RTEMS 6.1
asrdata.h
2
13/* COPYRIGHT (c) 1989-2013.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_RTEMS_ASRDATA_H
39#define _RTEMS_RTEMS_ASRDATA_H
40
41#include <rtems/rtems/asr.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif
46
57typedef struct {
67
70#ifdef __cplusplus
71}
72#endif
73
74#endif
75/* end of include file */
This header file defines the parts of the Signal Manager API.
uint32_t rtems_mode
This type represents a Classic API task mode set.
Definition: modes.h:174
rtems_asr(* rtems_asr_entry)(rtems_signal_set)
This type defines the prototype of routines which are used to process asynchronous signals.
Definition: asr.h:97
uint32_t rtems_signal_set
This integer type represents a bit field which can hold exactly 32 individual signals.
Definition: asr.h:87
Definition: asrdata.h:57
rtems_asr_entry handler
Definition: asrdata.h:61
bool is_enabled
Definition: asrdata.h:59
rtems_signal_set signals_pending
Definition: asrdata.h:65
rtems_mode mode_set
Definition: asrdata.h:63
