART_ResetTx ( Usart pUsart)
Parameters
◆ USART_SetBaudrate()
void USART_SetBaudrate ( Usart pUsart,
uint8_t  OverSamp,
uint32_t  baudrate,
Parameters
◆ USART_SetReceiverEnabled()
void USART_SetReceiverEnabled ( Usart pUsart,
uint8_t  enabled
Parameters
enabledIf true, the receiver is enabled; otherwise it is disabled.
◆ USART_SetRTSEnabled()
void USART_SetRTSEnabled ( Usart pUsart,
uint8_t  enabled
Parameters
enabledIf true, the RTS is enabled (0); otherwise it is disabled.
◆ USART_SetTransmitterEnabled()
void USART_SetTransmitterEnabled ( Usart pUsart,
uint8_t  enabled
Parameters
enabledIf true, the transmitter is enabled; otherwise it is disabled.
◆ USART_Write()
void USART_Write ( Usart pUsart,
uint16_t  data,
Parameters
dataData to send including 9nth bit and sync field if necessary (in the same format as the US_THR register in the datasheet).
timeOutTime out value (0 = no timeout).
