#define | RTEMS_SIGNAL_0 0x00000001 |
| | This signal set constant represents the bit in the signal set associated with signal 0.
#define | RTEMS_SIGNAL_1 0x00000002 |
| | This signal set constant represents the bit in the signal set associated with signal 1.
#define | RTEMS_SIGNAL_2 0x00000004 |
| | This signal set constant represents the bit in the signal set associated with signal 2.
#define | RTEMS_SIGNAL_3 0x00000008 |
| | This signal set constant represents the bit in the signal set associated with signal 3.
#define | RTEMS_SIGNAL_4 0x00000010 |
| | This signal set constant represents the bit in the signal set associated with signal 4.
#define | RTEMS_SIGNAL_5 0x00000020 |
| | This signal set constant represents the bit in the signal set associated with signal 5.
#define | RTEMS_SIGNAL_6 0x00000040 |
| | This signal set constant represents the bit in the signal set associated with signal 6.
#define | RTEMS_SIGNAL_7 0x00000080 |
| | This signal set constant represents the bit in the signal set associated with signal 7.
#define | RTEMS_SIGNAL_8 0x00000100 |
| | This signal set constant represents the bit in the signal set associated with signal 8.
#define | RTEMS_SIGNAL_9 0x00000200 |
| | This signal set constant represents the bit in the signal set associated with signal 9.
#define | RTEMS_SIGNAL_10 0x00000400 |
| | This signal set constant represents the bit in the signal set associated with signal 10.
#define | RTEMS_SIGNAL_11 0x00000800 |
| | This signal set constant represents the bit in the signal set associated with signal 11.
#define | RTEMS_SIGNAL_12 0x00001000 |
| | This signal set constant represents the bit in the signal set associated with signal 12.
#define | RTEMS_SIGNAL_13 0x00002000 |
| | This signal set constant represents the bit in the signal set associated with signal 13.
#define | RTEMS_SIGNAL_14 0x00004000 |
| | This signal set constant represents the bit in the signal set associated with signal 14.
#define | RTEMS_SIGNAL_15 0x00008000 |
| | This signal set constant represents the bit in the signal set associated with signal 15.
#define | RTEMS_SIGNAL_16 0x00010000 |
| | This signal set constant represents the bit in the signal set associated with signal 16.
#define | RTEMS_SIGNAL_17 0x00020000 |
| | This signal set constant represents the bit in the signal set associated with signal 17.
#define | RTEMS_SIGNAL_18 0x00040000 |
| | This signal set constant represents the bit in the signal set associated with signal 18.
#define | RTEMS_SIGNAL_19 0x00080000 |
| | This signal set constant represents the bit in the signal set associated with signal 19.
#define | RTEMS_SIGNAL_20 0x00100000 |
| | This signal set constant represents the bit in the signal set associated with signal 20.
#define | RTEMS_SIGNAL_21 0x00200000 |
| | This signal set constant represents the bit in the signal set associated with signal 21.
#define | RTEMS_SIGNAL_22 0x00400000 |
| | This signal set constant represents the bit in the signal set associated with signal 22.
#define | RTEMS_SIGNAL_23 0x00800000 |
| | This signal set constant represents the bit in the signal set associated with signal 23.
#define | RTEMS_SIGNAL_24 0x01000000 |
| | This signal set constant represents the bit in the signal set associated with signal 24.
#define | RTEMS_SIGNAL_25 0x02000000 |
| | This signal set constant represents the bit in the signal set associated with signal 25.
#define | RTEMS_SIGNAL_26 0x04000000 |
| | This signal set constant represents the bit in the signal set associated with signal 26.
#define | RTEMS_SIGNAL_27 0x08000000 |
| | This signal set constant represents the bit in the signal set associated with signal 27.
#define | RTEMS_SIGNAL_28 0x10000000 |
| | This signal set constant represents the bit in the signal set associated with signal 28.
#define | RTEMS_SIGNAL_29 0x20000000 |
| | This signal set constant represents the bit in the signal set associated with signal 29.
#define | RTEMS_SIGNAL_30 0x40000000 |
| | This signal set constant represents the bit in the signal set associated with signal 30.
#define | RTEMS_SIGNAL_31 0x80000000 |
| | This signal set constant represents the bit in the signal set associated with signal 31.
This header file defines the parts of the Signal Manager API.
